3.73 or 4.10/4.11 i know you have heard this before - JeepForum.com
post #1 of 4 Old 09-10-2001, 05:40 PM Thread Starter
mytjnamedrex
Im planning on running 33x12.5 bfg m/t. I have the I-6 and a 5-speed. I am going to put on chip/exhaust/intake. I need to still effectively use 5th and will be spending about 90% onroad. Im learning to 3.73's but i cant find the 3.73s for the front d30 on a 97 tj. Any help would be good. Also how are the trac-loc limited slips? should i put them on? Does anyone know about the strength of a d35 with a trac-loc limited slip?? I need help cause im gonna change gears within the next week.thanx
97 TJ w/ Hardtop/AC/5-speed/I-6/ aftermarket stereo/ 2" spacer/1"BL/ 32x11.50 BFG AT's.
....that sounds expensive..
mytjnamedrex is offline
post #2 of 4 Old 09-10-2001, 08:22 PM
Wicked YJ
I'm running 4.10 with 33X12.50's. Running a locker, with bigger tires makes it more likely to break an axle. But since you are doing more road driving, I don't think you have to worry about that.
94 Red YJ
4" RE lift, 2" body lift, 4.10 gears, ford 8.8 in the rear, powertrax No-Slip in the rear, lockrite in the front, complete custom roll cage by Carolina rock shop, and corbeau seats and 5pt. harnesses, and of course herculined
Wicked YJ is offline
post #3 of 4 Old 09-14-2001, 09:56 PM
Nightclaw
I don't know about the TracLok, but let me tell you - a crappy little EZLocker screwed my D35C six ways from Sunday. It's to the point now that I'm looking at an axle swap, just to have a drivable rig. And this happened with 30x9.5" BFG AT-KO's and 3.07:1 gears. I don't wheel very often either - last time my tires kissed dirt was six months ago...
Bottom line is (from my personal experience, anyway), if you do ANY mods involving the driveline south of the transfer case, don't expect the D35C to live very long.
I'm not saying you shouldn't gear up and go for better meats, just that when it breaks, don't be too shocked. It's a simple fact of life with the D35C. Argh...
Nightclaw is offline
post #4 of 4 Old 09-15-2001, 08:38 AM
osburn
osburn's Avatar
In direct contradiction to that, I ran 33s on stock axles equipped with 4.10s and ARBs. I firmly believe the life of your axle significantly increases with lockers. The real reason more locked axles break is because people who run lockers, tend to run harder obstacles. If you ran the same obstacles without lockers, you would only break sooner attempting them. I never busted an axle shaft. I ran the Rubicon, Dusy-Ershim and Jackhammer on stock axles. Not to mention scores of other trail rides.
One of the advantages I felt I had was that the ARBs are not engaged on the street. If you can't turn the locker off, then it is still trying to function on the road too. This does create stress on shafts, joints, yokes and other drivetrain components.
If you want to do tough trails, you're going to reduce the stress on your axles by being locked. If you want to use your Jeep as a daily driver you're going to reduce the stress on your axles by being open. The solution seems too obvious to me. But, if my opinion was fact, then there'd be no such thing as a locker debate.
On the subject of gears, I ran 4.10s with 33s. I installed the 4.10s when I installed the ARBs which was when I was running 31s. Had I known I was going to 33s, I would have installed 4.56s. So in my opinion, the 3.73 gears aren't even a consideration.
I should qualify my opinion by letting you know I'm not a casual four wheeler. I'm in pretty deep and so my opinion is from a more hardcore perspective. But you should also know that my Jeep is still my daily transportation to and from work. I'm runnin 5.13s in the diff now.
Matt Osburn
Score 1032
osburn is offline
Anybody heard of these??? rgingerelli99tj Tires & Wheels 1 09-12-2007 11:50 PM
Anybody ever heard of this or tried/use it happymudder10 Tires & Wheels 3 07-13-2007 07:03 PM
Anyone heard of OE Wheels?? jeff601 Tires & Wheels 7 06-22-2007 08:47 PM
Have you heard of these tires? Meatroach Tires & Wheels 13 11-23-2006 08:14 PM
Have you heard of this? vzbjeep Engines & Drivetrain 2 09-30-2005 03:50 PM
