San Diego Area - Page 900 - JeepForum.com
 60Likes
post #13486 of 40896 Old 04-24-2009, 11:30 AM
92 Green YJ
92 Green YJ's Avatar
so does anybody know anything about fixing hot tubs? I've been working on mine for over a week and im still having problems. Its a del sol spa. when I fired it up it gave me a code FL 1 on the display panel. according to the manual this code means:
Pressure switch is not closed when the pump is activated. Heater is deactivated. Proper flow of water is inhibited or pressure switch has malfunctioned. Check for proper water level, pump is primed and/or clogged filter. Contact a qualified service technician.
So I ordered a new pressure switch first and tried that. same deal and the jets were not running at all. so I broke down and called someone. he came out and said my pump and motor were shot. so I ordered a new pump and motor and after a minor wiring snafu (the booklet that came with the pump had a different wiring diagram than the one thats actually on the pump) I got the new pump installed and wired correctly.
Now when I turn it on the low speed jets work and it cycles up. However the heater light is not coming on. I left it on over night and the water temp only rose 6 degrees. its still giving me the same code. and now when i try to activate the high speed jets it blows the fuse in the control panel.
So does anybody know about this stuff?
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #13487 of 40896 Old 04-24-2009, 11:44 AM
MooJr
Originally Posted by Jeebs View Post
Nate I'm home if you wanna swing by. Gimme a call before heading over.
Ended up having to work on my uniform. (Forgot about the inspection today, Whoops)
Originally Posted by RikRotorhead View Post
Where did you get them and how much did you pay?
I went to the stealership today and they wanted $26.50 each, and you have to order them. Ebay has them much cheaper.
Product Information
Product Name Part No. Quantity Item Price Total Price
1997-04 JEEP WRANGLER SIDE MARKER LIGHT INSIDE FENDER OF FLARE, DRIVER SIDE
CH2550120-8 1 $7.20 $7.20
1997-04 JEEP WRANGLER SIDE MARKER LIGHT INSIDE FENDER OF FLARE, PASSENGER SIDE
CH2551120-2 1 $7.20 $7.20
Subtotal: $14.40
Shipping & Handling: $8.01
Tax: $1.26
________________________________
Order Total: $23.67
Shipping is high but cheapest price i could find
edit: forgot the URL https://www.tnaautoparts.com/
Your local neighborhood Noob - Nate
MooJr is offline
post #13488 of 40896 Old 04-24-2009, 12:34 PM
EJames1226
EJames1226's Avatar
Scott/Jeff, i completely removed the shafts, except i forgot about the fork on the passenger side. that would probably help right.
Im very confused though, it was making a TON of noise, the sound of metal ratcheting against metal, but the oil is fine, and there are no metal shavings, and everything looks fine so far...
Maybe its not the locker after all.... maybe something like the shift fork, with that stupid posi lock thing that we did?
Damage Initiation Specialist: Eric's Jeep Repair Club, San Diego Chapter
EJames1226 is offline
post #13489 of 40896 Old 04-24-2009, 12:40 PM
92 Green YJ
could be. I told ya, I tried the posi route but I kept snapping the forks, so I finally just tore the whole damn thing out and swapped in a one piece inner from an XJ and I've never looked back.
My
post #13490 of 40896 Old 04-24-2009, 12:40 PM
Jeebs
2015 JK Wrangler
Eric I thought you were selling the Jeep.
Jeebs is offline
post #13491 of 40896 Old 04-24-2009, 12:45 PM
EJames1226
EJames1226's Avatar
Thing is though, we did the posi lock after the very first time the axle started making the noise and it didnt do anything for the noise. When we added more thrust washers to hte locker it fixed it temporarily.
How many times have i been selling my jeep? 12 times i think. You cant take me seriously when i say that anymore. I could eather sell it and buy a peice of crap and be miserable. Or keep it, and fix it, and then be happy. Im just short on funds do to lay offs.
post #13492 of 40896 Old 04-24-2009, 08:19 PM
ductape1000
ductape1000's Avatar
Hey Jeff,
What time tomorrow works for you?? I want to make sure that I leave early enough to help push that truck up your driveway!
The only thing I know is ... I know nothing!!
Insert clever saying by someone well known here...
ductape1000 is offline
post #13493 of 40896 Old 04-24-2009, 08:36 PM
RikRotorhead
my original hard doors had the pin style latch. all I had to do to convert to those was remove the pin latches and actual pin piece and put the flat bar style capture things on instead. that being said, they are really finicky, usually have to try 3 or 4 times to get my doors to close and latch
So do you want me to bring them with me tomorrow? Will you be at Jeff's wrenching party?
Originally Posted by AyalaLJ View Post
Hey Jeff,
I'll be leaving Murrieta about 7-7:30. Takes me about an hour to get to SD.
Jeff, can you PM me your address so I know where I'm going?
I'm bringing Richie with me. We are going to tow my Jeep behind his truck. He needs to leave early, so I'll drive it home. Are we doing LW tomorrow?
Premo, we will be throwing that item you wanted into the back of his truck.
Zombies hate fast food.
RJC#512
RikRotorhead is offline
post #13494 of 40896 Old 04-24-2009, 09:07 PM
jbolty
jbolty's Avatar
Hey Jeff,
Any time. I'll be here all day. I have to return the tow dolly sometime in the afternoon.
jbolty is offline
post #13495 of 40896 Old 04-24-2009, 09:19 PM
ductape1000
Ok. I'll shoot for about 10:00 to be at your place. See you then. Thanks again for the invite!!
post #13496 of 40896 Old 04-24-2009, 09:41 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Jeff, will you be ready to rock & roll by 5:00AM tomorrow???? I'll bring a drop light & some candles.
My ol' lady has to work again tomorrow so Joe = a free man.
Joe Dillard is offline
post #13497 of 40896 Old 04-24-2009, 09:46 PM
Joe Dillard
Scott, maybe PM this guy - he goes by SpaComponents (or something like that).
http://www.jeepforum.com/forum/f15/new-goodyear-mt-r-kevlars-duratracs-760661/
post #13498 of 40896 Old 04-24-2009, 09:49 PM
jbolty
jbolty's Avatar
better make it 5:30 so the coffee will be ready.
jbolty is offline
post #13499 of 40896 Old 04-24-2009, 10:32 PM
EJames1226
EJames1226's Avatar
FYI it aint comin out. if someone wants to bring a pry bar up here that would be great.
post #13500 of 40896 Old 04-25-2009, 12:11 AM
jeeps123
question - how do i find those youtube videos of the dudes jeeping somewhere near here - was it wildcat canyon? lyons valley? - where the cops show up at the end? I remember the guy who posted them saying that he went offroading with the cop in question, so everybody got off with a warning or something
I can't find them again for the life of me!!
free or cheap
jeeps123 is offline
San Diego Meet and Greet, Jan 2nd 11AM Fiesta Island Jeebs SanDiego 243 12-28-2012 06:30 PM
Monster Jam San Diego (January 23rd) Delta347 SanDiego 7 01-09-2010 09:32 PM
