Bought a Superwinch EPi9.0S!!! - JeepForum.com
post #1 of 24 Old 06-30-2009, 02:56 PM Thread Starter
Hampster
I took the plunge and spent the extra bucks to get the EPi9.0S with the synthetic rope from the factory. Paid $756.72 delivered to my door...it's probably gonna take a few weeks to get here, but I am excited. It'd be nice if for some miraculous reason it showed up Friday so I can have it mounted for this weekend....
01' WJ Limited - Quadradrive, V8, Daily Driver, 149k
Hampster is offline
post #2 of 24 Old 06-30-2009, 03:30 PM
IslandTJ
Good winch, but heavy...
At least with the syn rope, you'll lighten it some...
Now Jeeping in Oregon
IslandTJ is offline
post #3 of 24 Old 06-30-2009, 03:37 PM Thread Starter
Hampster
says it's 69 lbs installed....just out of curiousty does the synthetic rope come already installed on the drum???
Hampster is offline
post #4 of 24 Old 06-30-2009, 03:39 PM
RubiExpressTJ
1987 YJ Wrangler
I have the first generation EPi9.0 and it's a very tough reliable winch. Good choice.
- Luke
RubiExpressTJ is offline
post #5 of 24 Old 06-30-2009, 04:38 PM
IslandTJ
It should - just like the wire rope.
IslandTJ is offline
post #6 of 24 Old 07-01-2009, 10:20 PM
MayRoll
The 80' of synthetic line does not come on the drum. You'll need to install it. Make sure you wind the line under tension before it's first pull.
MayRoll is offline
post #7 of 24 Old 07-06-2009, 02:00 PM Thread Starter
Hampster
UPS is bringing the winch today...will write my review when I get it installed
Hampster is offline
post #8 of 24 Old 07-06-2009, 04:24 PM
19OlllllllO41
19OlllllllO41's Avatar
Mine didnt, came in a plastic bag. You need to spool it yourself.
The Present:
'05 TJ Rubicon (Electric Lime Green)
'04 WJ
'46 CJ2A
The Past:
'83 CJ7, '92 YJ, '00 XJ, '99 TJ, '05 TJ Rubicon (Impact Orange)
19OlllllllO41 is offline
post #9 of 24 Old 07-06-2009, 09:24 PM
chadsmeltzer
chadsmeltzer's Avatar
Actually, with synthetic rope you don't need to do that.
I have the same winch and love it, it blows away my old MileMarker. I just wish I had more winchline (and could afford more winchline).
04 TJ - 2 KC Daylighters, 35x12.5x15 MT/R Kevlar, 3" coils, Rear 4 link, 1.25" JKS BL, 1" JKS BMML, 33 Eng. Hi-Clearance Skid, 8.8 with LS, D30 EZ locker, OBA
chadsmeltzer is offline
post #10 of 24 Old 07-07-2009, 12:55 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Not sure where you're getting that from, but you most assuredly need to tension the synthetic before the first pull. If for no other reason than to pack the wraps so an upper layer pull doesn't sink all the way down the drum. It's not that bad for the line, but makes it a real bear to spool out for the next pull.
We've gotten some of them stuck so back we had to use another rig to pull out the line.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #11 of 24 Old 07-07-2009, 08:55 AM
chadsmeltzer
It was in the instructions that came with my winch, I will look for it when I get home.
post #12 of 24 Old 07-07-2009, 09:52 AM Thread Starter
Hampster
I can solve this^^^. UPS brought my EPi9.0S last night...in reading directions, Superwinch suggests spooling the line under tension of winching another vehicle on a level surface. My directions were packaged inside the plastic bag with the Viking winch line.
Hampster is offline
post #13 of 24 Old 07-07-2009, 01:24 PM Thread Starter
Hampster
mounting update.
to the subject of winch plates being compatiable with the EPi9.0: I have the Rough Country winch plate. It protrudes over the front bumper a few inches. So far the bolts intended to mount the aluminum fairlead to the plate are too large for the holes on the plate side...I'll either have to drill out the holes on the plate to widen them or just get slightly smaller bolts to fit through....I mocked up the fairlead using 2 of the 4 bolts intended to mount the winch to the down side of the plate, which seemed to work. Maybe I'll drop by Lowes and match'em up tonight.
Also regarding the plate and the standard 10" x 4.5" standard bolt pattern: On my YJ I have a stock bumper. The back 2 bolts sit behind the bumper and the front 2 sit just ahead of the bumper so that when I mount the winch up it looks as if the bottoms of the front 2 bolts will be slightly in contact with the front edge of the stock bumper. If it doesn't squeeze in there, it looks like I'll have to use a cutting wheel to notch my front bumper in 2spots. The saga continues...
Hampster is offline
post #14 of 24 Old 07-07-2009, 01:56 PM
jbramble24
I also have the EPi 9.0 mounted on the rough country plate. If you do drill out the holes for mounting the fairlead, you may have to grind down the heads of the bolts in order to keep them from contacting the front of the winch. I opted to go with slightly smaller bolts, mounted the fairlead first (before mounting the winch to the plate), ran the bolts through from back to front (nuts on the outside/front of the fairlead) and ended up with about 1/16" clearance between the winch and fairlead bolts.
GM 350 Powered 1984 CJ-7
jbramble24 is offline
post #15 of 24 Old 07-07-2009, 02:23 PM Thread Starter
Hampster
^^this sounds like a good idea...do the bolts that hold the fairlead in place need to be Grade 8? All the bolts that came in my shipment say 8.8...but they DO NOT have the 6 lines indicating grade 8...which has me concerned
Hampster is offline
Superwinch EPi9.0 Installed SuperWade2 General Jeep & Off-Road Equipment 18 11-03-2011 12:49 PM
Superwinch EP9.0 and EPi9.0. What's the difference? joeroe General Jeep & Off-Road Equipment 13 12-24-2009 04:04 PM
new superwinch not working! epi9.0 humbertotrevino General Jeep & Off-Road Equipment 12 09-04-2008 09:49 AM
Superwinch EPi9.0 or Warn 9.5ti Prot General Jeep & Off-Road Equipment 8 10-22-2007 03:22 PM
Superwinch EPi9.0 SuperWade2 General Jeep & Off-Road Equipment 20 05-17-2007 09:57 PM
