can't remove a bolt - Page 2 - JeepForum.com
post #16 of 36 Old 11-19-2011, 05:29 PM
hammerz71
Get the breaker bar, everybody who owns a socket set should have one. Trust me, you'll need to use it more than just this once...
2002 Jeep Grand Cherokee Overland
Old Man Emu HD coils, 265/65/17 Nitto Terra Grapplers, Warn M8000, home made light bar, Cepek 130 watt lights, Hella 500s
CURRENTLY REBUILDING THE 4.7 HO ENGINE
hammerz71 is offline
post #17 of 36 Old 11-19-2011, 05:38 PM
austin6137
1990 XJ Cherokee
Originally Posted by jeepn4life92 View Post
i have an assortment of thick walled steel tubing purchased cheaply that i manage to need on every project, best investments ive made, go to your local home depot or lowes or any other home improvement store and buy a pipe witht the inside diamter just slightly larger than the outside diatemer or your socket wrench, slide it over the end and use it like that, be careful though, i have actually over loaded a socket wrench doing this and broke the ratcheting device on the inside (not entirely sure what to call it, lol) and the socket wrench would not hold a load after
I couldn't tell you how many ratchets I've killed doing that, lol thankfully I have craftsman. I've also split a few sockets to.
90 - xj laredo- 4.5" rough country lift, 6.5" of total lift with drop brackets, zj disc brakes on c8.25, olympic winch bumper, jcr upper and lower quarter armor, IRO hack-n-tap and rock sliders and rear bumper. rugged ridge 8500lb winch. Spartan locker up front. With a jd yellow paint job, 97+ front end and bushwacker cut out flares. 35's
austin6137 is offline
post #18 of 36 Old 11-19-2011, 08:01 PM
wolfcreek
Originally Posted by hoovail View Post
If a breaker bar doesn't work, and your feeling ballsy, try this.
That was me . It would be a little tough to use my patented technique on a drain plug with a vertical axis.
wolfcreek is offline
post #19 of 36 Old 11-20-2011, 09:42 AM
jeepn4life92
the one i broke was a craftsman too, lol
jeepn4life92 is offline
post #20 of 36 Old 11-20-2011, 09:47 AM
BriansCJ
1994 XJ Cherokee
I cant see a drain plug being that hard to get off. Get a breaker bar, and some pipe as already stated and go to town.
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #21 of 36 Old 11-20-2011, 09:56 AM
hammerz71
The only time I can remember having trouble getting one off was on a Honda 650 I had about 20 years ago. The first time I changed the oil after I bought it (used) it was a royal PIA, I ended up putting an air impact wrench on it.
I did have one on the ex's GC that the dealer had a hell of a time with and the service manager tried to tell me I cross threaded it myself or one of those quickie-lube places did it. This was a new car purchase and about the fourth oil change on the thing - freebie deal with the dealership for 3000 mile changes the first three years or 36k miles. I quickly went to the glove box and showed him that EVERY oil change was done THERE, by them and I had all the records! Made them take the pan off and re-tap it for free after he put his foot in his mouth.
Same dealership, same GC I had an issue when I had them rotate the tires about a year later, stripped lug and they broke it getting the bolt off - again, IT WAS MY FAULT until I produced receipts and they had to replace the stud and lug nut.
I do all my own work UNLESS it's free with a car purchase or it's a simple tire rotation that I'll have them do with a free oil change for the $15-20 they charge. IT PAYS TO KEEP ALL YOUR RECORDS HANDY, boys!!!
post #22 of 36 Old 11-20-2011, 10:11 AM
jeepn4life92
just wondering since we're discussing how we all have gotten majorly stuck bolts unstuck, does anyone have any understanding on what conditions (i.e. salty roads, very hot conditions, etc) tend to cause bolts such as the drain plug to get stuck. im thinking this bolt is getting stuck because of the "unusual" environments we sometimes take our jeeps thru and that this bolt is located in the heart of everything we run thru.
post #23 of 36 Old 11-20-2011, 01:10 PM
NonRubicon
Try soaking some DeepCreep on it before going at it with the breaker bar. I've had DeepCreep do the trick with stuck nuts/bolts when PB Blaster didn't cut it.
X2 on the pipe extension, on a quality 1/2" breaker bar.
NonRubicon is offline
post #24 of 36 Old 11-20-2011, 03:40 PM
austin6137
1990 XJ Cherokee
Yea I broke alot of craftsman tools, you gotta love lifetime warranties. Broke snapon tools to.
post #25 of 36 Old 11-20-2011, 04:17 PM
mopar408
1974 CJ5
alright, no flames here BUT if we're in agreement that we are speaking of the drain plug and you can't get it loose and are probably gonna break it off (it's only 1/2 SAE thread)....
It has nothing to do with structural strength at all. It simply keeps the oil from running out.
Go to Home Depot or the FLAPS and buy a BFN 3/16 and 11/32 bit, a 1/8 NPT pipe tap and a brass 1/8 NPT pipe plug. Center punch the face of the hex on the bolt, drill it first w/ 3/16 bit all the way thru til it hits oil.Thats for a pilot hole. ( keep putting grease on the end of the bit to trap and retain metal shavings) Then the 11/32 for the final hole. Tap the hole w/ the pipe tap and REMEMBER pipe thread is tapered, meaning it won't go completely thru but will get progressively tighter (cut 5or6 threads) Remove and put the brass plug in it and just remove it when you need to do oil change.
Sounds a lot harder than it is IF you are mechanically inclined.
Remember, I was raised in northeast Louisiana: Form Follows Function.
If it's good TO you, it's gotta be good FOR you....
mopar408 is offline
post #26 of 36 Old 11-21-2011, 05:45 AM
tjwrangler99
Take it back to the dealer/shop and let em have it... maybe they will give you a free oil change. There is no excuse for using an impact gun (which they probubly did) on a drain plug.
If you dont wanna do that, I sometimes put my breaker bar in a position, and jack the end up with my jack... Just be careful of it popping off and flying somewhere lol.
1999 TJ
BFG AT 31's | BDS 2" Lift | JKS Quick Disco's | Zone Rear Sway Links | TeraFlex 1/2" Drop+Washer | Warn M8000 | Viking 80' 3/8 Synthetic w/ Safety Thimble | Viking 350 Fairlead | MetalCloak AL Bumper | 99 Durango Steering Box | Uniden 520 CB w/ 3' FireStik | ebay header | Magnaflow Mid-Cat | Banks Cat-back | XJ Steering Linkage | Hella Black Magic (x4)
2011 Patriot FD1
tjwrangler99 is offline
post #27 of 36 Old 11-21-2011, 05:47 AM
tjwrangler99
Oh another option, if you dont want to heat the thing up... Just run the jeep for a while, get the oil/pan nice and hot... just be careful of the oil when u pop it off
1999 TJ
2011 Patriot FD1
post #28 of 36 Old 11-21-2011, 07:45 AM
mopar408
1974 CJ5
therein lies a problem. Obviously the oil is still IN it. Therefore if you try to heat the bolt you are only heating the oil. Like heating a pot to boil water. The oil would actually COOL the bolt.
One way would be to drill a small hole in the very bottom of the pan and drain the oil. Heat the bolt up yo a dull orange and remove, then weld the hole back up. That may be worth trying 'cause sooner or later OP's gonna break the sumb!+ch off flush and really be in trouble.
mopar408 is offline
post #29 of 36 Old 11-21-2011, 08:39 AM
tjwrangler99
what are you talking about? If the bolt/pan/oil is sitting at ambient temperature, and heating them is still increasing the tempurature overall. All components will absorb some of the heat, but its still an increase. This is why I said to run the motor for a while.
I would not drill a hole in the pan just to heat up a bolt. I would rather the head snap off, because then you just need a bolt extractor with a drill.
I think if you run the jeep for a bit, it may provide enough heat to get that sucker to move.
1999 TJ
2011 Patriot FD1
post #30 of 36 Old 11-21-2011, 11:10 AM
mopar408
1974 CJ5
what are you talking about? If the bolt/pan/oil is sitting at ambient temperature, and heating them is still increasing the tempurature overall. All components will absorb some of the heat, but it's still an increase. This is why I said to run the motor for a while.
Dude, proper oil temperature ( open to discussion) is 200/230 when hot. As far as removing a bolt, it usually involves heating it til it first starts to take on a glow, sorta dull orange.
I'm sure everyone has their own opinion on torch work, but come on....heating it up with oil temp you might as well use a hair drier instead of a torch.
With all due respect.
mopar408 is offline
How to Remove a Nut or Bolt Stuck in a Socket or Wrench 1Aauto Cheap Tricks & Fixes 10 10-26-2011 05:10 PM
1991 YJ rear seat belt bolt - cant remove BRI-NYG Fabrication Shop 11 09-29-2010 03:23 PM
Adding more bolts(8 bolt to 16 bolt) to 16.5 inch humvee wheels KJFactor Tires & Wheels 6 08-22-2010 07:48 PM
ahh moved the do not remove bolt!!! tallrugbyguy Engines & Drivetrain 0 03-05-2009 02:15 PM
Source for bolt-in D60/Ford 9"/GM 14 bolt TJ axles? flatlander757 Engines & Drivetrain 2 01-21-2008 04:14 PM
