Go Back JeepForum.com > Jeep Registry > Wagoneer > Big Black
Poison Spyder DeFenders™ - "Tubeless" Jeep FendeBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Big Black Jeep Registry
Previous Jeep Wagoneer Next Jeep
Big Black
Email Bookmark Print
ramblerguy
Jeep Information
Year:1982
Model:Wagoneer
Engine:360
Transmission:Torque Flite 727
Transfer Case:308
Front Axle:Dana 44
Rear Axle:AMC 20
Axle Gear Ratio:3.42
Suspension:Stock
Tires:Stock 15's
Wheels:Stock aluminum
Armor:Non
Recovery Gear:None
Started out as a factory 2 wheel drive wagoneer that the previous owner had installed a 454 Chevy motor, transmission and 12 bolt rearend into. I bought it without any running gear, aquired everything to turn it back to all AMC specs. Rebuilt a 360, the transmission, transfer case and front and rear diff's. Had to install a pair of wagoneer frame engine mounts as the original ones had been cut out to install the 454. Also had to rewire the engine compartment as the original wiring harness was cut off at the firewall(******* could have just unplugged it). Still doing some minor work but it runs and drives great. Will post pictures soon.
None
Login Or Register To Post Comments
