Go Back JeepForum.com > Jeep Registry > Wagoneer > Schooner Wagon
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineWIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ
Schooner Wagon Jeep Registry
Previous Jeep Wagoneer Next Jeep
Schooner Wagon
Email Bookmark Print
thumperjohn151
Bremerton
Jeep Information
Year:87
Model:Grand Wagoneer
Engine:360
Transmission:3sp auto
Axle Gear Ratio:3.72:1
Suspension:7leaf front - 3 leaf rear
Tires:235x75x15
Wheels:Alloy spoke e/w center caps
Armor:stock
Recovery Gear:???
Future Modifications:re-arch rear leafs - add 2 leafs
My first Jeep - just what I wanted. Had 67k original miles when I got it - Put 8700 my 1st x-country trip. Discovered what vapor lock is. . . and the cure.
Looking forward to many more adventures (after a few tweaks..).
None
Login Or Register To Post Comments
leafs13
View leafs13's Jeep
09-04-2011, 01:30 AM
So what's the cure :?
thumperjohn151
View thumperjohn151's Jeep
09-06-2011, 02:14 AM
Vapor Lock - The cure
Evidently, these things are notorious for Vapor Lock. . . I did not know this (all these years…). After all these years, and all the miles, and all the road conditions, I had never personally experienced Vapor Lock. Didn’t show up until I left on the trip from WA to CO - Like to drove me nuts!!! I thought I had a defective pickup, or clogged sock, or a hole in the fuel line, or anything but vapor lock.
For the Jeep, as probably ANY vehicle suffering this problem it’s the HEAT, literally “boiling” the fuel. Add to that Alcohol, and the boiling point gets even lower. Add to that the “vacuum” of pulling the fuel forward from the tank, and the vaporizing point gets lower still
The cure – I finally found a mechanic outside of Cheyenne, WY, that was familiar with these vehicles, and their inherent problem. The solution. . . install an electric fuel pump (PSI/GPM for carbureted vehicle) just off the output/pickup from fuel tank – as close as possible. PUSH the fuel. You don’t have to bypass the original mechanical fuel pump – it’s fine where it is. DO REMEMBER that on these vehicles (these model years) the fuel filter has a vapor bypass/return – this needs to be turned/twisted so it’s at the ‘top’, so that any vapor that comes through the line rises and goes out THAT return line.
Connect the power to the ignition, or an AUX switch. Insure the proper wire size (AWG) and circuit protection (FUSE). Good luck.
ThreadThread StarterForumRepliesLast Post
The Battle Wagon armair1 Wagoneer 2 09-04-2011 01:01 AM
War Wagon CutterN55 Wagoneer 5 04-30-2011 12:23 AM
