axle flip? - JeepForum.com
post #1 of 4 Old 05-08-2013, 03:30 PM Thread Starter
vgmp53
1981 FSJ Cherokee
axle flip?
I was wondering if anyone had any information on flipping the axles on a 1982 amc Cherokee the axles are on the top of the leafs and I was wondering how I could go about mounting them on the bottom of the leags any information will help thanks and god bless
vgmp53 is offline
post #2 of 4 Old 05-08-2013, 07:09 PM
tjcj
Search spring over axle swap on the web and you should find all the info you need
Sent from my XT881 freezeray gun using JeepForum
Yakima Valley Mountaineers.
tjcj is offline
post #3 of 4 Old 05-08-2013, 08:19 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
basically you need new spring perches welded on the axle, new u-bolts and most likely u bolt plates, longer brake lines just to name the basics. will net probably around 5" of lift or so. Lots of info can be found with a little searching.
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #4 of 4 Old 05-08-2013, 09:53 PM Thread Starter
vgmp53
1981 FSJ Cherokee
Thanks for the replies ill do some research and post some oics
vgmp53 is offline
