ARB Air Compressor not turning on/working! - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > ARB Air Compressor not turning on/working!
SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!Bds fox ipf 2.0 racing series shocks now available at rockTJ BDS 2" suspension lift!! FINALLY a GREAT 2" l
Unread 07-24-2015, 11:50 PM   #1
rayzjeep
So I have power to the switch and the relay is good and I still can't get the compressor to turn on. What's a good way to direct wire the compressor to the battery to at least see if it's working? Thanks!
rayzjeep is offline   Reply With Quote Quick reply to this message
Unread 07-25-2015, 08:59 PM   #2
zillla
1975 CJ5
I'd use a jumper wire straight from the battery to the compressor hot.. Are you sure the pressure switch is ok? And not satisfied?? Or broke?
Pull my finger
zillla is offline   Reply With Quote Quick reply to this message
Unread 07-25-2015, 09:04 PM   #3
rayzjeep
No I haven't switched the pressure switch yet.
