Build Your Own CO2 Tank System High Quality & Lowest Cost - Page 2 - JeepForum.com
 8Likes
post #16 of 154 Old 09-05-2011, 07:17 PM
1911Tyler
1977 CJ5
If anyone wants a better price on tanks. I just ordered a spare at this place for 81$ shipped. Best price I've found yet.
http://www.aquariumplants.com/Alumin...isters_p/t.htm
1911Tyler is offline
post #17 of 154 Old 09-07-2011, 10:54 AM
adamkn
adamkn's Avatar
1911tyler, thanks for sharing the info on the full co2 kit and spare tank. The price for that kit is the best I've seen.
As far as spare tanks, I was able to find a local co2 supplier that sells reconditioned co2 tanks. I got a 15lb tank, full of co2, for $65. Just an FYI for anyone else that may be shopping for a tank - check for local welding and beverage supply shops.
2000 TJ
adamkn is offline
post #18 of 154 Old 09-08-2011, 03:42 AM
1911Tyler
1977 CJ5
Very good idea. And also craigslist. If you don't care about nice shinny bottles I see them all the time on there. Me I want it to look nice so I'm paying extra for that.
post #19 of 154 Old 09-11-2011, 06:38 PM
Jeep_tj_97
Can you guys help me to determine the size of this and if it would be a good deal?
the guy is asking for 30$ but I have no use for the kegs.
aprox dimension the guy told me 24'' high about 8'' wide, he said there a coca-cola sticker if it helps.
Jeep_tj_97 is offline
post #20 of 154 Old 09-18-2011, 05:16 AM
monkers
2010 JK Wrangler
If you get a used tank, who is responsible for the testing? Is it the purchaser, the seller, or the shop that fills it? Just curious, I have come across a couple but didnt want to buy one then get soaked for a expensive test or something. What is the cost of the test? Can the tanks (steel and alum) be painted, if you get a used one you could give it a rattle can spruce up no? This is a great forum, thanks for sharing all the info on this and help everyone save some cash!!
2010 Rescue Green 2 Door 6 Spd, 2.5" RK Max Travel, Fox 2.0 IFP Shocks, 37" Nitto Trail Grappler M/T, EVO Sleeves, Gussets, Mini Skids, Rock Stars, Poly Perf Long Travel Upper Shock Mounts, Poison Spyder Evap Skid, Diff Covers, Grab Handles, Cobra 75WXSt, Stern Cibie/Osram Light Upgrade, Mopar Heated Seats, Trimmed Flares & Bumpers
monkers is offline
post #21 of 154 Old 09-18-2011, 06:23 AM
adamkn
adamkn's Avatar
The testing/inspection only needs to be done once every 5 years. The last test date should be stamped/identified on the tank. So if you're buying a used one, try to find that one that has been tested recently. Otherwise, call the shop you'll use for refills, and hopefully they can let you know the costs for testing.
The shop I bought mine from specializes in reconditioning tanks - they'll install a new valve, do the tests, and repaint the cylinder. Mine is about 25yrs old, but looks good as new to me. So yeah you can repaint if you want.
2000 TJ
adamkn is offline
post #22 of 154 Old 09-21-2011, 07:47 AM
Rubiconcruiser
CO2 tanks
Hydro testing , check with a welding supply shop, if there are none in your area pm me Ill arrange the detais, usually $25.00 includes fill if tank is OK. If you have the other containers PM me as well I need them.
Rubiconcruiser is offline
post #23 of 154 Old 09-21-2011, 07:51 AM
Rubiconcruiser
This is a 20 pound tank, and I want the kegs, where can I get them. PM or phone 912 455 5065/
thanks jim
post #24 of 154 Old 09-21-2011, 08:00 AM
Rubiconcruiser
Prices are good, but you are paying too much for the product CO2. Use a welding supply store, and REMEMBER tanks are EXCHANGED unless you want your own returned after a wait of a week or so.
post #25 of 154 Old 09-21-2011, 08:08 AM
Rubiconcruiser
Hey Monkers YOU are responsible for testing. Its yours be safe check dates stamped on the top of the bottle.
post #26 of 154 Old 09-23-2011, 01:22 AM
jclauson
thought i would share what i did
bartered for a tank on craigslist trading my random crap - free 20lb tank
poly performance regulator HERE - $40
poly performance hose - $14 (seems a little cheap. i would get a different hose)
but fully functional setup for 65 after shipping!
1990 YJ w/ lots of home made sh*t
check it out
http://www.jeepforum.com/forum/f22/hysterias-90-yj-build-1190617/
jclauson is offline
post #27 of 154 Old 09-23-2011, 07:05 AM
adamkn
adamkn's Avatar
Actually that would be $65 plus the value of your "random crap" that you bartered.
I'm curious to see how you have the 20lb tank mounted in your jeep.
For anyone that is not familiar with tank sizes, fyi, a 20lb tank is pretty impractical if you plan to keep it in your jeep. Way too big. Even a 15lb tank is difficult to mount or strap down because of its size and weight (45lb+ when full). I'd take a 20lb tank if it was given to me for free, but id only use it around the house, it would never end up in the jeep.
2000 TJ
adamkn is offline
post #28 of 154 Old 09-23-2011, 09:28 PM
jclauson
I don't run a back seat. I have plenty of room. I'll get a pic tomorrow of my current location. I traded a guy an old external hard drive. Trust me it wasn't worth squat.
check it out
jclauson is offline
post #29 of 154 Old 09-23-2011, 09:46 PM
Philly
I work in the industrial gases industry and used a co2 rig on my old jeep before i sold it to air up after hitting the trails. It is an inexpensive and economical system as opposed to an on-board compressor.
You may hear people hem and haw about how CO2 reacts with water to create carbonic acid which will, over time, degrade rubber or plastic components; but there is a very easy solution: air down at the gas station and fill back up with compressed air after leaving the trail.
ALWAYS store/transport/mount your tank in the vertical position though. The constant contact of CO2 against the poly gasket and regulator will do damage over time. It is a safety precaution, and common sense. No one wants a busted valve stem shooting a tank around in their jeep
Edit: Great post, I often wondered why more people did not utilize this system.
Philly is offline
post #30 of 154 Old 09-26-2011, 11:59 AM
adamkn
adamkn's Avatar
Interesting point about the carbonic acid, I had never heard that before. Given how most of us abuse our tires while off-roading, I suspect that our tire treads will be worn out before we see ANY effects of the carbonic acid.
As far as the last point about keeping the tank vertical, that's certainly a good idea - but I really don't think it's necessary when transporting it occasionally for off-road trips. When transporting, the key is just making sure that it is mounted securely. And making sure the valve is protected. ( I assume everyone knows it must be vertical anytime you use the tank)
2000 TJ
adamkn is offline
Who Makes High Quality Pinion Bearings? ntaousakis Engines & Drivetrain 3 04-18-2008 06:12 AM
What is the average cost to build a rear bumper tire carrier? rescue6 Fabrication Shop 10 04-04-2008 06:50 PM
My idea for a low cost system in my TJ. JeepRocks86 Audio, CB & Ham Radios, GPS, & Electrical 2 12-10-2007 07:37 AM
Want to build a low cost stroker...looking for input. atomicmoose Engines & Drivetrain 15 03-08-2007 01:05 PM
