brush guard, winch, winch mount compatibility - JeepForum.com
post #1 of 7 Old 07-20-2007, 10:12 AM Thread Starter
Longspoon
ok so I'm looking at this
http://www.4wd.com/productdetails.as...=0&partID=6129
it says it's for a 98-06 but says it is used with this
http://www.4wd.com/productdetails.aspx?pid=37170
which of course is for 97-04. The comparable part for an 06 appears to be
http://www.4wd.com/productdetails.as...=0&partID=6167
Which is the same model number, though different part number, of the winch plate that the original brush guard is incompatible with. The part number listed as incompatible appears to be the version made for YJ's and not TJ's so I'm guessing that the 06 version of that model number may work...
So the two questions are, which mounting plate would fit that brush guard, and will both those pieces (brush guard and mounting plate) fit with the superwinch epi9.0 that I have decided to go with?
confused yet?
Join these groups...
"I'm not a Republican because I grew up rich, but because I didn't want to spend
the rest of my life poor, waiting for the government to rescue me." MH
The less a man makes declarative statements, the less apt he is to look foolish in retrospect. - CR
Finally, a word to those of you out there who have yet to be offended by something I have written or said: Please be patient. I am working as fast as I can. - AC
Longspoon is offline
post #2 of 7 Old 07-22-2007, 03:24 PM
Crashnburn80
Crashnburn80's Avatar
Wow you made that confusing.
OK. First off, that brush guard you are looking at is 50% off at quadratec right now: http://www.quadratec.com/products/12115_00_07.htm
2nd, you do not have an 8274 winch, so you do not want the 8274 winch plate, that only fits that one specific upright winch.
You want the Planetary winch mount, I'm not sure why 4wd lists that plate as only being good up to 04, but it should work on a TJ up to the final year of 06. I confirmed it on quadratec's website as well, and they list it as being good for 98-06.
| 1.25" BL |
| Riddler diff covers |
| 33" MTRs | Warn M8000 |
and much more...
Crashnburn80 is offline
post #3 of 7 Old 07-23-2007, 07:21 AM Thread Starter
Longspoon
dude thanks so much for that, it'll save me a bundle (both of money and headache from the little woman )
sorry it got real confusing, thanks for clearing it all up for me...
post #4 of 7 Old 07-24-2007, 11:09 PM
XabuJr
XabuJr's Avatar
1992 XJ Cherokee
Don't buy that brush guard. It mounts to the Warn winch plate. So if you're going to get anything other than the Warn it will not work. They used to have one that mounted to the bolts on the bumper, but apparently good luck in finding that one.
edit: I guess I should check all the links first. haha as long as the warn plate you buy has the two holes in it, then you're good. The Warn one I picked up (it was like the 2000 model) didn't have those two holes, so no guard for me..
XabuJr is offline
post #5 of 7 Old 07-25-2007, 06:26 AM Thread Starter
Longspoon
Yea now that I'm noticing that it REQUIRES the warn winch plate I'm not so sure... I'm also not really sure why I got so hung up on which winch plate to begin with. I'm not dead set on the Warn plates, ultimately I just liked the way that guard looked.
If I were to get another brand of mount do you think it would be a major hassle to drill holes in it to fit that guard?
post #6 of 7 Old 07-25-2007, 10:48 AM
XabuJr
XabuJr's Avatar
1992 XJ Cherokee
Probably not, depending on the style of plate. I will see if I can get you a pic of my warn plate and maybe photoshop it so you can see how the new ones are, unless someone posts a pic of one of their new ones..
XabuJr is offline
post #7 of 7 Old 07-25-2007, 12:48 PM
Skeezer
Go to Nate's 4x4
2005 Rubicon
Skeezer is offline
Front bumper, Grille Guard, & Winch Plate Hobojo General Jeep & Off-Road Equipment 2 10-13-2009 12:47 PM
Please advise on winch,plate and grill guard on stock bumper!! jeep2008 General Jeep & Off-Road Equipment 10 06-17-2009 06:16 AM
HF Winch mount for wranglers and HF winch accessory kit jeeptorino68 General Jeep & Off-Road Equipment 2 03-16-2009 06:55 AM
Winch controller compatibility RussoGuitar General Jeep & Off-Road Equipment 0 11-14-2008 10:30 PM
Brush and belly guard with winch ZJPunk98 General Jeep & Off-Road Equipment 2 12-10-2005 12:26 PM
