Axe,Shovel, etc - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > Axe,Shovel, etc
Alloy usa heavy duty ball joint kitsNEW!! HMF 50"-52" light bar mounting brackets!! ZONE 4.25" combo lift for TJ available at Rockridge4w
Unread 11-18-2014, 11:34 AM   #1
jeepdewey6th
Axe,Shovel, etc
I'm trying to find something I can mount to my jeep inside to hold axes and shoves, along those lines. Something like in this photo,
jeepdewey6th is offline   Reply With Quote Quick reply to this message
Unread 11-18-2014, 11:37 AM   #2
jeepinhokie
jeepinhokie's Avatar
look up quick fists.
http://www.quickfistclamps.com/
HOKIES UNITED!
A Hokie build
check out my jeepin videos!
jeepinhokie is offline   Reply With Quote Quick reply to this message
Unread 11-18-2014, 11:44 AM   #3
jeepdewey6th
Thank you so much that's perfect
Unread 11-18-2014, 12:19 PM   #4
JIMBOX
Yeah, perfect on the inside/tailgate-
If you have a headon collision--the ax will cut somebodies head off and the shovel will begin digging the grave !
Notta good idea !
JIMBO
Yellow Jeep No. 683
http://i294.photobucket.com/albums/m...10-snow027.jpg
--YA GOTTA HAVE CLASS--
JIMBOX is online now   Reply With Quote Quick reply to this message
Unread 11-18-2014, 12:43 PM   #5
jeepdewey6th
That's actually why I'm doing it I'm making my keep a zombie proof looking jeep
Unread 11-19-2014, 02:29 PM   #6
rocks4x4
You can always do it the way I mounted mine. You only need 4 u-bolts.
Mount the axe on one on your side rear roll bar and the shovel on the other.
The u-bolts will go over the tools and the roll bar padding.
It is very secure and should not go anywhere in the event of a accident.
Defender of Freedom
Thank a Veteran for your Freedom
Live Hard, Play Hard
rocks4x4 is offline   Reply With Quote Quick reply to this message
Unread 11-21-2014, 01:09 PM   #7
TJDaveX
Motorized Toy Collector
TJDaveX's Avatar
U bolts are great if you want to display your tools.
But, when you need them, you want them now.
My Quick Fist clamps have been working great for years while off road.
For everyday driving the shovel and ax are safe in the garage..where they belong.
TJDaveX is offline   Reply With Quote Quick reply to this message
Unread 11-21-2014, 11:26 PM   #8
jeepdewey6th
What do you mean u bolts, I want it inside my jeep like the back cargo area
Unread 11-22-2014, 12:53 AM   #9
TJDaveX
TJDaveX's Avatar
Sounds like he uses u bolts around the rear cage of his JK to attach his tools.
Wouldn't work for you unless you have added a cage in your WJ.
Unread 11-22-2014, 12:30 PM   #10
jeepdewey6th
**** wouldn't work I want to put them either on the side of my back cargo area or my back door but I don't want to open the door and the Axe to fall and cut me or someone else
