San Diego Area - Page 595 - JeepForum.com
 60Likes
post #8911 of 40895 Old 08-16-2008, 07:11 PM
Delta347
So was just talking with Sean the other day about things for the Jeep and was thinking about Dual Batteries. When you get two batteries running do you just use a splitter on the alternator cable? Since I have 2 alternators would it be a good idea to hook both up one for each, since I don't mind weight that much.
This probably won't happen any time soon but just wondering, unless my grandfather im visiting in Florida this week decides to put me to work and pay me with a pair of batteries.
Originally Posted by Leans93 View Post
So ghost has a plug in his hole and opihi has a gaping hole, Do I need to worry about this hole at all? I just don't want to start her up and have something spewing out of it.
Side Effects may include dry mouth, nausea, vomitting, water retention, painful recolage, hallucination, dementia, psycosis, coma, death, and halitosus. YJs are not for everyone please consult your physician before use.
Delta347 is offline
post #8912 of 40895 Old 08-16-2008, 08:39 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
Originally Posted by EJames1226 View Post
Looks like ya got an oil leak. That right thar is yur prablem.
eh, its on the list.
1990JEEPXJ is offline
post #8913 of 40895 Old 08-16-2008, 10:04 PM
PR1AWRet
2002 KJ Liberty
Looks like rust on the control arm bolt. Should be an easy fix. Since you'll have the bolt off, might as well change the arm out too.
PR1AWRet is offline
post #8914 of 40895 Old 08-16-2008, 11:39 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
ummmm.....i kinda do have to change the arm, thats what the thing i need to fix is.
(couldnt tell if you were being sarcastic or not) haha
post #8915 of 40895 Old 08-17-2008, 12:38 PM
Vern Britain
Try these guys. Ive been running duel Odessys for about 6 years. Not sure if their set up works with wet cells should though.
http://www.wranglernw.com/
Cant Dive 55
My Website
Vern Britain is offline
post #8916 of 40895 Old 08-17-2008, 12:42 PM
Jeebs
2015 JK Wrangler
Jeebs is offline
post #8917 of 40895 Old 08-17-2008, 12:54 PM
Poobah
I've been thinking about doing the dual battery thing for a while now as well...and I did a bunch of research a while back and I remember reading about the Odysseys having problems lately... I decided to go with the Mean Green setup and Optima yellow tops when I finally pull the trigger on this project. Let me see if I can find some of the links on the subject.
Ok - A quick Google found this - one of the places I saw where people are moving away from the Odysseys.
http://hamjeep.com/nwpdualbatt.htm
Here is an excerpt from that page - it looks like they are recommending exactly what I had decided on as well:
"ELECTRICAL SYSTEM ISSUE - CHANGED RECOMMENDATION
We have made a few changes to our Project Jeep in recent days. One of these was the replacement of the Wrangler NW Dual Battery Tray we have previously recommended.
It is an excellent product, but we encountered some problems with the Odyssey PC-925 batteries required by that tray.
The top terminals on those batteries are supposed to take a small amount of rotation. We found that the small amount they quote apparently exceeds what they will really take.
We had one of our Odyssey batteries fail when the top terminal became disconnected from the plates inside the battery and began to rotate freely.
Some research has found that others have encountered similar issues. It seems that the terminals on the Odyssey PC-925MJT and PC-925LMJT batteries may be too weak for this application.
We still recommend the Wrangler NW Battery Manager.
It is the best way to handle the installation of two batteries in your vehicle.
We also recommend their alternators.
We have one in the Project Jeep and it really helped out when we had the problems with the Odyssey batteries.
We now recommend the Mean Green TJ Dual Battery Tray and two Optima Yellow-Top D34/78 Deep Cycle Batteries.
The following review is included for reference and to show the Wrangler NW Dual Battery Manager..."
Poobah is offline
post #8918 of 40895 Old 08-17-2008, 04:04 PM
jbolty
jbolty's Avatar
You don't need dual batteries, unless you are doing a lot of winching with the engine off or some other high draw application. It is not cheap to get it set up properly.
jbolty is offline
post #8919 of 40895 Old 08-17-2008, 04:52 PM
jbolty
jbolty's Avatar
Pleeeeez help me with my towing problem.
http://www.jeepforum.com/forum/f12/yj-flat-towing-problem-595457/
jbolty is offline
post #8920 of 40895 Old 08-17-2008, 04:58 PM
StvDiego
So true...
Basic dual-battery setups:
1. Switch
Uses a heavy-duty battery switch, like on a boat, to switch between batteries; A: Battery 1; B. battery 2; C. Both Batteries. You would have to switch between batteries, and on both batteries would discharge on "both" position.
2. Relay
Similar to the switch method but uses a relay
3. Isolater
Wires in both batteries to charge each and isolates them from one another to prevent sympathetic drain. Isolaters are expensive and don't generally handle vibration and heat well.
You would also need two identical batteries of the same age and usage (basically two new batteries with the same manufacture date).
And after all that, unless you're going way out there by yourself (which we shouldn't do) or winch a LOT or have an insane audio/video system that draws major power, you really don't need two batteries. There's better things to spend money on
StvDiego is offline
post #8921 of 40895 Old 08-17-2008, 06:06 PM
PR1AWRet
2002 KJ Liberty
Being sarcastic.
PR1AWRet is offline
post #8922 of 40895 Old 08-17-2008, 06:20 PM
CRAWLING 98
Wheeler
CRAWLING 98's Avatar
Had a great time over the weekend on the trails. I had minor damage that is fixable.
Would have liked to seen Joe D out there but he missed out again.
Maybe next time Joe.
Group W Bench
CRAWLING 98 is offline
post #8923 of 40895 Old 08-17-2008, 06:50 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
Being sarcastic.
thats what i figured, hard to tell without smileys though.
post #8924 of 40895 Old 08-17-2008, 07:35 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Yeah. Suxs to have all sorts of household chores holding me back.
Good thing is....one of my best friends, along with his family, are coming to San Diego tomorrow to visit me from Washington State (Tacoma area). He's a fellow Jeep fanatic (has a YJ almost exactly like mine), and he was stationed aboard my last ship with me. We go back ~13 years.
Joe Dillard is offline
post #8925 of 40895 Old 08-17-2008, 07:55 PM
jbolty
jbolty's Avatar
Ok. I have stuff.
My friend is cleaning out his garage so I went over there today and got a HUGE old chain fall, some roof rack brackets, assorted tools, electric motors and other stuff. But the three key things are a pipe notcher, with a bunch of accessories, a front end alignment gauge and a 5th wheel hitch complete. If I sell any of it I agreed to split it, else it's all mine.
jbolty is offline
brokenyoujoint , Climbit
San Diego Meet and Greet, Jan 2nd 11AM Fiesta Island Jeebs SanDiego 243 12-28-2012 06:30 PM
Monster Jam San Diego (January 23rd) Delta347 SanDiego 7 01-09-2010 09:32 PM
