4 inch lift kit questions - JeepForum.com
post #1 of 10 Old 04-17-2013, 10:01 PM Thread Starter
604_yamamoto
I want to get a 4 inch lift kit for my 07 jk rubicon unlimited. My question is, do I need to upgrade the electronic sway bar disconnect system and the steering stabilizer? Will the stock ones still work? Stupid questions but I just don't know. Thanks!
604_yamamoto is offline
post #2 of 10 Old 04-18-2013, 07:40 PM
ljrubitm
2011 JK Wrangler
I have a 2011 JKUR with a 4'' lift & 35's. No need to replace them. Been running this way for 3 yrs now.
ljrubitm is offline
post #3 of 10 Old 04-18-2013, 07:47 PM Thread Starter
604_yamamoto
Good to know. Thanks!
post #4 of 10 Old 04-18-2013, 08:28 PM
222Doc
222Doc's Avatar
the lift should be VERY complete at 4". It will have longer links for the front sway no matter if it is a Rubi or not. SS shock only one is needed.
But at 4" plan on drive lines, they will not last long stock, off road they wont last at all. Most GOOD lifts will be taller than speced as well. Making the Dl issue more an issue.
If you use stock links to the sway on a 4 inch lift when the front goes to full drop or in flex it will go past paralell and flip down.
222Doc is offline
post #5 of 10 Old 04-18-2013, 08:59 PM Thread Starter
604_yamamoto
Wow, ya I thought it might be more involved. I should probably go to a reputable shop.
post #6 of 10 Old 04-18-2013, 09:44 PM Thread Starter
604_yamamoto
How about a 3 inch lift kit? Can all the other components remain stock?
post #7 of 10 Old 04-20-2013, 09:31 AM
ljrubitm
2011 JK Wrangler
AS far as swaybar link go, depending on the lift, the front is moved to the rear and you are given new ones for the front.
If you want to run 35's a 4'' lift is not needed put it's up to you. Being a 4 door the stock ds is still hit or miss but they seem to last longer then a 2dr will. Down here in Florida there is nothing but trails & mud , suger sand not much in the way of flexing so I've been good for 3 yrs now
ljrubitm is offline
post #8 of 10 Old 04-20-2013, 09:43 AM
Filthy-Beast
above about 2.5" things get expensive to do it right. you can run 35s with 2.5" and a little trimming.
For Sale:
97 TJ: daughter 1 - 2.5L, Auto, 2" BB, 31" GY Duratrac
98 TJ: Daugher 2 - 4.0L, 5spd, D44 rear
06 LJ Rubicon: mine - Rokmen full up-armor, 8 adjustable CAs, front bumper, sliders, corners, Shrockworks rear bumper, 3" AEV/BDS lift, Currie HD stearing and Antirock, MT/r - k 35x12.5, SuperWinch, MC Overlines, York OBA
13 JKU Rubicon: Wife's for now, Ace Rock rails & rear bumper tire carrier, Truck Lites, MC Game changer 3.5 lift, RR skids, PSC Brawler front bumper, Warn 9.5cti-s, 35" GY MTRs
Filthy-Beast is offline
post #9 of 10 Old 04-20-2013, 12:04 PM Thread Starter
604_yamamoto
Thanks for all the info. I have lots to think about now.
post #10 of 10 Old 04-24-2013, 03:21 PM
jcrawler93
Get a reputable suspension kit, rough country, pro-comp, skyjacker etc they should have everything that your JK will need to be lifted.
jcrawler93 is offline
