4.10/4.11 (Are they the same thing?) - JeepForum.com
post #1 of 11 Old 05-12-2002, 08:11 AM Thread Starter
Wolfpack97
I just received my statement from Drivetrain Direct for my 4.10 gears I ordered (haven't installed them yet). It said the Dana 30 had a 4.10 and the Dana 35 was 4.11. Is this right? Does it matter? I was wondering if I should be concerned that the 2 pinion gears are a LITTLE different. I ordered the gears as a package deal so maybe it was just a "typo" they used on the statement to describe what I bought. I plan on putting them in tomorrow if there is no problem with this set up.
Thanks everyone!!
97 Wrangler Sport 4.0L.
3" BDS Lift, 4.11 gears, Tera Disco's, Rusty's Air tube, Rusty's adj. track bars, Class III Hitch, "Generic" Hi-Lift, 33 MT's on 8" black wheels, CB, etc. etc. etc.
03 Toyota Sequioa 4x4: Loaded with all options but basically stock. This is the family hauler.......Miss the WJ but we need more room....
Wolfpack97 is offline
post #2 of 11 Old 05-12-2002, 09:01 AM
Bulletproofcj7
Did you try calling drivetrain direct to sort out the problem?
1982 cj7. Frame off. shell valley kevlar body, stainless hinges, Bestop seats and supertop, KC titanium lights, Homemade swing out tire carrier with spare front wheel bearings/hub, Built 304,DUI,Edelbrock shorty headers with dual stainless 21/2 tubes into incynerator cans 21/4 dumped out the back,Edelbrock 600cfm, performer intake and cam, Borgeson lower column, Centerforce clutch, NV-4500, Dana 300 w/custom built twin stick, Homade 1/4" steel skid plate, 2.5 soft ride w/ 1" shackle lift, 33x12.5 mtr's. Stainless fuel and brake lines, Braided hoses. more...
Bulletproofcj7 is offline
post #3 of 11 Old 05-12-2002, 04:44 PM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by Wolfpack97:
<strong>I just received my statement from Drivetrain Direct for my 4.10 gears I ordered (haven't installed them yet). It said the Dana 30 had a 4.10 and the Dana 35 was 4.11. Is this right? Does it matter? I was wondering if I should be concerned that the 2 pinion gears are a LITTLE different. I ordered the gears as a package deal so maybe it was just a "typo" they used on the statement to describe what I bought. I plan on putting them in tomorrow if there is no problem with this set up.
Thanks everyone!!</strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">That's the way they all are - don't worry about it!
Steve
OldJeepguy is offline
post #4 of 11 Old 05-13-2002, 02:21 PM
ezgoing
ezgoing's Avatar
Why is it that one is 4.10 and one is 4.11? I always thought they had to be the same otherwise there would be excess stress put on the drivetrain.
'92 YJ Sahara
1 1/4" shackle lift for now soon to be some sort of lift
31" Bridgestone Dueller A/Ts on AR-767 wheels
'67 Ford Galaxie 500 (passes everything but the gas station)
"What do you mean I can't make it, watch me!" = oops
ezgoing is offline
post #5 of 11 Old 05-13-2002, 04:07 PM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by ezgoing:
<strong>Why is it that one is 4.10 and one is 4.11? I always thought they had to be the same otherwise there would be excess stress put on the drivetrain.</strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">The difference is negligable - Every 4 banger YJ has 4.10 in the front and 4.11 in the rear. The reason is that the ring gear diameters, being different, require a "best fit" match on the number of teeth that will fit within the diameter. Hmmm...this isn't real clear...imagine a 6" circle, suppose you want to stick 60 points around the circumference - ok fine..now you want to do the same with a 7" circle but it has to turn at the same relative speed as the 6" circle...hmmmm. What they do is determine what's called the "best fit".
I realize this explanation may be a bit cloudy but it sure is clear in my mind!
BTW - Mud bog folks run a 4.56 rear and a 4.10 front (or something similar) - not something we would want to do with out trail rigs.
Steve
post #6 of 11 Old 05-13-2002, 07:42 PM Thread Starter
Wolfpack97
Thanks everyone. I talked to my mechanic and he said this setup would be fine, no problem. He agreed that lots of vehicles run different ratio numbers in the front and rear because the "diameter" or size.
Thanks again. I am having them installed tomorrow!!!!
post #7 of 11 Old 05-14-2002, 09:28 AM
blackjeep
if you still dont understand, and if i recall right you can go to randy's ring and pinion web site and it will explain to you. I dont know the address but it will come right up if you search it.
95 wrangler 1.5" springover Dana44 front Ford8.8 rear 4.10's 35x12.50 MTR's
blackjeep is offline
post #8 of 11 Old 05-14-2002, 10:01 AM
ezgoing
ezgoing's Avatar
I believe I understand why it is done now. Thanks.
'92 YJ Sahara
ezgoing is offline
post #9 of 11 Old 05-17-2002, 12:23 PM
PA Mud Puppy
Also, as a general rule, if the ratios are within 2% of each other, you will be ok. It won't cause any damage.
PA Mud Puppy is offline
post #10 of 11 Old 05-18-2002, 12:18 AM
kidwired
kidwired's Avatar
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by PA Mud Puppy:
<strong>Also, as a general rule, if the ratios are within 2% of each other, you will be ok. It won't cause any damage.</strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">I concur, this is correct
94 yj SOA +3.5", 35" swampers.
kidwired is offline
post #11 of 11 Old 05-18-2002, 11:12 PM
kegmaster
i thought it was 4%, but o well. As long as you dont drive in 4w on the road it wont do anything.
96 XJ 3" ome with 33s.
kegmaster is offline
this thing is the..... herbiehind Fabrication Shop 1 12-03-2009 08:13 PM
What is this thing??? Jaden539 General Jeep & Off-Road Equipment 3 12-18-2008 08:17 PM
Is there such a thing as a D44 manual? UKJeepThang Engines & Drivetrain 2 11-14-2008 12:00 PM
best thing to use djXternal Audio, CB & Ham Radios, GPS, & Electrical 3 09-28-2007 03:15 PM
any thing i should know? king_kong General Jeep & Off-Road Equipment 8 02-19-2007 03:00 PM
