Go Back JeepForum.com > Jeep Registry > Wagoneer > 1990 Jeep Grand Wagoneer
Rough Country Lift Kits and Parts!Ruffstuff 10 year saleSmittybilt XRC M.O.D Bumper and Brush Guard
1990 Jeep Grand Wagoneer Jeep Registry
Previous Jeep Wagoneer Next Jeep
Email Bookmark Print
timcav
Jeep Information
I have a battery drain problem. I noticed that everything that should work, works. Headlights, wipers, horn, etc. However, in order for the tailgate window to operate from the main switch, I must get out of the jeep, walk to the back, and push on the tailgate. Then, the tailgate window will operate. There are other problems that I continue to work on, bad fuel sending unit connections, relays and all. I wondering if this (the tailgate issue) would slow drain a good battery. The cargo light is out when the door is closed, but not enough to operate the window from the main switch. I believe I can adjust the tailgate to a more secure position. Any suggestion will be helpful. Thanks.
None
