Anyone done a 700r4 to a flipped dana 300??
been looking at the lo max kit for the 231, and at atlas t/case, both of which are a fortune...
scored a good deal on a short shaft dana 300, and for a whole lot less, could do a 4:1 dana 300, twin sticked and flipped. will do a rebuild at the same time, so be a new case practically..
if anyone has done it, what was the best adapter? is there a way to put the 27 spline input on the t/case so i dont need to tear into the tranny and change the output shaft to a 23 spline?
any input is greastly appreciated...
thanks
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.The Cherylkee....
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover 4.6 HSE
2000 4.7 4WD WJ with a rebuilt motor.
4.3/700r4/new frame buildup (YJ)....
http://www.jeepforum.com/forum/f12/swap-offically-underway-324622/
Years to gain the hands on experience, and offer it freely.
Minutes to gain the knowledge from the internet, and quote it just as freely.
Choose wisely!
