Can i Make my 2 keys into 1? - JeepForum.com
post #1 of 11 Old 03-16-2012, 04:54 AM Thread Starter
Brandon1254
Im proud to say i finally bought my first jeep yesterday I love it...but i hate the fact that there is a separate key for both The doors, and ignition. If i take them both to a key cutter place (Ace) can they make one key that does both?
Also whats a normal price to get my Manual locks converted to auto(keyless entry)...Is it simple for someone with little experience to do it themselves?
Its a 96 Cherokee Classic(if that makes a difference)
Brandon1254 is offline
post #2 of 11 Old 03-16-2012, 07:20 AM
mike_dippert
mike_dippert's Avatar
You cannot combine keys by cutting them different. Look up how a lock cylinder works and you'll slap yourself for even asking. There's a chance you can get the door locks rekeyed to match the ignition.
mike_dippert is offline
post #3 of 11 Old 03-16-2012, 07:44 AM Thread Starter
Brandon1254
any clue how much something like that costs?
post #4 of 11 Old 03-16-2012, 08:46 AM
mike_dippert
For cars, no clue.
I used to do it for Schlage (sp?) brand house locks when I worked at a hardware store. I think we charged $15/lock. It took maybe 5 minutes if we knew the key code.
post #5 of 11 Old 03-16-2012, 09:24 AM
athos76
Most locksmiths can re-key the door to match the ignition or vice versa.
I had a hoopdee Honda Civic in Germany that had a separate key for every lock... Had the locksmith rekey them in about 30 minutes... Poor thing died a horrible death the next day though
2006 I6 6-Speed X, 33" Goodyear Duratrac, 8.8.
athos76 is offline
post #6 of 11 Old 03-16-2012, 09:25 AM
athos76
Usually $25-$45 bucks. I've had it done for $10 before if you remove the lock cylinder first.
athos76 is offline
post #7 of 11 Old 03-16-2012, 09:36 AM
nitecop
I know for fact it can be done on 68-9?? Fords because I did it for years. most doublesided keys can be done as well. most only have pins on one side of the lock.
Its cheap to try, you just to mark the key so you can know which way to insert it. Of course whoever cuts the key needs a old school key machine to make it happen.
Jim
USW, OAPSE Union member
99 TJ Sahara 4.0 5-Sp FUV + farm worker
Project f-Xj F150/XJ Ford eXtreme jeep combo
06 6 Speed LJ my daily driver.
Colorado Jeep club memeber #505
nitecop is offline
post #8 of 11 Old 03-16-2012, 10:12 AM
mike_dippert
[rant]I cannot express how much I hated using the old school key cutter at the hardware store. It was always my fault when the copy of a worn out key didn't work. A copy is, at best, going to be just as ****ty as the original.[/rant]
post #9 of 11 Old 03-16-2012, 10:25 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
By 1996 the Cherokee should have just one key for the doors and ignition. Assume that somebody changed one or the other for some reason.
You might be able to find a new set of matching locks with keys (try TeamCherokee.com), or as suggested you can get either the doors or the ignition re-keyed to match. I have had good luck finding full sets of locks at the junkyard. Find a donor with a key that is not worn flat, check all the locks, and then remove them. All the locks/key cylinders come right out when you remove the retaining clips.
CJ7-Tim is offline
post #10 of 11 Old 09-21-2013, 07:22 AM
Corbie
So two jeeps with one key to rule them all is possible ? I'll have to find a locksmith
Ps I use to use an old GM key to unlock my helicopter doors with
"Tires are like boobs. They always look big until you have played with them for a while. Then you just want a bigger set!”
-"YEEP” from Virtual Jeep Club
Corbie is offline
post #11 of 11 Old 09-24-2013, 09:39 AM
Indy
Indy's Avatar
Just put the two keys back to back, wrap duct tape around it so you have -------[]-------- And youre done.
I'm the only gay eskimo.
Indy is offline
cherokee , key , keyless entry , lock , price
Keys not responding corlen Cheap Tricks & Fixes 1 03-15-2012 09:52 AM
Just got the keys to the new shop! KMD Fabrication Shop 32 11-30-2011 10:45 AM
Transponder Keys - Liberty only came with one, cheapest method for more valid keys?He incucrash Audio, CB & Ham Radios, GPS, & Electrical 3 05-20-2009 09:42 PM
where to get 3/4 and7/8 hex keys 01xjRubidog General Jeep & Off-Road Equipment 2 05-15-2009 08:40 AM
2003 wranglers keys pat or not? 2003.wrangler Audio, CB & Ham Radios, GPS, & Electrical 2 08-02-2005 03:02 PM
