Best things to have in your toolbox for under $25? - JeepForum.com
post #1 of 12 Old 08-31-2013, 05:28 PM Thread Starter
redhatman
redhatman's Avatar
Hey everyone, I'm curious what tools and accessories everyone has that they have found to be worth having handy. What things under $25 do you own or use that you're glad to have?
-Tire Gauge
-Tire Deflators
-Mini Flashlight
-Pat
I am now a dealer for Iron Rock Off Road
I offer the same great products you already know about,
the same low prices you have been seeing, and with
the same experienced customer support, but I can offer it nearly 24/7
5.9 ZJ 7" IRO, 35s, 8.8, hp30, locked, blah blah
Originally Posted by CMARJEEP View Post
Those tires look freakin awesome Redhat... took the ZJ up a notch in my book. Now you're at notch 2.
redhatman is offline
post #2 of 12 Old 09-01-2013, 06:27 PM
ROWA
Band Aid...
94 YJ Sahara
The best Engineering is no match against natural Stupidity.
ROWA is offline
post #3 of 12 Old 09-01-2013, 10:46 PM
GilaMtnJeep
GilaMtnJeep's Avatar
Duct tape
BFH
Zip ties
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #4 of 12 Old 09-02-2013, 12:40 AM
ancientspear
Valve stem tool. Can be used to deflate as well as fix a loose stem on buddies rig. A friend saved my hide one day by lending me his.
Anyone ever use that putty stuff for patching leaks and whatnot?
ancientspear is offline
post #5 of 12 Old 09-02-2013, 03:19 AM
bondosgto
Baling wire, first aid kit, beer, hose clamps, ratchet straps, pb blaster, map torch.
bondosgto is offline
post #6 of 12 Old 09-02-2013, 06:58 AM
wilson1010
Multimeter, battery cables and welding rods.
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline
post #7 of 12 Old 09-06-2013, 01:42 PM
IslandTJ
Rescue tape
Epoxy putty
Bale wire
Now Jeeping in Oregon
IslandTJ is offline
post #8 of 12 Old 09-07-2013, 09:28 AM
Greenfun2
Greenfun2 is offline
post #9 of 12 Old 09-07-2013, 09:49 AM
olliehopnoodle
1982 FSJ Cherokee
D44 socket, small pick set and snap ring pliers.
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline
post #10 of 12 Old 09-07-2013, 09:55 PM
WSS
WSS's Avatar
1972 CJ5
RESCUE tape as mentioned already, awesome stuff
!4" to 18" boltcutters from HF
Inverted flare tool and sleeves
Hack saw w/ a few blades
pipe wrench or one of these:
http://www.irwin.com/tools/pipe-wren...ng-pipe-wrench
WSS is offline
post #11 of 12 Old 09-08-2013, 09:00 AM
wilson1010
I am embarrassed to admitting to owning a $14 right angle die grinder (Harbor Freight), but I carry this with metal cut off wheels and power it by on board CO2 tank with 150psi regulator. You can cut a crushed tailpipe off that's for sure.
post #12 of 12 Old 09-10-2013, 06:55 AM
Davetopay
BFH/ ball peen
Breaker bar
36mm socket
Hose clamps
4x4x12 block of wood
Philips and flat screwdriver
Large c-clamp
Duct/hose/electrical tape
Zip ties galore
Davetopay is offline
