1977 DJ-5F Postal jeep help needed - JeepForum.com
post #1 of 9 Old 05-14-2011, 04:26 PM Thread Starter
ANTEC900
Okay I recently bought a 1977 dj-5f jeep and need some help with finding stuff for it
What i need to know
What transmission it has
What transmission fluid do I use in it
And does anyone know where to get a manual for it
I will update with more later
ANTEC900 is offline
post #2 of 9 Old 05-16-2011, 05:18 AM Thread Starter
ANTEC900
Okay I found out it has a torqueflite 727 transmission
Now I need to find out where to get a manual for it
ANTEC900 is offline
post #3 of 9 Old 05-17-2011, 04:47 AM
TheBeardedPilot
you can google manuals most of the time and view them in PDF formats.
TheBeardedPilot is offline
post #4 of 9 Old 05-17-2011, 07:14 AM Thread Starter
ANTEC900
i used google but cant find any on it
ANTEC900 is offline
post #5 of 9 Old 05-17-2011, 06:19 PM
rjbruzan
Its a Mopar trans. Look for a Dodge manual.
rjbruzan is offline
post #6 of 9 Old 05-18-2011, 07:08 PM
baldfatdad
1984 CJ8
Usually says on the dip stick what fluid to use. My 904 which is a lighter duty version of the 727 uses Dextron. Chrysler trans are usually checked in Neutral, hot with the engine running, e brake on. Most trans are checked in Park.
I think it says that on the dip stick too.
baldfatdad is offline
post #7 of 9 Old 05-20-2011, 05:17 AM Thread Starter
ANTEC900
my grandpa has manuals on the trans
Just need one for the whole jeep
I know how to check it I just need to find out how much fluid should be in it. the dip stick does not have a full line from what me and my grandpa can tell
ANTEC900 is offline
post #8 of 9 Old 05-20-2011, 07:45 AM
baldfatdad
1984 CJ8
It should hold 8-10 quarts if it was dry. That would be a trans that just came from a rebuild. 4-5 quarts if you change the fluiid. Look for a notch or two on the dipstick, that would make the fluid. If there are no marks at all, I would put enough fluid to get it a couple inches up the dip stick- hot, in N, with engine running.
You might check the CJ8 forum. They have a thread on CJ8 postals.
post #9 of 9 Old 05-20-2011, 10:17 PM
bikerjr1
This link should help you out http://www.postal-jeep.com/
The DJ's were both right and left hand drive, most had the straight 6 with 727 tranny, not sure on the rear axle it wasn't heavy maybe a 20.
JR
bikerjr1 is offline
Any other DJ5 Postal Mail Jeep owners? ex-officio Street Jeep Forum 71 11-13-2015 09:41 PM
cheap fix Pax seat for Postal jeep ddgofer Cheap Tricks & Fixes 0 11-11-2010 01:33 PM
New owner of a 1972 Jeep DJ LHD aka Postal Jeep James_Van_Thach General Jeep & Off-Road Equipment 0 06-02-2010 07:05 AM
258 for postal jeep ineedsoap16 Engines & Drivetrain 3 08-04-2009 06:39 PM
postal jeep wild_jeep General Jeep & Off-Road Equipment 2 01-14-2009 06:36 PM
