wheeling, eating and drinking - 9/21 - Page 9 - JeepForum.com
post #121 of 149 Old 09-24-2013, 12:40 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Moose, if you'd like you are welcome to stop by & we can remount the flare. Just call first to ensure I'm home.
Roberto - same with you. I'm sure I'll be doing something with my POJ.
Joe Dillard is offline
post #122 of 149 Old 09-24-2013, 01:44 AM
wtfcrunch
I'm free after 6 as well if stockers can join?
-_________________-
Tyler Laros
San Diego, CA
wtfcrunch is offline
post #123 of 149 Old 09-24-2013, 04:00 AM
brokenyoujoint
Im free Wed Thurs and Fri.
brokenyoujoint is offline
post #124 of 149 Old 09-24-2013, 10:01 AM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
Originally Posted by BigD97TJ
That was a fun day! Thanks again to you all that helped me get off that trail, I owe you all a beer! I won't be doing that again!(at least I'll try really hard not too.) Looks like I'll be sourcing a HP Dana 30 with 3.55 gears along with a ZJ V8 tie rod.
That axle is in 99% of 4.0 auto Cherokees. Easy find
1990JEEPXJ is offline
post #125 of 149 Old 09-24-2013, 02:49 PM
Climbit
just so you know, an hp30 and lp30 use the same shafts, ujoints, and balljoints.
Where you broke, will not be upgraded by an hp30.
Not that it isn't a worthwhile swap.
But you would be better off with a set of chromo shafts, and CTM u joints.
Climbit is offline
post #126 of 149 Old 09-24-2013, 02:59 PM
brokenyoujoint
Junkyard hp30, aftermarket shafts, 1310 ujoints and a lighter foot will get you MUCH farther.
post #127 of 149 Old 09-24-2013, 03:37 PM
Climbit
The 1310 u joint is what your driveshaft runs.
760x is what you were thinking. Which he already had (all TJs do) and failed
A lighter foot is a must.
The money is best spent on chromo shafts and quality ujoints like a CTM.
High pinion doesn't change anything with the outer. But it does give you great driveshaft clearance and a slightly stronger pinion.
Climbit is offline
post #128 of 149 Old 09-24-2013, 03:56 PM
brokenyoujoint
your right... Your 230pm is my 230am... brain fart. With chromo shafts (450.00) and ctm joints(210.00 each), hp30 (200.00) he's already at a grand WITH OUT gears or a locker.the next thing to fail is the ring gear or pinion. I'd rather lose a joint than something in the case. He's running bone stock 3.55's. With ctms, chromo's he's gonna then want a locker and better gears. Then he's gotta do the rear to match. Can of worms unless that's his direction (which, sooner or later will be). For the way he is NOW he just needs to throw a xj front end at it and carry around some extra shafts and run new 760x joints. Save A LOT and then step it up. He needs to get it driving right now. Who knows. Maybe he didn't wallow out the ball joint holes and he can just repair what he has. Either way IMO a stock xj 30 is good for now. He'll just have to shorten his ds and he's done. Save for a REAL front end.
post #129 of 149 Old 09-24-2013, 04:34 PM
sdmoose429
Thanks for the help, Joe. I wouldn't have gotten it done nearly so quickly by myself.
Happy Trails, Moose KF7ITJ
"The difference between men and boys is the price of their TOYS!"
sdmoose429 is offline
post #130 of 149 Old 09-24-2013, 04:43 PM
Climbit
I somewhat agree...
but if he builds up his 30 a bit to survive, he will have something with a decent resale value that could put him on his way to a "real" front axle.
this is the reason why I haven't 3 linked my rig yet, I don't want to hack up the brackets on the axle, I can get a lot of money for it if it's bolt in.
Climbit is offline
post #131 of 149 Old 09-24-2013, 05:07 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
I know this is trivial but he already has an Aussie up front.
post #132 of 149 Old 09-24-2013, 06:31 PM
Climbit
Iirc the Aussie will swap Into an hp30
Climbit is offline
post #133 of 149 Old 09-24-2013, 08:17 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
I would think so
post #134 of 149 Old 09-24-2013, 08:32 PM Thread Starter
jbolty
jbolty's Avatar
Originally Posted by 1990JEEPXJ View Post
I would think so
yes. fits HP and LP, same part
jbolty is offline
post #135 of 149 Old 09-24-2013, 10:06 PM
Joe Dillard
Opps, I haven't been on here much today.
We are still at it. Waiting for some gasket sealer to dry so we can test a Rubi's cooling system that we just replaced a water pump & thermostat.
