Caster and Toe degree/ Death wobble - JeepForum.com
post #1 of 3 Old 06-28-2012, 07:30 PM Thread Starter
milz87
Hey guys, new member to the fourm but not a stranger to the site. I know there are many many threads and posts related to death wobble and god knows ive read them all, but heres my situation.
I installed the Rubicon Express 3.5" Standard lift last weekend. Its a basic lift nothing special but was prepared to get parts as needed. I started getting the wobbles this week and went to 4 wheel parts to get aligned, they did the alignment the best they could without axle cams. So i bought a set and they installed them and brought the castor and toe into spec as best he could. (see image)
I still have the wobble when hitting a bump. Everything is stock except the new sway bars, springs, and shocks. I have currently on order an adjustable track bar. Im hoping this will do the trick, but while Im waiting id figured I would get some opinions.
All tie rods and bolts are tightened and in good condition. I posted the alignment report so you knowledgeable guys could opine.
milz87 is offline
post #2 of 3 Old 06-29-2012, 12:17 PM
loganm
When I first installed my lift I got bad DW at 30mph research how to do an alignment did it my self and it does fine at 75 80mph. Even though you took it to a shop it never hurts to double check the toe in. Also I check mine pretty much after every trail ride. It doesn't get outta line easily but it can happen. I lost the link but there's plenty out there.
loganm is offline
post #3 of 3 Old 07-05-2012, 08:19 PM Thread Starter
milz87
good call. Ended up installing a Rubicon express track bar and rancho steering stabilizer. drives like a champ now. i fear i only band-aided the issue with the stabilizer, but now i have a stable vehicle and can replace parts without feeling under pressure.
milz87 is offline
castor , death wobble , rubicon express , tj , toe
Death Wobble!!! Please Help!!! Little_Pioneer General Jeep & Off-Road Equipment 24 11-13-2011 08:22 AM
Death wobble Jeepchester General Jeep & Off-Road Equipment 5 07-06-2011 08:47 PM
Death Wobble aviator12 General Jeep & Off-Road Equipment 5 05-06-2011 04:27 PM
Death Wobble ben06 Tires & Wheels 6 08-25-2008 04:29 PM
Death Wobble nico597 Tires & Wheels 5 06-06-2006 07:07 AM
