San Diego Area - Page 899 - JeepForum.com
 50Likes
post #13471 of 40827 Old 04-23-2009, 07:39 PM
Jeebs
2015 JK Wrangler
Change of plans for me. I'll be dropping a 4.0HO from a '98 TJ in the CJ this weekend.
Jeebs is offline
post #13472 of 40827 Old 04-23-2009, 08:38 PM
EJames1226
EJames1226's Avatar
Jeff do you have any tips to getting the carrier out of the axle?
Damage Initiation Specialist: Eric's Jeep Repair Club, San Diego Chapter
EJames1226 is offline
post #13473 of 40827 Old 04-23-2009, 10:07 PM
RikRotorhead
I'm not Jeff, but....
If you are alone, place a crumpled up towel or blanket for a soft place for it to land on, make sure the axles are out far enough, and use two pry bars and apply equal pressure on each. Just pry it out. You can also give the carrier a couple taps with a rubber mallet to jar it loose a little first.
If you have help, have somebody catch it when it pops out.
Hope that helps.
Zombies hate fast food.
RJC#512
RikRotorhead is offline
post #13474 of 40827 Old 04-23-2009, 10:10 PM
StvDiego
Originally Posted by Jeebs View Post
Maybe its just a bad time to be selling something like that? People are slowing down on the extra fun stuff like lockers I bet.
Good time to be buying
This weeks haul: set of mirrors for the half doors and to replace the broken one on the full door; a set of Poison Spyder LED corner guards, JKS discos, a set of sliders and various bits and pieces
Originally Posted by jbolty View Post
Let's get it. What's the worst that could happen
Originally Posted by RikRotorhead View Post
Where did you get them and how much did you pay?
I went to the stealership today and they wanted $26.50 each, and you have to order them. Ebay has them much cheaper.
Sent you a PM
Whatever
StvDiego is offline
post #13475 of 40827 Old 04-23-2009, 10:17 PM
CRAWLING 98
Wheeler
CRAWLING 98's Avatar
jimmy needs that, since he has the super 35 already
Jimmy can't afford it at the present time.
Group W Bench
CRAWLING 98 is offline
post #13476 of 40827 Old 04-23-2009, 10:18 PM
SpydermanTJ
I'll throw them in the back seat and bring 'em with me.
From what I've read, the lower portion of the door area in all the tubs are the same, and it only changes with the windshield angle, which has no affect on the lower half doors. YJ doors fit CJs etc... but the latches are different on the newer Jeeps.
That's why I posted the question. What latches are those? Mine have a pin capture. Do you just remove the pin assembly and the latch just hooks the tub?
I meant for your party Rik! I can't make the one thats happening this weekend, but I'll be at yours in May.
I don't know how the latches are different, so I'll try em out and see what needs to happen. Thanks!
2000 4dr XJ 2WD, 4.0L auto
Gone, but not forgotten- 1998 TJ Sport
Nightcrew #162
"i'd want a bottle of 12 year old scotch and a 24 pack of rubbers. i'll go places with a hard-on that most people wont go with a mechanized infantry batallion."
SpydermanTJ is offline
post #13477 of 40827 Old 04-23-2009, 10:41 PM
jbolty
jbolty's Avatar
what Rik said. sometime brake cleaner will help if there is oil suction holding it but otherwise pry on something that is not a sealing surface or a gear.
jbolty is offline
post #13478 of 40827 Old 04-23-2009, 11:24 PM
CRAWLING 98
Wheeler
really ???????
LOL
Group W Bench
post #13479 of 40827 Old 04-24-2009, 01:53 AM
EJames1226
EJames1226's Avatar
Thanks thats what ive been trying (minus the brake cleaner). It comes out about 1/4" but thats it. If anyone wants to come over tomorow after 4, it would be greatly appreciated.
post #13480 of 40827 Old 04-24-2009, 06:33 AM
Poobah
Off Road Swap Meet, Saturday May 16th in Ramona
A JustRuns member is having a Jeep Swap Meet at his place in Ramona on Sat. 5/16, starting at 8:00am.
Local Clubs are invited to come and sell their stuff and clean out their old parts. There is no cost to sell.
There will also be kids selling drinks & hot dogs.
Address of the event:
330 Elm St.
Ramona, Ca. 92065
760-788-6557
. Green Jeep Club #99 . Tj Owners Club #299 . .
"What, me a cynic? I trust you have proof!"
Poobah is offline
post #13481 of 40827 Old 04-24-2009, 07:20 AM
ductape1000
ductape1000's Avatar
If anyone is serious, I have a utility trailer, and an appliance dolly. I am coming down to Jeff's on Sat. With a few people we could have some fun with it.
Set it up and let me know!!
The only thing I know is ... I know nothing!!
Insert clever saying by someone well known here...
ductape1000 is offline
post #13482 of 40827 Old 04-24-2009, 08:05 AM
CRAWLING 98
Wheeler
330 Elm St.
Ramona, Ca. 92065
760-788-6557
I don't belong to an official "CLUB" (does anyone remember this issue??) but I think that I will "crash" the party anyways.
Group W Bench
post #13483 of 40827 Old 04-24-2009, 09:01 AM
jbolty
jbolty's Avatar
Normally once it breaks free they drop right out. I know yours does; we have had it out enough.
Is the inner shaft on the pass side out enough?
Is it binding on the pinion?
jbolty is offline
post #13484 of 40827 Old 04-24-2009, 10:51 AM
92 Green YJ
92 Green YJ's Avatar
There's a typo or the guy doesn't know better...
3:55 is the case break down, 3:73 is the case break up. The one in the pic is definately a 3:55 down because the ring gear mount is too far from the center. The 3:73 moves the ring gear mount closer to the center to accomodate a smaller pinion gear. Just an FYI if you didn't know.
Quick!! .... Call Jeraldo Rivera!! It's Al Capone's long lost safe!
my original hard doors had the pin style latch. all I had to do to convert to those was remove the pin latches and actual pin piece and put the flat bar style capture things on instead. that being said, they are really finicky, usually have to try 3 or 4 times to get my doors to close and latch
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #13485 of 40827 Old 04-24-2009, 10:54 AM
92 Green YJ
eric, just try and twist the pinion a little. u have the front shaft out anyway. slap a monkey wrench on the pinion yoke and try to rotate it back and forth a little to see if it will work loose
My
San Diego Meet and Greet, Jan 2nd 11AM Fiesta Island Jeebs SanDiego 243 12-28-2012 06:30 PM
Monster Jam San Diego (January 23rd) Delta347 SanDiego 7 01-09-2010 09:32 PM
