Acronym List **Now a Google Doc** - Page 3 - JeepForum.com
post #31 of 48 Old 07-09-2010, 08:03 PM
cleanslate
I've also heard FTW reffered to as Forever Two Wheels.
cleanslate is offline
post #32 of 48 Old 03-06-2011, 12:30 PM
cheftrail
today i saw a MILF in a jeep, does that count?
05 TJ locked & loaded, 04 WJ DD, 96 XJ and a darn Volvo V70
cheftrail is offline
post #33 of 48 Old 03-12-2011, 07:28 PM
Levonius
FTW = For The Win its a praise for something...
Levonius is offline
post #34 of 48 Old 03-13-2011, 11:22 AM
03WJDave
2003 WJ
I have one correction:
POS= 1984 CJ-7 w/4cly, Mine was real POS spent most of it's life in the shop right from the dealer...
Member NCBBA, OBPA Join Jeepfishing surf group
Mayhem lives at 1600 Pennsylvania Avenue
03WJDave is offline
post #35 of 48 Old 04-25-2011, 11:15 AM
Sykd4MyWaggy
PO = Previous Owner... for about a month, I though PO was a dudes name that was really popular and got talked about a lot.
Sykd4MyWaggy is offline
post #36 of 48 Old 06-21-2011, 10:11 AM
dcecr
2006 WK
great compliation tks
dcecr is offline
post #37 of 48 Old 06-25-2011, 06:43 PM
54pappy
2006 XK Commander
BOHICA......Bend Over Here It Comes Again!
54pappy is offline
post #38 of 48 Old 06-28-2011, 02:10 PM
phil1330
1964 CJ5
Everybody should know this one
J...ust
E...mpty
E...very
P...ocket
"Life is hard, it's harder if your're stupid"...The Duke
phil1330 is offline
post #39 of 48 Old 09-27-2011, 08:38 PM
Trendsetter75
2010 JK Wrangler
Originally Posted by dakuda View Post
NP New Process (same as NV).
NP 231 Command-Trac Transfer Case (2HI - 4HI - N - 4LO).
NP 242 Selec-Trac Transfer Case (2HI - 4PT - 4FT - N - 4LO).
NP 247 Quadra-Trac II Transfer Case.
NP 249 Quadra-Trac Transfer Case (4 All Time - N - 4LO).
NV New Venture (same as NP).
NV3550 5 speed manual stick in a post-99 6 cylinder TJ.
NWS Not Work Safe (this thread might get you fired at work)
O2 Oxygen (usually in reference to an oxygen sensor).
OBA On Board Air. A system of a tank and/or air compressor located on a vehicle.
OBD, OBDI First generation of On Board Diagnostics.
OBDII Second generation of On Board Diagnostics (1996+).
OBW On-Board Welder.
OD or O/D Outside Diameter.
ODO Odometer.
OEM Original Equiptment Manufacturer.
OHV Off-Highway Vehicle or Over Head Valve.
OME Old Man Emu. Aftermarket Manufacturer.
ORV Off Road Vehicle.
PAB Passenger Airbag.
PB PB Blaster. A penetrating liquid.
PCM Powertrain Control Module.
PDC Power Distribution Center.
PDM Passenger Door Module.
POS Piece Of Sh--.
PS or P/S Power Steering.
PSI Pounds per Square Inch (of pressure).
PSF Pounds per Square Foot.
PRNDL Park, Reverse, Neutral, Drive, Low.
PRNODL Park, Reverse, Neutral, Overdrive, Drive, Low.
PTC Positive Temperature Coefficient.
PTO Power Take Off.
QD Quick Disconnect. Installed on the anti-sway bar.
RA Road Armor.
RC Reverse Cut.
RD Right Door.
RE Rubicon Express. Aftermarket manufacturer.
REBB Combine RE and BB = Rubicon Express budget Boost.
RFI Radio Frequesncy Interference.
RHD Right Hand Drive.
RK Rock Krawler. An aftermarket suspension company.
RKE Remote Keyless Entry.
RPM Revolutions Per Minute.
RR Right Rear.
RTI Ramp Travel Index.
RTV Room Temperature Vulcanizing. A product that is used to form gaskets.
SAE Standard American Equivalent. You know, tools that aren't metric. Also, Society of Automotive Engineers
SAS Solid Axle Swap. Swappnig in a solid front axle to replace IFS.
SE Jeep's basic trim package.
SEMA Specialy Equipment Market Association.
SF Superflex. A lift option for Rubicon Express lift kits.
SFA Solid Front Axle.
SJ Jeep Grand Wagoneers, Trucks from 1963-92.
SOA Spring Over Axle.
SOHC Single OverHead Cam.
SUA Spring Under Axle.
SWB Short Wheel Base.
SWR Standing Wave Ratio.
SYE Slip Yoke Eliminator. Installed on transfer case to decrease driveline angles.
TB Throttle Body.
TBI Throttle Body Injection.
TBS Throttle Body Spacer.
TBT Toys by Troy. Aftermarket Manufacturer.
TC Transfer Case.
TCM Transmisison Control Module.
TJ Jeep Wrangler models from 1997-06.
TJL, TJ-L Unofficial letter codes for Jeep Wrangler Unlimited 2004+.
TPS Throttle Position Sensor.
TRE Tie Rod End.
TSB Technical Service Bulliten.
UCA Upper Control Arms. (same as USA).
USA Upper Suspension Arm (same as UCA).
US/M U.S. to Metric [button].
VC Viscous Coupler.
VF Vaccum Flourescent Display.
VIC Vehicle Information Center.
VIN Vehicle Identification Number.
VSS Vehicle Speed Sensor.
VTSS Vehicle Theft Security System.
WJ Jeep Grand Cherokee models from 1999-04.
WD-40 Water Displacement, Formula 40. A common oil used to do pretty much anything.
WK Jeep Grand Chrokee models from 2005+.
WMS Wheel Mounting Surface.
WOT Wide Open Throttle.
WTF What The F-.
XJ Jeep Cherokee and Wagoneers from 1984-2001.
X Jeep Wrangler Trim/Option Package.
XM A satellite radio service.
YJ Jeep Wrangler models from 1987-95.
ZJ Jeep Grand Cherokee models from 1993-98.
You forgot NSG-370
2010 JKU (6-spd)
Trendsetter75 is offline
post #40 of 48 Old 02-11-2012, 09:17 AM
JeephtimS
What is OPDA?
97 TJ Sport, 2.5" front 1.5" rear lift, 31x11.5 15 Trxus STS on 15x10 Eagle Alloy 118s
JeephtimS is offline
post #41 of 48 Old 02-19-2012, 11:18 PM
JeephtimS
OPDA. Found out by accident that it means oil pump drive assembly.
post #42 of 48 Old 03-18-2012, 08:40 AM
13bullets
SKIM - Sentry Key Immobilizer Module
13bullets is offline
post #43 of 48 Old 04-04-2012, 05:46 PM
aaronjole
This is very helpful. Would you mind if I take a note of these acronyms... Thanks...
aaronjole is offline
post #44 of 48 Old 09-27-2012, 05:14 PM
babygirl
This really helps my studying the terminology!!! Thanks!
babygirl is offline
post #45 of 48 Old 12-02-2013, 01:20 PM
redjeepguy1
BMT = Big MAN Truck....
it's what is used to tow your jeep around on a trailer when / if you take it on trips where you'd rather tow it than drive it.
Bill
member 141,234,541 of the red jeep club
redjeepguy1 is offline
acronym list , acronyms , jeep acronyms , vehicle acronyms
Acronym List dakuda General Jeep & Off-Road Equipment 8 09-05-2007 03:51 PM
DIY co2 parts list bandit222 General Jeep & Off-Road Equipment 8 05-16-2007 10:43 PM
putting together my list... bloke279 Tires & Wheels 1 01-19-2006 10:21 AM
SYE/CV List JBXdudeTJ Tires & Wheels 12 01-15-2006 11:09 AM
Who's got there name on the list? BART CJ5 General Jeep & Off-Road Equipment 7 03-14-2003 06:32 PM
