Ac not working in grand cherokee - JeepForum.com
post #1 of 2 Old 05-22-2011, 01:26 PM Thread Starter
ktplotts
It finally got warm enough for me to turn on my ac recently, just to find out that it is not blowing out cool air. I checked the fuse and relay, both good. I got a cheap gauge and refill bottle of r134 from the store. The initial reading on the low pressure side was nothing so I verified that the gauge was working on another car, and it worked fine. So I figured the system was low and preceded to put the r134 in. after the whole can, pressure still read nothing and compressor was not kicking on. Anyone have any ideas that I can try next? I know the compressor will turn on because it comes on for a second then turns back off when I push the ac button. If you need more details, just ask. Thanks for the help. Its a 02 with straight 6 if that helps.
ktplotts is offline
post #2 of 2 Old 05-22-2011, 02:42 PM
hoaxci5
1995 XJ Cherokee
Maybe you have a big leak, they have a uv additive in some of the refills which with a black light allows you to see where it is leaking from..
Personally I don't mess with AC though, if it doesn't work I take it in.. the refrigerant also has oil in it and not having the right amount of oil will burn up the compressor, and it's just not worth the gamble to me.
Unknown - 1995 XJ - 4.5 RC lift, drop brackets, 33" MT's, SYE, Custom Bumpers/Rockrails
Rambo - 2007 XK Limited 5.7 - OME HD - Monroe Load Levelers (F150) - Flashpaq - RRO SuperSliders - 4XGuard all over - SOLD
hoaxci5 is offline
96 Grand Cherokee Laredo Interior Lights not working Boogncass Audio, CB & Ham Radios, GPS, & Electrical 7 10-03-2017 09:20 AM
2004 Grand Cherokee wheels on 1999 Cherokee Sport? jbroese Tires & Wheels 2 07-30-2010 10:15 PM
05 Grand Cherokee REC Joystick not working BOBBY263052 Audio, CB & Ham Radios, GPS, & Electrical 1 08-13-2008 05:41 AM
TJ owner looking for Cherokee/Grand Cherokee DD/slight offroader rubicon4x4 General Jeep & Off-Road Equipment 0 04-03-2008 01:26 AM
Can a 2002 Grand Cherokee Radio fit a 1996 Grand Cherokee limited? banzayworld Audio, CB & Ham Radios, GPS, & Electrical 4 10-20-2002 10:25 PM
