Bumper Paint? - JeepForum.com
post #1 of 16 Old 11-22-2011, 04:01 PM Thread Starter
mbookxj
1989 XJ Cherokee
Bumper Paint?
I'm looking at a JCR Offroad front bumper for my 89 XJ. It comes bare steel. Anyone have any suggestions to what I should use to paint it? Powdercoating is a little expensive for me right now. Thanks.
mbookxj is offline
post #2 of 16 Old 11-22-2011, 08:25 PM
jlsalani
my son just put a JCR bumper on the front of his 00XJ.... we used a self etching primer and then hit it with a flat black spray paint. Looks great.
jlsalani is offline
post #3 of 16 Old 11-22-2011, 09:31 PM
kashoggio
Primer then Bedliner spray. Easy to touch up
2004 TJ RUBICON~ LIME GREEN
"Some desire is necessary to keep life in motion."
kashoggio is offline
post #4 of 16 Old 11-23-2011, 06:18 AM
sjpatg
I just re did my rear bumper with rustolium hammered and it looks very nice
sjpatg is offline
post #5 of 16 Old 11-23-2011, 07:07 AM
rdsk8ter
1982 CJ7
rustolium truck bed liner sprays on texture is minimal and hard as a rock. try to paint it on a hot day seems to work better
rdsk8ter is offline
post #6 of 16 Old 11-23-2011, 07:46 AM
RowJ
Don't powder coat...chips are too hard to fix.
Did my JCR bumper with primer and Krylon Satin Black rattle can.
Tried Flat Black first but too dull, IMO.
Key is to get it really clean before painting and keep can as close as possible to surface (8"), without creating runs.
Has held up well for a yr and is easy to touch up, if needed.
Liked it so much, I just did same to front factory bumper last month ....
after removing plastic bumper pads and angle cutting the ends with a grinder to look more off road style!
RowJ is offline
post #7 of 16 Old 11-23-2011, 12:06 PM Thread Starter
mbookxj
1989 XJ Cherokee
That looks really good! Thanks for the info and pics. Ordered my JCR prerunner front bumper today.
mbookxj is offline
post #8 of 16 Old 11-26-2011, 02:06 PM
JSahara00
i did the brush on rust ex, it dries smooth and very easy to touch seeing its brush on. no removal is necessary of the bumper.
00 TJ, OME shocks, all currie control arm, OME steering damper, Brown dog MML, VIAIR OBA with 2 quick disconnects at the doors, jks quick discos, Kolak exhaust, 30 spline D30 w/ ARB and 4:56, 8.8 w/ super 88 and ARB, home made F/R bumpers and tire carrier,OME zj front springs and OME Lj rear springs, CB w/ firestick, DIY highline fenders/hood, 35 pro comp mud terrains, cragar soft 8s .. .
95 XJ 4.0 4x4 Auto, V8 ZJ steering linkage
JSahara00 is offline
post #9 of 16 Old 11-26-2011, 06:18 PM
d-dub
Bumper Paint
I painted my bumpers with gloss black pRust Seal from " http://www.kbs-coatings.com/ " I pre treated the steel with a degreaser (Aqua clean) and their "Rust Blast" then brushed it on with two thin coats. It smooths out nicely but will run if you brush it on too thick. Then when it was almost dry I applied a goat of flat black spray can paint from Tractor Supply for UV protection.
My son rear ended a car the other day and the "Rust seal" had one tiny nick in the paint. The car, might have to be totaled out, it looked pretty bad.
d-dub is offline
post #10 of 16 Old 06-21-2014, 12:24 PM
silv1010
want to do my bumpers on my tj like yours and new to this wat primer did you use and wat grit?
thnks
silv1010 is offline
post #11 of 16 Old 06-21-2014, 03:17 PM
BYuen
BYuen's Avatar
I like Rustoleum enamel rattle can. It holds up much better to the sun and elements than their regular stuff.
BYuen is offline
post #12 of 16 Old 07-10-2014, 09:50 AM
silv1010
painted the bumper and turned out good i would def rec the satin finish bc the gloss doesnt rly work that well but still looks good anyone know why tht might be. PICS below
http://s1218.photobucket.com/user/si...P/JEEP%20PAINT
silv1010 is offline
post #13 of 16 Old 07-11-2014, 11:43 PM
Aaleck
2011 JK Wrangler
Plastidip? Never used the stuff; not sure how durable it would be.
Aaleck is offline
post #14 of 16 Old 07-14-2014, 03:24 AM
karlo
Plastidip will last for couple of months, although worth trying since it is cheap and easy to do/remove.
karlo is offline
post #15 of 16 Old 07-14-2014, 10:26 AM
XTJake
ExtremeTerrain.com
XTJake's Avatar
IMHO dip is great for temporary uses (even though they say it will hold up for the long term). The appeal of the stuff is that it's removable. If you want something permanent then regular paint is better.
I like a spray on bed liner or textured rattle can for ease of touch up. Powder coat looks great and will hold up well in normal conditions, but if you're going to rub the bumper on a tree or rocks then you'll want to be able to touch it up easily and cheaply.
Let me know if you have any questions!
-Ryan
Jake R. |
Off-Road Outfitters
Toll Free: 800-988-4605 | Mon-Fri 10AM-6PM EST
Free Shipping on Orders Over $75!
PM me for our JeepForum Discount Code (must have 25 posts) or Price-Matching!
XTJake is online now
Bumper Paint 2fst4you General Jeep & Off-Road Equipment 11 03-20-2011 10:47 AM
how do i paint new steel raw bumper? club_xcursion General Jeep & Off-Road Equipment 7 03-15-2010 03:37 PM
How much paint will I need to paint front bumper? Boilermaker52 General Jeep & Off-Road Equipment 2 04-21-2008 10:52 AM
What kinda bumper paint. element54 General Jeep & Off-Road Equipment 13 10-04-2006 04:45 PM
bumper paint mookarma General Jeep & Off-Road Equipment 1 01-30-2006 09:09 PM
