"Aussie lockers suck because I broke a u-joint" - JeepForum.com
post #1 of 8 Old 07-15-2010, 08:01 AM Thread Starter
-ExDementia-
1991 XJ Cherokee
http://www.jeepreviews.com/jeep-part...ocker-reviews/
Aussie locker max tires?
Date: Jan 15, 2010
Reviewer: A JeepReviews.com User from (Netherlands)
I bought mine a few months ago, I live in the Netherlands and we were out in the woods with some mud and water pits. I have a cj7 4.2 with stock dana 30 and amc20 in the back, the Aussie locker was installed in the front. I had 35 inch BFgoodrich muds and I tried to get out of a little mud pit, very slowly I drove my left wheel against the wall and tried to get out, then I heard a snap and my u-joint broke! A few weeks later again (now the other side) again my u-joint broke off. I've de-installed 35 inch tires because I think that Aussie - 35 inch are a bad combination.
Oh man I'll be sure to stay away from Aussie then! I'll go with a Detroit or anything else but not an Aussie!
Hilarious
"The very existence of flamethrowers proves that some time, somewhere, someone said to themselves, 'You know, I want to set those people over there on fire, but I'm just not close enough to get the job done.'" - George Carlin
Click
for the elusive search button everyone talks about.
-ExDementia- is offline
post #2 of 8 Old 07-15-2010, 08:05 AM
yellow_xj
How is it the lockers fault that u joints on a d30 broke spinning 35 inch tires?
01,4.0 W/Upgraded Injectors & Bored Throttle Body,AW4,NP231,D30 W/RC CA Drop,C8.25 W/Aussie Locker & Junkyard Disc Conversion,6" lift on 33X12.5X15.
Yellow Jeep Club member # 16
Jeeps dont die they get rebuilt bigger and stronger, like the 6 million dollar man!
yellow_xj is offline
post #3 of 8 Old 07-15-2010, 02:42 PM
ClimbStuff
Why is it the monitors fault that the computer locks up?
ClimbStuff is offline
post #4 of 8 Old 07-15-2010, 02:49 PM
little_Jeep
I thought my computer caused all those spelling mistakes in my post.... I now suspect that my Aussie locker is the real cause....
little_Jeep is offline
post #5 of 8 Old 07-15-2010, 03:15 PM
dakuda
Admin
dakuda's Avatar
I broke a ujoint and an axle shaft with an Aussie. I certainly don't blame the locker. The Aussie survived the break - it works just fine.
You can do things the right way or the wrong way.
Or you can do it MY way...which is like the wrong way, only faster.
dakuda is offline
post #6 of 8 Old 07-15-2010, 04:06 PM Thread Starter
-ExDementia-
1991 XJ Cherokee
An aussie claimed a u-joint AND an axle shaft? You better get rid of that thing man... I've been running a Powertrax for a while now and haven't broken anything. They just must be better lockers
Click
post #7 of 8 Old 07-15-2010, 04:12 PM
HELMET
With a Detroit in the rear, I broke my front drive shaft.
Note to self, let off the skinny peddle before the front tires land.
HELMET is offline
post #8 of 8 Old 07-15-2010, 04:20 PM
dakuda
Admin
dakuda's Avatar
I broke them, the Aussie just happened to be installed. Different trips too, but both were on the same side.
I blame Canada and you need to push it a bit more.
dakuda is offline
aussie , aussie lockers , broke , broken , lockers , lunchbox , lunchbox lockers , u-joint , ujoint
"Lincoln Lockers"? theirishavenger Engines & Drivetrain 3 12-24-2006 09:08 AM
Aussie "automatic" locker??? Jon_H General Jeep & Off-Road Equipment 15 09-07-2006 01:07 PM
aussie lockers anyone? redrmearsenal18 Engines & Drivetrain 16 03-31-2006 03:31 PM
How about a "sticky" for lockers? Flyingbrass General Jeep & Off-Road Equipment 7 08-11-2005 09:21 AM
Lockers + MTs suck in snow MSHarnett General Jeep & Off-Road Equipment 15 12-07-2003 04:57 PM
