Advice on new lift - JeepForum.com
post #1 of 18 Old 06-25-2013, 07:03 PM Thread Starter
98TJcomeonuh
Advice on new lift
Hi.
I recently went on my first wheeling trip in my current jeep (05 unlimited, 6 speed, 31x10.50, and a rough country 2.5 in. lift).
My question/problem is that the ride is so harsh it's very hard to control the jeep, so I was wondering if there is any advice on with brand of lift has the best on and off road manners. I was think OME with a 1.25 BL.
Thans for any help.
98TJcomeonuh is offline
post #2 of 18 Old 06-26-2013, 03:29 PM Thread Starter
98TJcomeonuh
Bump
post #3 of 18 Old 06-26-2013, 05:14 PM
biffgnar
biffgnar's Avatar
What shocks do you have? What pressure are you running your tires at?
Romney in 2020!
biffgnar is offline
post #4 of 18 Old 06-26-2013, 07:32 PM Thread Starter
98TJcomeonuh
The no2 rough country shocks. Do you think that the shocks would make that much of a difference? Because I thought about getting the rancho 9000(the adjustable ones). But another source told me that the rough country spring rate is an ungodly amount, so i didn't think new shocks would make that much difference.But the last time I checked they were at 42 psi.thats what they were from the dealership. On my last tj I ran my mickey's around 33-35 psi.
post #5 of 18 Old 06-26-2013, 07:37 PM Thread Starter
98TJcomeonuh
I also thought that's the RC control arms might have something to do with it riding so violently.
post #6 of 18 Old 06-26-2013, 11:09 PM
Filthy-Beast
first, air down to 15# for off-road. google chalk test for proper air pressure. I run my 35" tires at around 26# on the street. I run my F150 towing a 6800# trailer at 42#
For Sale:
97 TJ: daughter 1 - 2.5L, Auto, 2" BB, 31" GY Duratrac
98 TJ: Daugher 2 - 4.0L, 5spd, D44 rear
06 LJ Rubicon: mine - Rokmen full up-armor, 8 adjustable CAs, front bumper, sliders, corners, Shrockworks rear bumper, 3" AEV/BDS lift, Currie HD stearing and Antirock, MT/r - k 35x12.5, SuperWinch, MC Overlines, York OBA
13 JKU Rubicon: Wife's for now, Ace Rock rails & rear bumper tire carrier, Truck Lites, MC Game changer 3.5 lift, RR skids, PSC Brawler front bumper, Warn 9.5cti-s, 35" GY MTRs
Filthy-Beast is offline
post #7 of 18 Old 06-27-2013, 06:58 AM
olliehopnoodle
1982 FSJ Cherokee
Yep, air down when you get to the trail. Air back up before you get on the road. Lot's of ways to air back up. Cheapest is to get a decent air compressor. A good one can be had for less than $100 easy and your 31" tires won't take long to air back up.
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline
post #8 of 18 Old 06-27-2013, 11:10 AM Thread Starter
98TJcomeonuh
Thank you. I'm going to air them down to 25 psi and try that to see if it helps. Then adjust as needed thank you for the info.
post #9 of 18 Old 06-27-2013, 11:13 AM Thread Starter
98TJcomeonuh
Do you mean an on board air compressor or just a regular compressor? I have just a regular air compressor and I also have a portable air tank.
Thank you for your info as well.
post #10 of 18 Old 06-27-2013, 01:09 PM
Filthy-Beast
If you mean for off-road that's way to high a pressure.
For Sale:
post #11 of 18 Old 06-27-2013, 04:23 PM Thread Starter
98TJcomeonuh
I you mean for off-road that's way to high a pressure.
So in your opinion what what would be proper psi for off road and then when aired up on road. Cause when I go over railroad crossings it's terrible and even a crack in the road haha. Thank you
post #12 of 18 Old 06-27-2013, 04:42 PM
jeff_in_rc
OK first you need to find the correct pressure for on the road. Search for the chalk test, it will tell you step by step how to get your street pressure correct for your tires. I will tell you 42psi is just way to fricken much!!!
Now you need to find a portable air compresser that runs off of your battery in the Jeep, ViAir, SureFlow, SuperFlow, etc. Look in the on-line stores.
On my Hercules Terra Tracs of the same size as yours I run 10psi off road and it really helps with traction and the ride. I hope this helps.
2004 Jeep Wrangler Rubicon
Member of the Gear Grinders 4WD Club
jeff_in_rc is offline
post #13 of 18 Old 06-27-2013, 04:57 PM
biffgnar
biffgnar's Avatar
With those tires, on road 28-30 psi. Offroad 12 psi area.
Romney in 2020!
biffgnar is offline
post #14 of 18 Old 06-27-2013, 06:58 PM Thread Starter
98TJcomeonuh
Yeah 42psi is way to much, I just never checked them when I got the jeep back In April. And thanks for the sources I will definitely check into all three thanks again.
post #15 of 18 Old 06-27-2013, 07:01 PM Thread Starter
98TJcomeonuh
Thanks I'm going to try it out when I get home from work and then when I get back out on the trail I'll do the same thanks.
