Body lift - JeepForum.com
post #1 of 9 Old 05-21-2013, 03:32 PM Thread Starter
jeepingforlife
Body lift
I have a '05 TJ wrangler. I have a 4" suspension and 34's on it. I would like to lift it a little more but I just got. New suspension lift. I'm thinking body. What is the biggest body lift you would suggest? I heard that once you get to 3, longer break lines an a radiator drop is necessary. Any suggestions?
jeepingforlife is offline
post #2 of 9 Old 05-21-2013, 08:29 PM
Filthy-Beast
Anything over 1.25" just looks wrong combine with 1" motor mount lift and a tummy tuck.
Here is 3" springs, 1.25" BL, 1" MML and tummy tuck.
For Sale:
97 TJ: daughter 1 - 2.5L, Auto, 2" BB, 31" GY Duratrac
98 TJ: Daugher 2 - 4.0L, 5spd, D44 rear
06 LJ Rubicon: mine - Rokmen full up-armor, 8 adjustable CAs, front bumper, sliders, corners, Shrockworks rear bumper, 3" AEV/BDS lift, Currie HD stearing and Antirock, MT/r - k 35x12.5, SuperWinch, MC Overlines, York OBA
13 JKU Rubicon: Wife's for now, Ace Rock rails & rear bumper tire carrier, Truck Lites, MC Game changer 3.5 lift, RR skids, PSC Brawler front bumper, Warn 9.5cti-s, 35" GY MTRs
Filthy-Beast is offline
post #3 of 9 Old 05-22-2013, 05:50 AM
tyvanwie
Why do you want to lift it more?
That setup is fine.
Sent from my iForum using JeepPhone
tyvanwie is offline
post #4 of 9 Old 05-22-2013, 09:21 PM
karlo
Most people go with 1.25" as maximum body lift. A 3" body lift is unsafe. Also, you will find it difficult to install properly.
karlo is offline
post #5 of 9 Old 05-22-2013, 11:59 PM Thread Starter
jeepingforlife
Why is 3" hard to install?
post #6 of 9 Old 05-23-2013, 03:56 AM
karlo
Because installing a 3" body lift needs a lot of work like you need a longer fuel lines between the tank and filler, remount the transfer case lever, etc.
karlo is offline
post #7 of 9 Old 05-23-2013, 04:01 AM
tyvanwie
Why do you want a 3" body lift
tyvanwie is offline
post #8 of 9 Old 06-07-2013, 04:46 PM
ninja186
Because that's the way to go. 3 inch body lift will let her clear mas grande tires and look really cool as she trolls the mall with 39 inch boggers.
There is absolutely NO reason for a 3 inch body lift. Especially on a Jeep.
ninja186 is offline
post #9 of 9 Old 06-08-2013, 12:19 PM
YoungGun
Here is what is needed to do a 3" body lift:
Extend rubber filler hoses from gas cap to tank
Extend/ remount transfer case shifter
Extend transmission shifter
Lower radiator
Remount / extend steering shaft.
Depending on how much slop you have in the brake lines they might need replaced with slightly longer ones.
All is doable. I did it for a while until I lowered it to 1.25" which I was happier with. I think the 3" shows too much frame. And drivetrain under the body. And it feels more top heavy when I run it.
There is no "I" in jeep. Just a lot of money.
YoungGun is offline
