Camber problems after lift - JeepForum.com
post #1 of 6 Old 08-21-2011, 07:18 PM Thread Starter
MunkMaster
ok here is the back story
96 jeep cherokee
had a 2 inch budget boost on the truck for acouple of years. alignment was fine. just put a RC 4.5 inch lift on the truck. adjustable control arms upper and lower. new coil springs new leaf packs adjustable track bar new shocks
my camber is effed.
i set the upper control arms at 15 inches and the lower at 16.5
full sye kit no vibrations. put the front driveshaft on now have vibrations.
i am going to check out the front shaft tommorrow afterwork.
its pooring down rain right now and i left alignment measurements in the truck i will post them up tommorrow
any ideas where i went wrong
the ball joints are good. nothing appears visually bent and i set the control arms up to what the instructions said.
thanks for all the help
MunkMaster is offline
post #2 of 6 Old 08-21-2011, 07:46 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The pinion angle is more important then the camber or caster. 3.5 - 4 inches of lift is the point at which you should consider control arm drop brackets to restore your suspension angles.
CJ7-Tim is offline
post #3 of 6 Old 08-21-2011, 08:00 PM
tjkj2002
2002 KJ Liberty
Camber will not change when lifting on a solid axle vehicle.I think you are reffering to caster.
tjkj2002 is offline
post #4 of 6 Old 08-22-2011, 05:41 AM Thread Starter
MunkMaster
Top of tire is camber in.
Caster is close but not dead on
post #5 of 6 Old 08-22-2011, 10:01 AM
muddy93
1987 FSJ Wagoneer
Like said above, CAMBER angle will NOT change when lifting a solid axle vehicle. The only things that will effect the camber angle(on a solid front axle) are; bad wheel bearings, bad ball joints, or a bent axle.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #6 of 6 Old 08-22-2011, 10:35 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
If you've got camber on your Cherokee, either your axle is bent or your ball joints are BEYOND shot.
~Richard
billzcat1 is offline
MBRP Off Camber Fabrications Line-X Bumpers MBRP General Jeep & Off-Road Equipment 3 07-13-2011 06:35 AM
Help needed. jeep Front end. camber problem wowsholva Engines & Drivetrain 0 06-27-2011 01:53 AM
camber adjustment on solid rear axle Ja$onMagnum Tires & Wheels 2 07-01-2009 01:34 PM
Setting camber on front wheels? possumwalk Tires & Wheels 4 09-11-2008 05:39 AM
camber LOCKED UP General Jeep & Off-Road Equipment 4 08-25-2003 08:14 AM
