Anyone else rock crawl backwards? - JeepForum.com
 2Likes
  • 1 Post By 222Doc
  • 1 Post By Jerry Bransford
post #1 of 14 Old 02-12-2017, 08:29 AM Thread Starter
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Occasionally, I crawl up and over an obstacle backwards, just for fun. It's usually stair-step type obstacles, where the line is not too critical. Does anyone else do that?
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is online now
post #2 of 14 Old 02-12-2017, 10:29 AM
biffgnar
biffgnar's Avatar
Definitely can be fun. All depends on the group you are with. Can be done even when line is a little tougher but becomes even more about the spotter then. I like to do it on obstacles where there are two distinct lines/paths. Drive one forwards, then back up either over it or the other line and then do the other line forward. Creates variety rather than just back and forth over the same line.
Romney in 2020!
biffgnar is offline
post #3 of 14 Old 02-12-2017, 11:13 AM
Mousejockey
All the time, some sections of the trail are only 1 lane so to speak, need to back up to a turnout, or when ya need to position for an extraction of another rig.
Mousejockey is offline
post #4 of 14 Old 02-12-2017, 12:35 PM
222Doc
222Doc's Avatar
Most days its just hard to getting going forward. Wait this is about wheeling....
JK4doors likes this.
222Doc is offline
post #5 of 14 Old 02-12-2017, 05:21 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I have enough trouble crawling my Jeep over obstacles in the usual forward direction.
222Doc likes this.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is online now
post #6 of 14 Old 02-12-2017, 10:06 PM
wilson1010
My 91 4x4 Toyota 22re pickup was significantly more effective climbing backwards.
03 Rubicon; 99 xj with too much stuff to list; Unimog 406 (gone)
wilson1010 is offline
post #7 of 14 Old 02-12-2017, 10:28 PM
christensent
2014 JK Wrangler
Is there much risk of damaging gears doing this? I hear you shouldn't pull someone out in reverse when they're real stuck, since it could break the ring/pinion (significantly weaker in the reverse direction).
Certainly no risk when really just crawling, but get a little wheel spin or throttle into the mix and couldn't it end poorly?
christensent is offline
post #8 of 14 Old 02-13-2017, 08:33 AM
222Doc
222Doc's Avatar
seen fronts break in reverse, but that was pulling another heep out of a bind. I wont pull in reverse, i use the winch in all those situations.
222Doc is offline
post #9 of 14 Old 02-13-2017, 09:57 AM Thread Starter
JeeperDon
JeeperDon's Avatar
The only time I had an issue with aggressive reverse pulling someone out was years ago when an internal ARB copper line, apparently doing a springlike jiggle just right, got eaten by the ring gear. Other than that, I never tell my Jeep it can't do something, so it manages to do everything. When I need to get winched over a tough spot, I tell the Jeep it's my fault, a courage issue.
I also have a cover on my winch day to day, but I always take the cover off at the start of a trail. It lets the rocks know I'm serious, have a plan B at the ready, and they will not deny me access.
Web Admin for
post #10 of 14 Old 02-13-2017, 03:54 PM
222Doc
222Doc's Avatar
I have had some rather heat talks to my heep. like the wife though i dont think its listening.
222Doc is offline
post #11 of 14 Old 02-13-2017, 04:01 PM
JeepersKreapers
I'd feel a little more scared looking down as opposed to up....
JeepersKreapers is offline
post #12 of 14 Old 02-16-2017, 08:54 PM
RARECJ8
RARECJ8's Avatar
1981 CJ8
Ive seen many bad things happen when a rig is winching out a vehicle and getting impatient winching driver thinks, heck ill help the winch and go to reverse.
Wait for it...
BOOM
Did you hear that?
Uh oh... Houston, now we really have a problem.
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #13 of 14 Old 02-16-2017, 09:45 PM
222Doc
222Doc's Avatar
Dp
222Doc is offline
post #14 of 14 Old 02-16-2017, 09:49 PM
222Doc
222Doc's Avatar
Originally Posted by RARECJ8 View Post
BOOM
Did you hear that?
I know that sound from even a few jeeps back. never good and always makes for a long , long day. i carry axles for my heep, but not gears.
222Doc is offline
