Brake bleeding question - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > Brake bleeding question
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineToxic Brakes - 3000 PSI Braided Stainless Steel Brake LineCess Recovery Gear Snatch Tow Strap OffRoad @ ROCKRIDGE4WD
Unread 07-13-2013, 02:34 PM   #1
4wdjeepguy
Ok so this may be a dumb question but should the reservoir fill cap be on or left off when bleeding brakes?
4wdjeepguy is offline   Reply With Quote
Unread 07-13-2013, 04:00 PM   #2
TSEJEEPERS
I put it on.
Less mess, but I do not think it matters.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list. www.mijc.org
TSEJEEPERS is offline   Reply With Quote
Unread 07-13-2013, 05:06 PM   #3
4wdjeepguy
Just wondering if it would create a vacuum in the resi to leave it on
Unread 07-13-2013, 08:43 PM   #4
rjbruzan
No vacuum as it is vented.
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline   Reply With Quote
