10,000 lb. Chicago Winch Question - JeepForum.com
post #1 of 9 Old 08-29-2008, 03:50 PM Thread Starter
Klint96XJ
Hey guys, I just bought a used winch. It is a 10,000 lb Chicago winch, with control box, Remote, Mounting plate, and roller fairlead. I bought it for $200.00 at a wholesale warehouse.
When I got home I streched the cable out which is about 105 ft long, then I wound it up. After I got done winding it all up, the motor seemed pretty warm. is that normal for pulling in 105 ft of cable? or should I be suspicious? The winch and Cable look brand new, so I didn't expect it to get that warm.
I've heard good things about chicago winches lasting a long time.
I've never owned a winch before, so any other advice you can give me that might make a winch last would be great.
Thanks Klinton
Klint 96 xj
Klint96XJ is offline
post #2 of 9 Old 08-29-2008, 04:07 PM
sprintagogo
A friend of mine got one of the cheaper winches (a T-max I think) but the drum and motor got worryingly hot so we had to leave the steel rope on it rather than running a synthetic which is heat sensitive and then returned it for a refund as soon as we got back.
Rollin on 32'zzzz
Originally Posted by Muddeprived View Post
Who's eric?
Originally Posted by HornedFrogHooah View Post
Sprintagogo, you're absolutely amazing. I don't care what they say about yall over across the pond - you're a godsend!
sprintagogo is offline
post #3 of 9 Old 09-06-2008, 12:33 AM
bushytails
Those winches often run hot... with no load, they'll often run much hotter letting the line out then pulling it in - the brake is in the drum, and the motor has to overpower the brake to power out the cable. This is why, as the last poster said, synthetic lines are bad on those winches. Get an 8274 instead.
--Bushytails
bushytails is offline
post #4 of 9 Old 09-06-2008, 02:59 AM
sprintagogo
--Bushytails
I forgot to mention, the other reason we returned that El Cheapo winch was that it payed out slightly faster than it wound in????? It got hot in either direction though???
Rollin on 32'zzzz
Who's eric?
post #5 of 9 Old 09-06-2008, 11:00 AM
bushytails
Quality control is not a major factor in their manufacturing process, to put it politely.
--Bushytails
post #6 of 9 Old 09-12-2008, 10:05 AM
GRI
I never heard much good things about those winches. Their atv winches work alright but the heavier ones arent very good.
82 cj7, 258, 2150 carb, no rust on tub or body, solid frame, B&M quickshift, offroad lights, tfi ignition, clifford intake, header
for sale $2950 or trade for utility quad
send me a PM
GRI is offline
post #7 of 9 Old 09-12-2008, 07:08 PM
COBY
my winch also gets warm with no load if i pull in all the line at once i don't think it is a problem
COBY is offline
post #8 of 9 Old 09-16-2008, 04:41 PM
sprintagogo
My Warn doesn't get warm when spooling on 100' of rope even under some load.
Rollin on 32'zzzz
Who's eric?
post #9 of 9 Old 08-15-2011, 12:00 AM
SuperGlue
1989 XJ Cherokee
I have personally watched mine lift the front of my fullsize k5 diesel blazer off of the ground straight up when I rolled it
SuperGlue is offline
Chicago Electric Winch???? XXX_4X4 General Jeep & Off-Road Equipment 16 01-05-2009 08:09 AM
Chicago electric winch Sanford_ General Jeep & Off-Road Equipment 6 08-27-2007 04:02 PM
More Chicago Electric Winch Problems Forumpete58 General Jeep & Off-Road Equipment 7 09-28-2006 12:29 PM
chicago 10,000 lb winch motox851 General Jeep & Off-Road Equipment 10 09-02-2006 11:43 AM
Chicago Winch? jeepin95 General Jeep & Off-Road Equipment 5 10-04-2004 10:22 PM
