Quantcast Any tips for a first time off-roader? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > General Jeep & Off-Road Equipment > Any tips for a first time off-roader?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineBLOWOUT SALE -- SYE Slip Yoke Eliminator Kits, NP231 TransNEW BOLT-ON Dash CB Mount 97-06 TJ Wranglers
Old 08-28-2008, 12:57 PM   #1
gearchick
Hi,
I am offroading this weekend for the first time! Recently got my Wrangler Sahara (98) 6 cyl, 4.0L 5-speed manual...
I know I'm supposed to check the fluids before I go out but does anyone have any other tips? I don't want to damage my beautiful car!
gearchick is offline   Reply With Quote
Old 08-28-2008, 01:03 PM   #2
mpd295
Make sure you're with someone who has been before. If you're not sure about terrain get out and walk it first. As far as your new vehicle, if you worried about getting it scratched or damaged then you might as well leave it at home. Some sort of damage will occur unless you're pretty much mudding in an open field and even then something could still happen.
mpd295 is offline   Reply With Quote
Old 08-28-2008, 01:38 PM   #3
gearchick
Well, I'm obviously not worried about scratches or cosmetic damage- Just want to make sure I am prepared so I don't break anything I can't fix! I am changing the oil before I go camping this weekend- anything else I should check out before I leave? Should I let air out of my tires before I go offroad?
Old 08-28-2008, 02:34 PM   #4
Death_Valley_TJ
Old dude
Death_Valley_TJ's Avatar
Letting some air out of you tires will make your jeep ride a little better off road and give it more traction. However, your jeep is very capable and if you are going to go on terrain that requires you to let air out of your tires then I hope you are going with someone with experience. Just driving off the highway on dirt roads does not require lower air pressure. Also, make sure you have a way to reinflate to the proper pressure before driving very far at highway speeds.
Have fun,
DVTJ
Death_Valley_TJ is offline   Reply With Quote
Old 08-28-2008, 05:10 PM   #5
breckboarder55
Deflate tires, Un-bolt the front sway bar
NOW two big items...
FRONT REAR TOW HOOKsattached directly to the frame...
kinetic tow straps at least a 15k pound 20 foot strap, you can pick one up at O'reileys, exc for about 25 bucks... Make sure the tow strap has no metal hooks! People have died from these, no joke.
To Veterans past and present, thank you for your service!
99 Jeep Wrangler-Just another TJ on 33"s
55 Dodge Royal Lancer- Resto Project
87 Mazda RX-7 Turbo II-Built.
87 Mazda RX-7 SE-Burn Victim
02 Toyota Celica GT-S-DD/beater
breckboarder55 is offline   Reply With Quote
Old 08-29-2008, 06:12 AM   #6
missrebel713
Your beautiful car isn't a car...it's a Jeep...embrace it.
missrebel713 is offline   Reply With Quote
Old 08-29-2008, 08:26 AM   #7
SpoiledRotten
Roughin' it smoothly
SpoiledRotten's Avatar
Maybe he has a beautiful car sitting next to his Jeep. How do you call a Jeep a car? You may not need to go offroading. You'll probably destroy your "car". Good luck and have fun. Don't do something just because an experienced off raoder does it. You'll mess up.
Christian Jeepers _ Member #2
United Four Wheel Drive Association _ Member
National Rifle Association _ Member
SpoiledRotten is offline   Reply With Quote
Old 08-29-2008, 08:52 AM   #8
Diehard
Diehard's Avatar
A few more Important items:
First aid kit
Fire extinguisher, (you'll be happy to have it than not if you need it and some places require you to have one).
Jack & spare tire, (another item some places require you to have).
Water (for drinking)
CB radio, not necessary, but cell phones do lousy in the woods/mountains.
Cell phone
Less important, but nice to have:
Some basic tools, (wrenches, socket set, screw drivers, hammer, etc.).
Rags or some old towels.
Bug spray.
Sunscreen.
Once you get more into it:
Spare fluids, oil, coolant, gear lube.
Spare axles, bearings.
More tools.
One of the most important items is your common sense.
SAFETY FIRST.
Don't do something if you don't want to no matter what someone says.
It takes a combination of experience and the Jeep to get good at offroading.
Be patient and learn your Jeep's limits and your own.
Have a SAFE trip and enjoy your Jeep.
2004 GC Spec. Edit. V8 4x4 Quadra-Trac II. Bright Silver Metallic Clear Coat, 4" lift, RE shocks, adj. JKS CAs all around, 265/75/16, 10 ply., Maxxis Bighorns, ProtoFab winch bumper, Vortex 10,000 lb. winch, dual OME steering stabilizer, Rockyroad rockrails, skids, JKS Discos. Addco front & rear sway bar, & Aussie locker. Next year? : Rear bumper with tire carrier.
Diehard is offline   Reply With Quote
Old 08-29-2008, 08:54 AM   #9
Diehard
Diehard's Avatar
This also is a good set of guidelines:
1. Never be afraid to say "NO".
2. Remember it's your vehicle and your well-being.
3. Just because someone else can, you might not. If someone else can't, you might.
4. The vehicle is only half the battle - the driver is the other 75%. (Yes it adds up wrong, but I left as is).
5. Making it look easy takes experience and experience takes time.
6. Skill can never be made up for with equipment.
7. Know your vehicle and it's limitations - AND YOURS.
8. Don't drink and drive (on the street or on the trail).
9. Stock vehicles can have fun too.
10. It ain't what you bought; it's how you build it. (Of course the part of the saying that they never finish is: How you build it depends on what you want to do with it - which might simply be to get down to your favorite fishing hole!).
Old 08-29-2008, 09:06 AM   #10
rqukrawler
Most stuff got covered above and much good advice has been dispensed, but I'll add something I've seen many newbies do.
When you come up to a rock in the road that looks tall enough to catch your undercarriage, you want to keep your tires on it. Don't center up on it and drive into it. One misplaced rock can catch drive shafts and cause the damage you're trying to avoid.
[CENTER]99' WJ Laredo, owned since day 1, hand-me down after 110k of groceries and soccer games, 4.0 Selec-trac, IRO 4" LA, IRO Sliders, discos, Rubicon Wheels & 255/75-17 BFG MT's[/CENTER]
Another one bites the dust. Slow roll on Swamp... body is toast but the goodies will live to see another day.
rqukrawler is offline   Reply With Quote
Old 08-29-2008, 09:13 AM   #11
TellicoTJ
When muddin, get out and see how deep the water/mud/ruts is and compare that to your ground clearance. Doing this will usually keep you from getting high centered.
Also if you lose forward momentum in mud, try backing out of the hole since there isnt nearly as much mud blocking you.
TellicoTJ is offline   Reply With Quote
Old 08-31-2008, 05:06 PM   #12
briguy3030
[QUOTE=breckboarder55;5631535]
kinetic tow straps at least a 15k pound 20 foot strap, you can pick one up at O'reileys, exc for about 25 bucks... Make sure the tow strap has no metal hooks! People have died from these, no joke.[/QUOTE
I was planning on purchasing 20' of recovery chain, grade 70 w/grabber hooks.
Is this not recommended? I use rigging every day as I am a Union Ironworker.
We use straps & wire rope chokers w/ the cranes.
I understand the logic of a failed piece of rigging & the metal hook/chain flying back @ somebody . . . however, couldn't one merely put a blanket, something with a little weight on the rigging to absorb/dissipate the energy in the event of a rigging failure?
RUBICON
"You miss 100 percent of the shots you never take."
-Wayne Gretzky
briguy3030 is offline   Reply With Quote
Old 08-31-2008, 05:11 PM   #13
briguy3030
Another Tip I'm sure you've heard before but it must be said . . .
Always let someone know where you will be going & how long you intend to be gone.
RUBICON
-Wayne Gretzky
Old 08-31-2008, 05:25 PM   #14
nicolas-eric
If it΄s your first time.. never go wheeling alone with only one Jeep.
Better buy (kinetic) recovery straps than a chain.
2.5" OME & 2" Spacer & LT Shocks • 2" BL • 1" MML • JKS Discos • JKS Rear Links • OME Steering Stabilizer
35x12.5x15 Cooper STT @ 8.5x15 • ARB Airlockers • ARB Diff Covers • 4.56 Gears • SS Brake Lines
Warn Skids • Genright Rock Slider • Smittybilt Rock Crawler Rear Bumper • Safari Snorkel • OBA
12.000 lbs Winch • Synthetic Winch Line • 4x 130W Hellas • 4x 200W Hellas @ Lightbar • E-Fan
Jeep TJ Runicon Pics www.timbercrawler.de
nicolas-eric is offline   Reply With Quote
Old 08-31-2008, 05:33 PM   #15
CMARJEEP
[QUOTE=briguy3030;5642587]
Most people don't like chains for a couple reasons. They are very heavy and take up more space than a regular old tow strap. They can't be jerked if you are really stuck and regular pulling won't get you out. Chains are just as safe as a tow strap when used properly. In fact if chains break they technically should just fall to the ground unless you are yanking with them. I prefer a good old tow strap though.
-Connor KI6TMX
www.norcaljeepers.co
CMARJEEP is offline   Reply With Quote
Glock Forum
