1994 Jeep No Brakes - JeepForum.com
post #1 of 8 Old 10-07-2013, 10:35 AM Thread Starter
carlakins
1994 Jeep No Brakes
I am sure this has been a question a lot, I have a 94 sport, I replaced the front left brakes almost 1 month later the brakes fail. I have replaced both front and replaced the booster, I have bled, bled and bled. When I replaced the booster I cleaned the mc just with brake fluid then I primed it, I sunk it in a vat of fluid and pumped it by hand. The installed and re-bled the system. I have good pedal until I start the car, then all the way to the floor. Any ideas? Please help. Thanks
carlakins is offline
post #2 of 8 Old 10-07-2013, 02:58 PM
mountainjock
1988 XJ Cherokee
What kind of Sport do you have? (XJ, Wrangler, etc...) Go to that models tech forum page and post your question there. Or maybe if you post up your model, a moderator will move it for you.
COLORADO JEEP CLUB MEMBER # 312
88 XJ 3" Pro comp lift 31/10.50
231 TC
4.0 I6
mountainjock is offline
post #3 of 8 Old 10-07-2013, 03:44 PM Thread Starter
carlakins
Thanks for the update model is Wrangler 2 door str 6. 2wd
post #4 of 8 Old 10-07-2013, 05:15 PM
uberxj92
1992 XJ Cherokee
Sounds vacuum related to me. Any hissing?
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #5 of 8 Old 10-07-2013, 05:23 PM Thread Starter
carlakins
Well when you press the brake it makes that noise only when the motor is on.
post #6 of 8 Old 10-07-2013, 05:25 PM Thread Starter
carlakins
Just replaced the booster brand new
post #7 of 8 Old 10-07-2013, 09:51 PM
jokerchief462
New or reman??? Sometimes the remand are bad right out if the box.
Sent from underneath my Jeep
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #8 of 8 Old 10-08-2013, 03:22 PM
uberxj92
1992 XJ Cherokee
Sounds like an OBF. OUT OF BOX FAILURE. It happens.
uberxj92 is offline
