Bl's safe? - JeepForum.com
post #1 of 21 Old 10-22-2006, 04:49 PM Thread Starter
eclipse27
Bl's safe?
Well i was informed in a previous thread that i didn't know what i was talking about. I'll totally admit if i was wrong. But i could of sworn someone told me any body lift over an inch was NOt safe. I'd consider getting one if there safe.
eclipse27 is offline
post #2 of 21 Old 10-22-2006, 04:51 PM
frumpy
frumpy's Avatar
absolutly safe. I would stay with 1"-1.25" and 2" MAX. Some people will argue anything above 2" is unsafe but theres no real proof (to my knowledge) that they are, well other than looking fugly.
2002 Dodge Dakota quad cab V8
2011 Dodge Grand Caravan
frumpy is offline
post #3 of 21 Old 10-22-2006, 04:58 PM Thread Starter
eclipse27
K i stand corrected...however do thedy mess things up?
post #4 of 21 Old 10-22-2006, 05:00 PM
Erik T.
Erik T.'s Avatar
Rumor has it that they'll break in a wreck and send your body soaring off your chasis and you'll burst into a ball of flames blah blah blah.
They're safe.
It's just anything over an 1.25" is fugly as can be.
-Erik.
Hack work? :rofl: You just described half the modified jeeps on this board.
Erik T. is offline
post #5 of 21 Old 10-22-2006, 05:04 PM
BlueJ
I would like to see that, would be interesting!
I saw a Dakota the other day with at least a 3 inch BL, looked completely rediculous. But hey, his bumper was still at the right height! LOL
1998 XJ Up Country - "The Green Chili"
BlueJ is offline
post #6 of 21 Old 10-22-2006, 05:57 PM
KaiserJeep
I don't subscribe to the "unsafe" thing myself. However there are plenty of collision photos on the Web that show damaged body tubs after Jeeps with 2" or larger BL's experience an accident that is otherwise not so serious. The leverage of the longer lift pucks distorts the body sheet metal above the puck, and more broken bolts are typical, but I have not actually seen a body tub bust loose. Worst case is just enough damge to increase the repair cost significantly. Add to this the poor appearance and the many many other changes that should accompany a larger BL, and I just would stay away from a 2" or larger BL.
Gary
1967 Kaiser Commando
2001 Grand Cherokee WJ
2003 Wrangler Rubicon TJ
KaiserJeep is offline
post #7 of 21 Old 10-22-2006, 06:02 PM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
i dont think they're unsafe so much, just look like crap. there is alot to be gained from a 1" or 1.25" body lift, but after that it gets a little sketchy.
also, as for messing things up....you'll need a motor mount lift, you'll have to extend transfer case linkages, you wont be able to shift right anymore i dont think, etc etc etc.
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #8 of 21 Old 10-23-2006, 06:45 PM
tn.jeep
I have a 2 inch and it is safe.
2000 TJ Juggy, Streched to 112", 42's, 60 and a 14 bolt
tn.jeep is offline
post #9 of 21 Old 10-23-2006, 06:47 PM
Rocky529
Rocky529's Avatar
You don't need a motor mount lift with a body lift. The t-case linkage does have to be adjusted either way however. It's best just go get an AA re-location bracket.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #10 of 21 Old 10-23-2006, 06:53 PM
McLovin
It always amazes me how much misinformation is floating around the internet. People should quantify their expereinces and not repeat what some else is reapted to you. Like I said before I used the supplied bracket to move the x-fer linkage down a couple of inches and that was it. My rig shifts fine I didnt need to extend anything and bla bla bla....
You dont have to have a motor mount lift with abody lift This to amazes me. People are more afraid to mess with a fan shroud then they are of moving there motor up
McLovin is offline
post #11 of 21 Old 10-23-2006, 06:55 PM
Rocky529
Rocky529's Avatar
Mostly correct, but every Jeep is different. The t-case linkage binding up is usually a given with a body lift, but the actual shifter may bind in 2nd, 4th, and reverse... or it may even hit the console. Either an adjustment to the shift boot or a bend in the shifter is usually the cure for that problem.
Rocky529 is offline
post #12 of 21 Old 10-23-2006, 07:02 PM
river rat
Forum porn star...I guess
river rat's Avatar
You guys make me laugh
97 TJ. Full width D60 w/Detroit, Alloys and 5.89 gears. Full width D44 spooled, 60 outers, Warn lockouts. 6" Rock Krawler Gen II LA. 11 gallon cell behind the rear seat. 37" Maxxis Trepador competitions on 17" Stazworks double internals, blazay, blazay.....
river rat is offline
post #13 of 21 Old 10-23-2006, 07:06 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
i have a 2" BL and and a car over (literally at 25 mph) and had no problems, i didnt need a MML or T?C linkage
RnEmOvr is offline
post #14 of 21 Old 10-23-2006, 07:10 PM
JFiorentino
JFiorentino's Avatar
I have a 2" body lift, plus 3.5 Superflex and 3/4" spacers.. I don't think it looks too bad, plus I added a filler panel in the rear to cover the spacers. What do you guys think?
John
"When approaching a four-way stop, the vehicle with the largest tires always has the right of way"
2004 TJ, Auto w/ OD, 4.0L, Off-Road 36x13.5 Super Swamper IROK's on MT Classic II Rims, SYE, CV Driveshaft, 4:56 Gears, ARB Locker, 3.5" RE Superflex, 2" Body Lift, JKS Quicker Disco's, 9,000# Winch, Toys-by-Troy step-sliders, The Source OBA. And lots more....
JFiorentino is offline
post #15 of 21 Old 10-23-2006, 07:22 PM
Brown Dog
Vendor
Brown Dog's Avatar
I have a 2". When I installed it I replaced all of the bolts with new, grade 8 bolts. But...I do that with almost any mod.
Brown Dog Offroad
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% HANDCRAFTED IN AMERICA
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
4.5" Superlift SL
AA SYE
35" GoodYear Mud Terrains
Conteract Balancing Beads
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline
Safe Transmission WAMPAROO Audio, CB & Ham Radios, GPS, & Electrical 1 02-09-2006 07:54 PM
how BL's help drive line Rubie Tuesday Tires & Wheels 3 03-10-2005 09:00 AM
Be Safe!!! GrimJeeper91 General Jeep & Off-Road Equipment 29 06-14-2004 02:38 PM
Mud and Water safe? OwnAccord General Jeep & Off-Road Equipment 3 04-11-2004 09:24 PM
How did you make YOUR cb safe? Killer Angel Audio, CB & Ham Radios, GPS, & Electrical 6 02-18-2004 01:46 AM
