Brakes lines - JeepForum.com
post #1 of 3 Old 04-15-2013, 08:32 AM Thread Starter
olewilly
1989 MJ Comanche
Brakes lines
I'm about to change brake lines in my MJ. Is it an easy job? Any tips on that or bleeding the brakes?
olewilly is offline
post #2 of 3 Old 04-15-2013, 04:19 PM
GilaMtnJeep
GilaMtnJeep's Avatar
First, get a set of "flair fitting" wrenches. Regular open end wrenches can spread and round off the fittings.
Second, get plenty of DOT 3 or DOT 4 fluid, whichever you Jeep specifies. Start with the wheel closest to the master and bleed them until clean fluid comes out.
And third, don't let the master cylinder run out of fluid. A master can be a PITA to bleed.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #3 of 3 Old 04-15-2013, 05:07 PM Thread Starter
olewilly
1989 MJ Comanche
Yea, I went on and tried it, I got line wretches but they only rounded it off. Maybe cause they were 12 point. Which I thought was stupid, but finally got it off with 2 vise grips without stripping it too bad. Bleed the brakes and on my way! Haha
olewilly is offline
