Beating me to death shocks - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > Beating me to death shocks
Zone Offroad - Jeep Forum PromotionFS: Wranger BRIGHT License Plate LED! Just $3! Great valueFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 05-03-2015, 10:00 AM   #1
rickamoss
1991 Jeep YJ 4.0 31 x 10.50's - virtually all stock. I recently (12-18 months) replaced all my shocks with an inexpensive set of Monroe Gas from Autozone - the red ones, and the jeep is just nuts, a speed bump at 5 mph will actually go airborne. I need to soften these shocks (No adjustments on them) or replace with a softer, but inexpensive (Okay cheap!) that will work for a very mild wheeler, trails only - virtually no rock but some mud. This the wifes rig and she's got a bad back and this things not helping. Thanks for reading and hopefully solving my problem.
rickamoss is offline   Reply With Quote Quick reply to this message
Unread 05-03-2015, 10:58 AM   #2
Jerry Bransford
Administrator
Jerry Bransford's Avatar
While that could be from those Monroe gas shocks, and gas shocks are generally stiffer, the overly stiff ride could also be in part from the air pressure in your tires. Exactly what tire and tire size are you running, and exactly what air pressure are you running in them? Most tire shocks significantly overinflate tires and some overinflate their tires by unknowingly inflating them to the air pressure molded onto the sidewall which only the tire's maximum safe air pressure... which is never the correct pressure to actually run them at.
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is online now   Reply With Quote Quick reply to this message
Unread 05-05-2015, 07:54 AM   #3
rickamoss
We are running uniroyal 31X10.5 and between 38 and 42 psi max is 50 psi. I've tried as low as 20 psi and she'll wallow over the speed bumps but you'll still find out how low the soft top and roll bar are.
Unread 05-05-2015, 08:37 AM   #4
Jerry Bransford
Administrator
38-42 is WAY too high for a 31" tire supporting a vehicle with the weight of a Wrangler. 30-32 is about right for a 31" tire.
You still may have overly stiff shock absorbers but I'd stop running 38-42 psi. Pay no attention to the 50 psi on the sidewall, that is only the tire's max safe pressure.
Getting Savvy...
Unread 05-05-2015, 09:15 AM   #5
Morris4x4Center
Vendor
Morris4x4Center's Avatar
1987 YJ Wrangler
If any of this helps,
New shocks won't be as weak as old worn out shocks. So that can cause you to sense a difference right away.
I don't think I've ever seen a red Monroe shock, so I'm not familiar with that type.
But if you can collapse the shock by hand off the Jeep, that's a weak twin tube design. Can't get much softer valving than that usually.
Shock companies don't share valving specs, so the only way to know a shock is valved EXACTLY like an old factory shock is to use the same OE shock.
At least that way you know what you are getting beforehand.
(Ignore that a shock is gas charged, that has nothing to do with the internal valving or how stiff it's valved.)
As Jerry says, changing tire pressure is usually the best place to start (it's free to do :-) but it sounds like you tried that already.
Morris4x4Center.com
Toll Free: 877.553.5337 | Free Shipping on Orders Over $99!|
PM us for any questions.
Morris4x4Center is online now   Reply With Quote Quick reply to this message
Unread 05-06-2015, 09:36 AM   #6
rickamoss
My mistake - they're Gabriel, and you're right I've tried lower air pressure. The old shocks I replaced were shot, to say the least, but the ride was magnitudes better.
Unread 05-06-2015, 07:33 PM   #7
Attwanl
When you say "virtually stock" does that mean nothing other shocks and tires? I only ask because when I got my jeep it had lift shackles on it. I replaced with stock length, made a big mistake and over tightened them. It rode bone jarringly rough, if I hit the smallest bump in a turn it felt like it skipped. I figured it was the nature of the beast so to speak, until I found out here that it causes it not flex... Made all the difference in the world when I loosed them up.
Just a thought
What happened?
Attwanl is offline   Reply With Quote Quick reply to this message
