Build Your Own CO2 Tank System High Quality & Lowest Cost - Page 4 - JeepForum.com
 8Likes
post #46 of 154 Old 07-04-2012, 12:55 AM
durrster1128
I'm running a compressed air system which is way lighter and more compact then the c02 systems. I can run 3 4500psi tanks for the same space 1 10# tank takes up, what are the beneifits you see with c02? IMO I dont see any.
not to mention for the price or a 10# c02 tank im buying 2 72ci 4500psi air tanks
durrster1128 is offline
post #47 of 154 Old 07-04-2012, 08:00 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
72ci (cubic inch)? I think you mean cubic feet. And a single 72 cubic foot tank is larger/longer than a 10 lb C02 tank so you can't run 2-3 4500 psi 72 cubic foot tanks in the same space as a 10 lb. C02 tank. If you really meant cubic inch, you won't get many tire refills from that... even 3 of them... and not nearly as many as a 10 lb. C02 tank can fill.
Jerry Bransford is offline
post #48 of 154 Old 08-20-2012, 07:35 PM
vincejeep1
2010 JK Wrangler
My regulator came in installed it and my air hose. now I have a CO2 system $40 for the tank, $50 for the regulator , $9.99 for the air line, $6.99 for the gauge/air chuck.
2010 Wrangler Rubicon Unlimited . Dented skids, scraped rims, mud stains on the seats.
2001 jeep Cherokee
Just here to have fun
vincejeep1 is offline
post #49 of 154 Old 09-04-2012, 05:29 PM
mikebyn
where did you get all of your stuff at
2006 Tj: 2" BB, 1" BL, 33's
Build Thread:
http://www.jeepforum.com/forum/f22/2006-tj-dd-shooting-35s-37s-1258213/#post12088091
mikebyn is offline
post #50 of 154 Old 09-05-2012, 03:48 PM
vincejeep1
2010 JK Wrangler
The tank was off E-Bay. The air line and chuck from Harbor Freight. the regulator from Poly Performance http://www.polyperformance.com/shop/...tor-p-297.html Its 40.00 plus shipping which was kinda high but it was still the cheapest I found. hope that helps and by the way it works great.
2001 jeep Cherokee
post #51 of 154 Old 09-07-2012, 09:40 AM
speedracer1305
Does the polyperformance regulator have the quick disconnect on it? Doesnt look like it from the picture.
speedracer1305 is offline
post #52 of 154 Old 09-07-2012, 11:41 AM
vincejeep1
2010 JK Wrangler
No it does't you can get it from Harbor Frieght
2001 jeep Cherokee
post #53 of 154 Old 04-24-2013, 05:25 PM
Necromancer_tat
Where'd all my money go?
Necromancer_tat's Avatar
2015 JK Wrangler
Jerry, can you fix the OP's links please? None of them work when clicked on. The replies are hit and miss if they work or not.
My newest build:
Necromancer_tat is offline
post #54 of 154 Old 04-24-2013, 07:14 PM
sardog12
sardog12's Avatar
My quick disconnect from HF doesn't seal very well when I am airing my tires so I am going to look into getting one from Lowe's tomorrow in the hopes of finding one that will work better.
GEAUX TIGERS
sardog12 is offline
post #55 of 154 Old 05-01-2013, 02:40 PM
cincyjeeprs
My 2 ('er 5) cents on this:
1. I prefer an adjustable regulator, rather than fixed. Sometimes you are filling up little stuff around the house instead of just your big meats. Don't want to blow up (explode) baby's bouncy ball.
2. If you do use it for air tools, most call for 90 psi max.
3. Power Tank products may be a little spendy, but all of their stuff is top quality. Compare a quick disconnect fitting from them, to one from HF. It's a world of difference, with all due deference to our Chinese friends.
4. I have a Power Tank 10# system with the fancy schmancy lighted digital gauge, and I like it A LOT. They also have a high volume regulator for you guys with the 44s.
5. Great Write-Up. Thanks for all your hard work, MagicMtnDan.
cincyjeeprs is offline
post #56 of 154 Old 07-22-2013, 08:13 PM
pwmac
co2 reg
Got a 20# system works great. Problem is after doing 4 or more fat tires the reg flow rate slows drastically. Obviously the thing is getting super cold. Switched regs and the other one does the same thing.
In the welding industry and other operations that require flow for a considerable time they all use regulator heaters. I would like to try one, but they are all 110.vac
Does anyone have a source for a 12v reg heater?
Thanks, PaulW
pwmac
Durango, CO
06 Rubicon, modified
pwmac is offline
post #57 of 154 Old 12-19-2013, 10:11 PM
VTOLRN
1994 ZJ
Got bored and started building a mount for one of my extra Homebrew Co2 tanks. Still needs some work/ paint/ rubber vibration padding. Have an extra regator that I'll set up with Air chuck
Free score 1994 ZJ with 200k, Winter Cruiser, MTB hauler, ?.
VTOLRN is offline
post #58 of 154 Old 03-30-2014, 04:43 AM
BROWNING3250CAL
Good job, thank you! I'm scrapping the air compressor idea and building a 15lb tank setup!
BROWNING3250CAL is offline
post #59 of 154 Old 03-30-2014, 05:35 AM
wilson1010
I recommend a 10 pound plus a 5 pound. Or, if you prefer two 10 pound tanks since they are easier to find. You only need another tank since you switch the regulator over. That way I never run out. And, I can use it completely without being "out of air" somewhere.
One is strapped to the floor, the other in a stand up bracket.
PS: You don't need a gauge or adjustable regulator. Just a fixed pressure 150 psi regulator.
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline
post #60 of 154 Old 03-30-2014, 05:40 AM
BROWNING3250CAL
Good to know. I'll do 2 10 lb tanks. The guage is uneccessary because it doesn't read accurately?
Who Makes High Quality Pinion Bearings? ntaousakis Engines & Drivetrain 3 04-18-2008 06:12 AM
What is the average cost to build a rear bumper tire carrier? Rescue06 Fabrication Shop 10 04-04-2008 06:50 PM
My idea for a low cost system in my TJ. JeepRocks86 Audio, CB & Ham Radios, GPS, & Electrical 2 12-10-2007 07:37 AM
Want to build a low cost stroker...looking for input. atomicmoose Engines & Drivetrain 15 03-08-2007 01:05 PM
