Angle Finders - JeepForum.com
post #1 of 9 Old 06-29-2013, 05:54 PM Thread Starter
4wdjeepguy
Angle Finders
Does anyone have a strong preference for a particular brand? I need to pick a new one up to set my caster.
IG: CS_OFFROAD
YOUTUBE: CS OFFROAD
4wdjeepguy is offline
post #2 of 9 Old 06-29-2013, 06:18 PM
tjcj
I have a couple of the cheap plastic ones from my local hardware store they work. Recently bought a Craftsman 6" digital torpedo level/ angle finder for $40. Its way easier to get a more accurate reading.
Yakima Valley Mountaineers.
tjcj is offline
post #3 of 9 Old 06-29-2013, 06:25 PM Thread Starter
4wdjeepguy
Does it have a magnetic base? As of right now, I was going to use a plastic one and double check that number with an iPhone angle finder app.
IG: CS_OFFROAD
YOUTUBE: CS OFFROAD
post #4 of 9 Old 06-29-2013, 07:04 PM
tjcj
Yes it has a magnet. I bought it cause I was using the plastic ones to dial in my caster and wanted a more accurate reading.
Sent from my XT881 using JeepForum
tjcj is offline
post #5 of 9 Old 06-29-2013, 07:23 PM Thread Starter
4wdjeepguy
I noticed it only has one flat surface--I think. What does it do if it is upside down?
IG: CS_OFFROAD
YOUTUBE: CS OFFROAD
post #6 of 9 Old 06-29-2013, 07:47 PM
tjcj
It reads the same upside down or right side up. The one I got you can also switch it between modes, it will read degrees , inch in feet , and % of slopes
tjcj is offline
post #7 of 9 Old 06-30-2013, 08:44 AM
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
Get one with the largest diameter indicator you can find. Trying to see the difference between 4 and 5 is nuts on the cute little mini-dials most have. If you do the math on a 3" diameter dial, 1 is only .024" on the outside curve of the dial.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #8 of 9 Old 06-30-2013, 06:47 PM
Motorcharge
Imo stay away from the cheap Swanson ones from Lowe's. They work and they'reaccurate but they fall apart easily. I constantly have to put the pointer and plastic cover back on and it doesn't do much but sit around in a toolbox most the time. Just pulling it out makes everything fall off of it.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #9 of 9 Old 06-30-2013, 08:46 PM Thread Starter
4wdjeepguy
I have one with a 4" dial right now. Bought it for 8-9 buck iirc. I might get the craftsman one. It looks pretty sweet. My iPhone is more accurate than anything right now..
IG: CS_OFFROAD
YOUTUBE: CS OFFROAD
