Been given a winch.... but it has a catch... - JeepForum.com
post #1 of 3 Old 03-16-2011, 01:25 AM Thread Starter
ctm9191
1989 MJ Comanche
Sunday i was given a Ramsey 6000 winch... or so my stepdad called it that, it has good gears and frame..... NO MOTOR, so what have is the frame and no cable/motor/way to keep the cable in check once i order one... online i have found i need a motor with the part number 458109... and i plan on calling ramsey when they open tomorrow to see if i can order a motor from them.
I have no idea the age of the winch but if anyone can give me an idea of how it might do once i can find a motor it would be much appriciated
He did tell me if i run out a "100 feet of cable only use the winch for about 20 feet at a time" he said it gets a small motor that gets hot.
but if you guys know where to order one from other than ramsey i would love the help because ive been trolling the interweb for about a hour and cant find one site with the correct replacement motor
ctm9191 is offline
post #2 of 3 Old 03-16-2011, 03:06 AM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
That's a nice size for a portable winch or hitch receiver setup because any larger gets pretty heavy to lug around. 6k may be a little smaller than I'd pick for bumper mount if I was buying new, but still big enough to help out in a lot of instances. You can help it out by using a snatch block to double back the cable on harder pulls. The more line off the spool, the lower the effective gearing ratio will be. Also, doubling back the line will double the pulling power since the line will be pulling 6k worth on each half or direction, for a total of 12k.
A 25% duty cycle rating is common for electric winches, meaning that ideal usage under heavy load is to pull for one minute and then rest it for three to allow cooling.
I see a lot of winch motors go on ebay but have never paid much attention to the smaller ones.
***Chris***
chris87xj is online now
post #3 of 3 Old 03-16-2011, 04:15 AM Thread Starter
ctm9191
1989 MJ Comanche
the pull one rest three min will come in handy one day im sure, thank you for that. yea i was wanting to get 8,000lb pull but... all i have to pay for on this winch is the motor/fairlead/cable... from what iv seen ill be spending about 200-250 depending on where i order from... way better in my book than spending what it cost for a new winch
I LOVE FREEBIES
ctm9191 is offline
winch
Rugged Ridge 8500lbs winch or Smittybily 8000lb winch HighRoller02TJ General Jeep & Off-Road Equipment 5 05-20-2010 01:45 PM
Ready to Catch the Bug! awsten84 Tires & Wheels 3 04-21-2010 12:08 PM
Which winch plate is flat to frame and will hold my winch close to grill? CB3 General Jeep & Off-Road Equipment 5 02-23-2010 09:23 PM
catch/thud/something in tcase whitie_08 Engines & Drivetrain 0 03-21-2009 08:58 AM
Anyone in WA catch the Swap Meet Today? johnniebravo General Jeep & Off-Road Equipment 2 03-14-2003 09:58 PM
