Best lift for a good price. - JeepForum.com
post #1 of 5 Old 08-23-2013, 11:11 PM Thread Starter
Jordan27
I am wanting to do a 2.5inch lift on my 2008 Jeep Wrangler unlimited. I don't want to go any bigger then that for fuel mileage concerns. Can someone recommend a good lift?
2008 Jeep Wrangler Sahara Hard top Stock .... So far...
Jordan27 is offline
post #2 of 5 Old 08-24-2013, 09:27 AM
Davetopay
The first question you need to answer is , what do you want it to do?
Davetopay is offline
post #3 of 5 Old 08-24-2013, 09:55 AM Thread Starter
Jordan27
Pretty much stock but higher. I don't want to go too crazy as it is my daily driver that is why I only want to do 2.5 inch or 3. I don't get too crazy off road but a little more clearance in Moab would be great.
Jordan27 is offline
post #4 of 5 Old 08-28-2013, 06:28 AM
Ross
The size of the lift won't cause you MPG to drop, the size of the tires will.
If money is a concern do a 2 inch budget boost and if still want more lift add a 1" body lift. If you want it to do better off-road get some sway bar disconnects.
I have known a few people running this type of setup with 33's and thing worked just fine.
If in the future you decide you need/want to go bigger or better you won't have much money invested. The 1" body lift is a good mod for any Wrangler, built big or small.
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is online now
post #5 of 5 Old 08-28-2013, 09:00 AM
SLADE
Start with a good set of coils that fit your needs.
You can add a small 1" 1.25" body lift or a small coil spacer later if it's needed.
It's cheaper to start with a coil you can build off of than it is to start over from scratch when you need to fine tune or your wants/needs change.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
