Build Your Own CO2 Tank System High Quality & Lowest Cost - Page 3 - JeepForum.com
 8Likes
post #31 of 154 Old 11-03-2011, 05:35 PM
OlivergreenCJ7
Anyone know if there is a fixed regulator that has 100psi output? I'm looking for a way to run air tools without buying the expensive adjustable regulators. I figure 100psi would be safe for tools yet still pretty quick for airing up tires. Anyone have some links?
Thanks
1979 CJ7: Gone,but not forgotten
2001 TJ Sport: locked and loaded
OlivergreenCJ7 is offline
post #32 of 154 Old 11-12-2011, 01:30 PM
neonhomer
I have a friend of mine who hooked me up with a spare CO2 regulator. It needed a high pressure gauge, to which I just removed it and plugged the hole. So I have an adjustable regulator and low pressure gauge.
I also have three 20# CO2 cylinders, but they are all out of date. Last time I checked, a local gas supply shop wanted $45 to recertify the tank, and then more to fill it.
CO2 is handy to have though.... When a buddy of mine put a tree branch through his sidewall, we used my CO2 (When I had some gas left) setup and his impact to change the tire in the middle of the woods.
NeonHomer
Mid-Florida Jeep Club - Member
1996 Jeep Grand Cherokee, 4.0L/42RE/242 - Rebuilt motor w/ Comp cam (4/12), 3.5" Junkyard F>R lift, 31x10.5.x15 M/T's, Spartan Locked D44a, TC & tank skids, F&R adj trackbars, V8 steering arms
Galaxy DX99V CB, 102" SS Whip, Yaesu FT-2900R 2m, Larsen 1/4w mag mount, Sony HU, Massive 3way - F Door, Pioneer 3way - R Doors, MB Quart ONX304 Subs (x2), Lanzar 1600w amp.
"No Matter Where You Go... There You Are."
"Oh me oh my a lovely day is dawning. Oh what a joy I didn't wake up dead. So I can go to work and then resume my yawning, and get my sleep on site instead of in my bed" - Daria Morgendorffer (with my twist)
neonhomer is offline
post #33 of 154 Old 12-14-2011, 04:22 PM
timekpr5
Looking for peoples experience on longevity of the CO2 charge in the tank. I would be filling my 37/12.5 tires from 8 to approximately 20 psi. Best guess on how many times I could use it?
timekpr5 is offline
post #34 of 154 Old 12-14-2011, 04:52 PM
adamkn
adamkn's Avatar
If you look up the Powertank website, I believe they have a chart with the info you are looking for.
2000 TJ
adamkn is offline
post #35 of 154 Old 12-14-2011, 06:14 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Based on my being able to fill my 35x12.50 tires from 7-8 to 25 psi four times with a little left over in a 10 lb. tank, I'd guess probably three times.
Gone on vacation until August 25.
Jerry Bransford is offline
post #36 of 154 Old 01-17-2012, 08:14 AM
timekpr5
Thank you Jerry. That was what I was looking for. I have been told the OffRoad Air OA-REG150 Hyper-Flo regulator has, or is about to be discontinued. Has anyone else heard the same?
2004 TJ, 14,700 actual miles, JK axles, About every piece of body armor Genright makes (dent it - cover it with body armor). Stretched, 4-speed Atlas, AEV beadlocks, 37/12.5-17 Goodrich KM2 tires, and a whole bunch of other stuff too.
timekpr5 is offline
post #37 of 154 Old 01-17-2012, 03:37 PM
timekpr5
Is a 10# tank what most people use? I can get the 10# Poly Performance CO2 Kit for $219 delivered.
timekpr5 is offline
post #38 of 154 Old 01-17-2012, 07:31 PM
Jerry Bransford
Administrator
Yes, 10 lbs. is the standard size used for this purpose. You can do better than $219 if you buy the tank, regulator, and other misc. parts separately but that's not a bad price for one that is ready to go.
post #39 of 154 Old 02-06-2012, 07:07 PM
99alpine
1988 XJ Cherokee
Can these set-ups run air tools fine? Such as a cut off wheel or impact?
32" Goodyear MT/R, 3" Bodylift (soon to be cut down,) Homemade Quick Disconnects, '87 Blazer Swingout Tire Carrier.
Upcoming: Upgrade to 33" Goodyear Duratrac's, Full Teraflex system (shocks (front and rear,) disconnects, skids, diff covers, and steering stabilizer,) custom built front and rear bumpers, custom built flat fenders, custom built sliders, flush tail lights and re-located front turn signals.
99alpine is offline
post #40 of 154 Old 02-07-2012, 07:15 PM
Jerry Bransford
Administrator
Yep but that'd be an expensive use of them. For limited use, it'd run an impact tool fine on the trail but something like a cutoff wheel or grinder uses too much air (C02) for it to last all that long. I wouldn't waste my C02 running air tools.
post #41 of 154 Old 02-09-2012, 06:18 PM
timekpr5
$49.62 Poly Performance CO2 regulator. $81.99 10# CO2 tank from http://www.aquariumplants.com/. $48.37 Kidde Safety RB16 Running Board Bracket for 20# SKU:408-292474 WEIGHT:15.00 lbs(s) (yes the 10# tank fits) from ReStockit.com. $20.00 misc. parts. Grand total = $199.98. Of course that does not include the incorrect $23.86 running board bracket that I bought in my first attempt (thought the price was to good to be true). Always did want a 10 pound extinguisher with a 5" diameter in my truck. I saved $20.00 by ordering the parts individually instead of buying the $219.00 Poly Performance CO2 package. All the prices are delivered and were the best I could find at the time I ordered.
timekpr5 is offline
post #42 of 154 Old 02-09-2012, 08:17 PM
timekpr5
Anyone know where to get these fittings. http://www.8-lug.com/tech/1103_8l_po.../photo_06.html I am sure ARB must buy them from somebody. Disregard = I found them. PowerTank has them.
timekpr5 is offline
post #43 of 154 Old 04-09-2012, 03:48 AM
mudruna
1994 ZJ
Would there be any difference in parts if you were to use nitrogen? Not sure of the price difference, just trying to do my homework before I pull the trigger on this project.
94 ZJ Limited- 7" IRO premium, 4.56 gears on Elockers and Chromo's, 35" claws on beadlocks, Kevin's sliders
mudruna is offline
post #44 of 154 Old 05-29-2012, 10:03 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Thank's for the info I've been eyeing up a powertank for sometime now ! Now I can build one and spend more money
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #45 of 154 Old 06-11-2012, 10:00 PM
GOATKrawler
im getting ready to do this as im pretty sure my air compressor is about to take a dive. only thing i need to figure out is where to mount it in my LJ. and are there any other "filler" hoses. not the coil hose but the part that actually attaches to the valve stem? also anyone have hints tips tricks or need to know info would be greatly apperciated!!
GOATKrawler is offline
Who Makes High Quality Pinion Bearings? ntaousakis Engines & Drivetrain 3 04-18-2008 06:12 AM
What is the average cost to build a rear bumper tire carrier? Rescue06 Fabrication Shop 10 04-04-2008 06:50 PM
My idea for a low cost system in my TJ. JeepRocks86 Audio, CB & Ham Radios, GPS, & Electrical 2 12-10-2007 07:37 AM
Want to build a low cost stroker...looking for input. atomicmoose Engines & Drivetrain 15 03-08-2007 01:05 PM
