Acronym List **Now a Google Doc** - JeepForum.com
post #1 of 48 Old 10-28-2005, 04:15 PM Thread Starter
dakuda
Admin
dakuda's Avatar
In the interest of making this list more dynamic and easier to update, I have transferred it to a Google Doc.
JeepForum.com Acronym List Google Document Link
I cannot embed it, since HTML access is off for the forum (as a security measure). However, you can access and update the list at the link above. If I figure out a way to embed it securely, I will do so.
The 'old' list is included below, to keep the search gods happy.
You can do things the right way or the wrong way.
Or you can do it MY way...which is like the wrong way, only faster.
dakuda is offline
post #2 of 48 Old 10-28-2005, 04:16 PM Thread Starter
dakuda
Admin
dakuda's Avatar
Here is a list of Jeep Acronyms. It seems that there is an acronym for everything.
2wd Two Wheel Drive.
4FT Four Wheel Drive, Full Time.
4LO Four Wheel Drive Low.
4PT Four Wheel Drive, Part Time.
4wd Four Wheel Drive.
AAL Add A Leaf.
ABS Anti-lock Brake System.
AC or A/C Air Conditioning.
ACC Accessory.
ACM Airbag Control Module.
AECM Airbag Electonic Control Module.
AEV American Expedition Vehicles. A vehicle modification/conversion shop, located in Montana.
AMC American Motor Corporation. Owners of the Jeep brand from 1970-87.
ARB ARB Corporation named for its founder, Anthony Ronald Brown. Aftermarket manufacturer.
ASDM Airbag System Diagnostic Module.
AT (A/T) All Terrain tire.
ATC Automatic Temperature Control
ATF Automatic Transmission Fluid.
AtoZ A to Z Fabrication. Aftermarket Fabrication.
AVG ECO Average Fuel Economy.
AW4 Automatic Transmission used on the XJ since 1987.
AWD All Wheel Drive.
AX15 5 speed manual stick in a pre-99 6 cylinder TJ.
AX5 5 speed manual stick in a pre-99 4 cylinder TJ.
BB Budget Boost (small, 2" lift).
BCM Body Control Module.
BFG BFGoodrich Tires.
BFH Big ****ing Hammer.
BL Body Lift. Spacers between the frame and body/tub of a vehicle.
BPE Bar Pin Eliminators.
BS Backspacing. Wheel hub location in relation to outside edge of rim.
BTT Back To Top.
BTW By The Way.
BUX Built Up Export.
C-101 Jeepster/ Commando 1967-1973. Part Jeep CJ and part Jeep Wagoneer.
CAB Controller, Antilock Brake.
CAL Calibration.
CAT Catayltic Converter.
CB Citizen Band Radio.
CCD Chrysler Collision Detection (vehicle communications bus).
CCV Crank Case Ventilation.
CEL Check Engine Light.
CG or COG Center of Gravity.
CJ Jeep models 1944-1986.
CJ-2A Civilian version of the MB, split windshield.
CJ-3A Updated version, single pane windshield
CJ-3B High hood version of 3A to fit larger engine
CJ-5 Early years were 81" wheelbase, later years were ~84". Built until 1983.
CJ-5A based on the M38A1 design
CJ-6 Stretch version of CJ-5, 101" wheelbase
CJ-6A based on the M38A1 design
CJ-7 smilar to late CJ-5, but with ~94" wheelbase. Built until 1986.
CJ-8 Scrambler Pickup, stretch version of the CJ-7, 104" wheelbase.
CJ-10 Heavy Duty Truck, Military airport Jeep pickup - 2wheel drive
CMTC Compass/Mini-Trip Computer (module)
COG Center Of Gravity.
CPS Crank Position Sensor.
CV Constant Velocity Joint.
D30 Dana 30 axle.
D35 Dana 35 axle.
D35C Dana 35 axle with C clips. The 'C' stands for custom. They are custom because they are shipped incomplete from the Dana factory to Chrysler. Final assembly was done by Chrysler.
D44 Dana 44 axle.
D44a Dana 44 axle with an aluminum housing
D60 Dana 60 axle.
DAB Driver Airbag
DC Daimler-Chrysler. Owners of the Jeep brand from 1998 until 2007.
DD Daily Driver.
DDM Driver Door Module
DJ AMC 2wd Postal Jeeps. 1952 - 1973
DLC Data Link Connector (same as EDC)
DOHC Dual (or double) OverHead Cams.
DOT Department of Transportation
DRB Digital Readout Box
DRL Daytime Running Lights.
DPA Dropped Pitman Arm
DS Death Shake (same as DW)
DTE Distance To Empty
DW Death Wobble. Violent shaking of the vehicle. (same as DS)ECO Intantaneous Fuel Economy
ECU Engine Control Unit (same as ECM)
ECM Engine Control Module (same as ECU)
EDC Engine Diagnostic Connector (same as DLC)
EGR Exhaust Gas Recirculation
EFI Electronic Fuel Injection
ET Elapsed Time
FAQ Frequently Asked Questions.
FC Forward Control Trucks 1957 - 1966
FIPK Fuel Injection Performance Kit. Sold by K&N.
FSJ Full Size Jeep (SJ's and J-trucks).
FSM Factory Service Manual.
FWD Front Wheel Drive
GC Grand Cherokee
GPS Global Positioning System.
HCU Hydraulic Control Unit
HD Heavy Duty
HEX Hexagon
HF Harbor Freight. A discount tool store.
HID High Intensity Discharge. A lighting system that produces an intense, white light.
HO High Output
HP High Pinion
HTH Hope this helps, happy to help.
HU Head Unit. The main part of your stereo system.
HVAC Heater, Ventilation, Air Conditioning system.
I4 Inline four cylinder engine.
I6 Inline six cylinder engine.
IAC Idler Air Control Valve
ID or I/D Inside Diameter
IFS Independant Front Suspension.
IOD Ignition Off-Draw
IR Ingersoll Rand. Air tool manufacturer
IRS Independant Rear Suspension.
JK New model Jeep Wranglers made from 2007+
JTEC Jeep Truck Engine Controller (PCM)
KJ Jeep Liberty models from 2002+ (Cherokee in Europe).
L Liter
LA Long Arm. Refers to length of control arms.
LCA Lower Control Arms. (same as LSA)
LD Left Door.
LED Light-Emitting Diode.
LHS Left Hand Drive.
LJ Unofficial (?) letter code for the Jeep Wrangler Unlimited 2004+.
LOM Lamp Outtage Monitor.
LR Left Rear.
LSA Lower Suspension Arm (same as LCA).
LSD Limited Slip Differential.
LWB Long Wheel Base.
MAP Manifold Absolute Pressure sensor.
MET Metric.
MIC Mechanical Instrument Cluster.
MJ Jeep Comanchee, Compact Pickup models from 1986-92.
MML Motor Mount Lift.
MPI Multi-Port Fuel Injection.
MPG Miles Per Gallon.
MPH Miles Per Hour.
MSTM Memory Seat Module.
MT (M/T) Mud Terrain tire.
MTR Motor.
MUX multiplexed.NP New Process (same as NV).
NP 231 Command-Trac Transfer Case (2HI - 4HI - N - 4LO).
NP 242 Selec-Trac Transfer Case (2HI - 4PT - 4FT - N - 4LO).
NP 247 Quadra-Trac II Transfer Case.
NP 249 Quadra-Trac Transfer Case (4 All Time - N - 4LO).
NV New Venture (same as NP).
NV3550 5 speed manual stick in a post-99 6 cylinder TJ.
NWS Not Work Safe (this thread might get you fired at work)
O2 Oxygen (usually in reference to an oxygen sensor).
OBA On Board Air. A system of a tank and/or air compressor located on a vehicle.
OBD, OBDI First generation of On Board Diagnostics.
OBDII Second generation of On Board Diagnostics (1996+).
OBW On-Board Welder.
OD or O/D Outside Diameter.
ODO Odometer.
OEM Original Equiptment Manufacturer.
OHV Off-Highway Vehicle or Over Head Valve.
OME Old Man Emu. Aftermarket Manufacturer.
ORV Off Road Vehicle.
PAB Passenger Airbag.
PB PB Blaster. A penetrating liquid.
PCM Powertrain Control Module.
PDC Power Distribution Center.
PDM Passenger Door Module.
POS Piece Of Sh--.
PS or P/S Power Steering.
PSI Pounds per Square Inch (of pressure).
PSF Pounds per Square Foot.
PRNDL Park, Reverse, Neutral, Drive, Low.
PRNODL Park, Reverse, Neutral, Overdrive, Drive, Low.
PTC Positive Temperature Coefficient.
PTO Power Take Off.
QD Quick Disconnect. Installed on the anti-sway bar.
RA Road Armor.
RC Reverse Cut.
RD Right Door.
RE Rubicon Express. Aftermarket manufacturer.
REBB Combine RE and BB = Rubicon Express budget Boost.
RFI Radio Frequesncy Interference.
RHD Right Hand Drive.
RK Rock Krawler. An aftermarket suspension company.
RKE Remote Keyless Entry.
RPM Revolutions Per Minute.
RR Right Rear.
RTI Ramp Travel Index.
RTV Room Temperature Vulcanizing. A product that is used to form gaskets.
SAE Standard American Equivalent. You know, tools that aren't metric. Also, Society of Automotive Engineers
SAS Solid Axle Swap. Swappnig in a solid front axle to replace IFS.
SE Jeep's basic trim package.
SEMA Specialy Equipment Market Association.
SF Superflex. A lift option for Rubicon Express lift kits.
SFA Solid Front Axle.
SJ Jeep Grand Wagoneers, Trucks from 1963-92.
SOA Spring Over Axle.
SOHC Single OverHead Cam.
SUA Spring Under Axle.
SWB Short Wheel Base.
SWR Standing Wave Ratio.
SYE Slip Yoke Eliminator. Installed on transfer case to decrease driveline angles.
TB Throttle Body.
TBI Throttle Body Injection.
TBS Throttle Body Spacer.
TBT Toys by Troy. Aftermarket Manufacturer.
TC Transfer Case.
TCM Transmisison Control Module.
TJ Jeep Wrangler models from 1997-06.
TJL, TJ-L Unofficial letter codes for Jeep Wrangler Unlimited 2004+.
TPS Throttle Position Sensor.
TRE Tie Rod End.
TSB Technical Service Bulliten.
UCA Upper Control Arms. (same as USA).
USA Upper Suspension Arm (same as UCA).
US/M U.S. to Metric [button].
VC Viscous Coupler.
VF Vaccum Flourescent Display.
VIC Vehicle Information Center.
VIN Vehicle Identification Number.
VSS Vehicle Speed Sensor.
VTSS Vehicle Theft Security System.
WJ Jeep Grand Cherokee models from 1999-04.
WD-40 Water Displacement, Formula 40. A common oil used to do pretty much anything.
WK Jeep Grand Chrokee models from 2005+.
WMS Wheel Mounting Surface.
WOT Wide Open Throttle.
WTF What The F-.
XJ Jeep Cherokee and Wagoneers from 1984-2001.
X Jeep Wrangler Trim/Option Package.
XM A satellite radio service.
YJ Jeep Wrangler models from 1987-95.
ZJ Jeep Grand Cherokee models from 1993-98.
dakuda is offline
post #3 of 48 Old 12-27-2006, 07:18 PM
SpoiledRotten
SpoiledRotten's Avatar
I have seen the "OHV" when people are going wheeling in a special park. I have done a google search and still haven't found what the letters actually mean. I thought ORV or Off Road Vehicle, just didn't get the Hightway part when trying to figure it out.
On edit: Did some more searching and saw where it stands for "OFF HIGHWAY VEHICLE". Still could be added to the Acronyms.
Christian Jeepers _ Member #2
United Four Wheel Drive Association _ Member
National Rifle Association _ Member
SpoiledRotten is offline
post #4 of 48 Old 01-25-2007, 07:00 PM
wyocommander
? no expert, but...
list shows 'TJ' as going to '05, shouldn't it be '06?
wyocommander is offline
post #5 of 48 Old 01-25-2007, 07:31 PM Thread Starter
dakuda
Admin
dakuda's Avatar
Eh, I made the list in late 04 or early 05.
dakuda is offline
post #6 of 48 Old 05-08-2007, 04:39 PM
ChiliPalmer
This is Ames Mister...
ChiliPalmer's Avatar
You may want to add REBB also, if they're reading this thread they may not put the two together to figure it out...
If you want to help the sport of offroading visit the
Forum!
Oh man Chili. I feel like a recovering addict that just had a bag of blow, a bottle of Jameson, and a sack dropped in his lap. You screwed me man!
ChiliPalmer is offline
post #7 of 48 Old 07-19-2007, 02:38 PM
monkeychrist
bookmark, nothing to see here...
Originally Posted by athos76 View Post
...but one day while driving, I heard a twang and saw a little orange bungee go shooting off into traffic...
monkeychrist is offline
post #8 of 48 Old 09-02-2007, 12:24 AM
adurbin
Chrysler has owned Jeep since 88- not 98
97 TJ
4" Pro Comp Suspension Lift, 1" inch Body Lift, 33x12.50 Mickey Thompson Baja MTZ's on Cragar soft 8s, MileMarker PE8000 Winch, Rockcrawler Bumpers, 8.8 LSD.
Northeast Tennessee Jeep Club Member #1
adurbin is offline
post #9 of 48 Old 09-05-2007, 02:51 PM Thread Starter
dakuda
Admin
dakuda's Avatar
The abbreviation was for DAIMLER-Chrysler. Owners from 98 - 07
dakuda is offline
post #10 of 48 Old 01-08-2008, 10:40 AM
jp360cj
1977 CJ7
Probably a dumb question, but what is IIRC?
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #11 of 48 Old 01-08-2008, 11:45 AM
XJK
The Guru of Nothing
XJK's Avatar
http://www.urbandictionary.com/define.php?term=IIRC
IIRC - If I Recall Correctly
-Kyle
It's Not Just a Jeep, It's a Lifestyle
XJK is offline
post #12 of 48 Old 02-24-2008, 11:23 AM
cosninocanines
THANKS I needed this! Like you I'm new and spent way to much time trying to figure out what the h_ll they all meant.
cosninocanines is offline
post #13 of 48 Old 02-24-2008, 12:05 PM
BWR
hmmmmmmmmm....in other circles it stands for Over Head Valve..........
BWR is offline
post #14 of 48 Old 05-16-2008, 05:47 AM
blackattak
Thanks! 2 months later & still trying to learn this jeep language. Will keep this in my replies for reference.
blackattak is offline
post #15 of 48 Old 05-21-2008, 12:50 PM
Hrothgar
I've seen FTW used alot quite recently, and short of my own definition (**** The World) I'm at a loss to what it means... And my own def doesn't work in the context it's used.
FTW anyone?
Hrothgar is offline
acronym list , acronyms , jeep acronyms , vehicle acronyms
Acronym List dakuda General Jeep & Off-Road Equipment 8 09-05-2007 02:51 PM
DIY co2 parts list bandit222 General Jeep & Off-Road Equipment 8 05-16-2007 09:43 PM
putting together my list... bloke279 Tires & Wheels 1 01-19-2006 09:21 AM
SYE/CV List JBXdudeTJ Tires & Wheels 12 01-15-2006 10:09 AM
Who's got there name on the list? BART CJ5 General Jeep & Off-Road Equipment 7 03-14-2003 05:32 PM
