San Diego Area - Page 881 - JeepForum.com
 46Likes
post #13201 of 40686 Old 04-09-2009, 10:25 PM
Jeebs
Jeebs's Avatar
I cannot stand all the retarded laws in this state!!!
Jeebs is offline
post #13202 of 40686 Old 04-09-2009, 10:30 PM
SuperMAN96
Originally Posted by 4x4grey88 View Post
Welcome to the Forum Alex and the San Diego section.
Can you provide more information on the issues one your Jeep? Making a noise is not really enough info.
Is it s squeak or a bang, or a pop, does it happen while turning ETC.
More info.
Ya, well i will put it in reverse and then turn the steering wheel left or right and it just makes this grinding noise and it just sounds not right. i took it in cause my check engine light came on and they showed me something on the front right wheel and when ever my wheel was turning there was something that looked loose and they said thats what it was, but i still dont know.
SuperMAN96 is offline
post #13203 of 40686 Old 04-09-2009, 11:53 PM
RikRotorhead
Stick around, it'll get worse.
And on top of that, if 1A passes, you'll pay more too.
Can you give a bit more detail of what they pointed at looks like, or better yet, take a pic, it would be easier to help you.
Does it look like a universal joint at where the axle comes out of the housing between the axle housing and the brake disc assembly?
Zombies hate fast food.
RJC#512
RikRotorhead is offline
post #13204 of 40686 Old 04-10-2009, 03:15 AM
BigMike80
Can your brute beat my brute?
http://blastbody.mybrute.com
Are you gonna bark all day, little doggie, or are you gonna bite?
-Mr. Blonde
Originally Posted by JPJeeper
Ok, so instead of putting something cool on your jeep, you are going to go stare at women? Isn't that what the Internet is for?
BigMike80 is offline
post #13205 of 40686 Old 04-10-2009, 07:16 AM
ankyle62
probably http://thislooksdumb.mybrute.com
ankyle62 is offline
post #13206 of 40686 Old 04-10-2009, 07:34 AM
jbolty
jbolty's Avatar
I will knock you out
http://jbolty.mybrute.com/
jbolty is offline
post #13207 of 40686 Old 04-10-2009, 10:48 AM
MooJr
Originally Posted by RikRotorhead View Post
Thought I'd bring the list forward a bit.......
Steve? Jason?
Im in +1 (wife) Camping
is the dog ok?
Your local neighborhood Noob - Nate
MooJr is offline
post #13208 of 40686 Old 04-10-2009, 11:16 AM
Poobah
Wow - your brute cheated - he was pulling out knives and spears and all sorts of stuff on me!
http://porkyboy.mybrute.com
My new Brute, PorkyBoy demolishes everyone!
. Green Jeep Club #99 . Tj Owners Club #299 . .
"What, me a cynic? I trust you have proof!"
Poobah is offline
post #13209 of 40686 Old 04-10-2009, 12:15 PM
MooJr
The bar moves back and forth from passenger to driver side when turning wheels.
MooJr is offline
post #13210 of 40686 Old 04-10-2009, 01:43 PM
RikRotorhead
Hopefully one of the TJ owners here can help you. Mine doesn't have that.
RJC#512
post #13211 of 40686 Old 04-10-2009, 01:57 PM
jbolty
jbolty's Avatar
Maybe just a worn out bushing, or is the bar broken? Should not be hard to see exactly where the movement is.
jbolty is offline
post #13212 of 40686 Old 04-10-2009, 01:57 PM
StvDiego
Track bar is loose, common. Also the most common cause of the dreaded DW. Also common after installing a lift.
Aren't Jeeps fun
Problem now is that the inside hole may be elongated. A lot of folks run without them, not something I would recommend on a DD.
You can tighten it down, maybe a new bushing and that should do it. Better plan is look for an adjustable track bar. That one will continue to work itself loose (there is an incredible amount of force working on that bar as you steer/drive) and eventually you'll start to experience DW (you're not really a True Genuine TJ Jeeper ® )
The trick is to have someone slowly turn the steering wheel (with the engine off) while laying under the front end and you'll be able to see it move.
do a search for Death Wobble, now that's exciting Jeepin
StvDiego is offline
post #13213 of 40686 Old 04-10-2009, 03:17 PM
Jeebs
Jeebs's Avatar
If ya aren't going to Corral Canyon or the JY I am doing a full day Jeep renovation. Its pretty much gonna be a tune-up on steroids. If anyone wants to lend a hand bringing the CJ up to standard let me know. All you can eat and drink BBQ and beer will be provided as usual.
Jeebs is offline
post #13214 of 40686 Old 04-10-2009, 06:47 PM
EJames1226
EJames1226's Avatar
Mike is this your jeep by chance?
Damage Initiation Specialist: Eric's Jeep Repair Club, San Diego Chapter
EJames1226 is offline
post #13215 of 40686 Old 04-10-2009, 07:14 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
If it's moving that much, odds are the mounting bolt hole is wallowed out/egg-shaped and tightening the bolt or installing a new bushing won't help for long. Better yet, have a hardened heavy duty washer welded onto the front of the bracket to beef it up and hold the bolt from being able to move.
Anyone with a welder can do that or if you don't know of any, come on up to Escondido Saturday and I can do it for you. PM me if you want to do that.
Getting
Jerry Bransford is offline
San Diego Meet and Greet, Jan 2nd 11AM Fiesta Island Jeebs SanDiego 243 12-28-2012 07:30 PM
Monster Jam San Diego (January 23rd) Delta347 SanDiego 7 01-09-2010 10:32 PM
