Can I clear 32x11.5x15s with only a 2.5 suspension lift (no body lift) on my 2006 TJ? - JeepForum.com
post #1 of 4 Old 04-21-2009, 08:40 AM Thread Starter
ddonjon
I have decided to upgrade my stock wheels and tires on my 2006 TJ..I would like to put on a set of 32 x 11.5 x 15's and would like to know if I can clear these wheels with a 2.5 inch suspension lift only. I want to avoid doing any body lift. Assuming my new wheels are okay as far as backspacing, can I clear this size tire?
ddonjon is offline
post #2 of 4 Old 04-21-2009, 10:03 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Yep, 2.5" of suspension lift is perfect for 32x11.50 tires. Make sure to go no wider than 15x8 on your wheels, with backspacing between 5" and no less than 3.75".
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Jerry Bransford is offline
post #3 of 4 Old 04-21-2009, 10:09 AM
SpoiledRotten
SpoiledRotten's Avatar
You'll have "plenty" of clearance. I ran 32's with no lift for quite a while and only rubbed the flares occasionally.
Christian Jeepers _ Member #2
United Four Wheel Drive Association _ Member
National Rifle Association _ Member
SpoiledRotten is offline
post #4 of 4 Old 04-21-2009, 10:49 AM
TiredOldMan
TiredOldMan's Avatar
I'm running 32x11.5x15 on 3.75 backspace wheels with a 2.5 suspension lift and no body lift. It works perfectly for me and keeps my COG low.
Looking for MB Shock wheel 15x8 5on4.5 3.75bs
" The problem with socialism is that eventually you run out of other peoples money"
Margaret Thatcher
TiredOldMan is offline
Why is it bad to have a body lift and a suspension lift? XJKingJeezy General Jeep & Off-Road Equipment 21 03-17-2009 03:49 PM
Body Lift or Suspension Lift dmb0485 Tires & Wheels 3 02-21-2006 06:07 AM
Whats the diff between Body Lift and Suspension Lift? loudog3114 Tires & Wheels 7 02-01-2005 02:27 PM
32x11.5x15 tires on 15x7 rims with 2" body lift? TJ LUVER Tires & Wheels 3 12-13-2004 05:40 AM
Body Lift with Suspension Lift?? RockinTJ Tires & Wheels 0 04-13-2001 12:45 PM
