San Diego Area - Page 550 - JeepForum.com
 60Likes
post #8236 of 40899 Old 06-18-2008, 06:43 PM
jbolty
jbolty's Avatar
Look what brown did for me.
jbolty is offline
post #8237 of 40899 Old 06-18-2008, 06:59 PM
StvDiego
They brought you a shiny new penny?
sweet
StvDiego is offline
post #8238 of 40899 Old 06-18-2008, 08:25 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Hi Steve!
I think I'll drink a beer or two to your health, fast recovery, and tightening up that loose screw in your head.
Get well soon my friend.
Joe Dillard is offline
post #8239 of 40899 Old 06-18-2008, 08:34 PM
CRAWLING 98
Wheeler
CRAWLING 98's Avatar
Originally Posted by premo View Post
We're looking for something older though like a CJ or Willys or something...the more rustic looking the better
JasonP
Well mine looks to much like a MALL QUEEN, so I guess I'm out
Group W Bench
CRAWLING 98 is offline
post #8240 of 40899 Old 06-18-2008, 10:00 PM
Jeebs
2015 JK Wrangler
Any of you experienced motor heads available tomorrow? I'm pulling the head, valves and all the other associated junk off tomorrow. While the FSM and the Hayne's to a step by step, I still find it helpful to have someone with hands on experience around. I went a grabbed a valve spring compressor tool for the job as well (I thought I had one but no such luck). Anything else I might need?
Jeebs is offline
post #8241 of 40899 Old 06-18-2008, 10:43 PM
jbolty
jbolty's Avatar
I would leave the valves in place for now. If they are up to spec and reused they have to go back in the same place. No need of more loose parts to keep track of.
Sometimes the head is loosened in a certain order, similar to tightening; check the book for that.
just take everything off the outside, drop the oil pan and call it good for now. I would leave the pistons in place too; they have to go back in the same cylinder.
Next step is to get everything measured, see what parts you need, total it up and decide what to do.
I'll come by, if I can, after work.
jbolty is offline
post #8242 of 40899 Old 06-18-2008, 11:10 PM
Jeebs
2015 JK Wrangler
I grabbed some of that green "crafting" foam to stick the rocker arms, valves, push rods, etc in to keep them in order. I may not even keep them. The intake valves are covered in so much crap that you can barely tell they're round. Also, don't I need to remove the valve equipment to get to the cam to get it measured?
Jeebs is offline
post #8243 of 40899 Old 06-18-2008, 11:11 PM
Delta347
Soo here is a picture of the fire from the carb...which caused the Jeep to start working again. As well as a couple pics at fiesta island following the successful fixing!
So I finally decided what would be a good use for that broken axle shaft! Now I doubt any of you airsoft hardcore, but if you did you would know some scenarios allow vehicle use. So I was thinking If i fixed the shatter end and put a rotating joint with a U shaped mount for an Airsoft gun i could use the lug bolts to mount the shaft upright in the back of the jeep on the tub or some fabricated platform built to fit back there. Sound cool?
Originally Posted by Leans93 View Post
So ghost has a plug in his hole and opihi has a gaping hole, Do I need to worry about this hole at all? I just don't want to start her up and have something spewing out of it.
Side Effects may include dry mouth, nausea, vomitting, water retention, painful recolage, hallucination, dementia, psycosis, coma, death, and halitosus. YJs are not for everyone please consult your physician before use.
Delta347 is offline
post #8244 of 40899 Old 06-18-2008, 11:18 PM
jbolty
jbolty's Avatar
no, the cam is down in the block the distributor is driven of a gear on the cam.
jbolty is offline
post #8245 of 40899 Old 06-18-2008, 11:39 PM
Jeebs
2015 JK Wrangler
Oh yeah, not on overhead cam...
IIRC its kind up and to the left of the crankshaft right?
Jeebs is offline
post #8246 of 40899 Old 06-19-2008, 12:30 AM
premo
aside from a bent to crap bumper adn some rock damage on teh wheels/tires it cant be any worse then mine dude! haha
-Scottish proverb
premo is offline
post #8247 of 40899 Old 06-19-2008, 09:18 AM
Jeebs
2015 JK Wrangler
Jeff -
2004 Ford F350 Diesel, 4 door, 4X4 with a sticker of $11,000 in Poway
Jeebs is offline
post #8248 of 40899 Old 06-19-2008, 09:19 AM
Delta347
You know you own a YJ when you wake up at 420am and can't get back to sleep so you spend 4 hours straight in the YJ Technical Forum posting left and right.
Delta347 is offline
post #8249 of 40899 Old 06-19-2008, 09:23 AM
Delta347
Jeff -
In the event bolding it didn't help 'diesel'
Kinda makes it stick out >.> (as to why its going for cheap)
Is it from the dealer? Or someone trying to sell it?
Diesel = Bad For Gas $$$
Pick Up = Good For Us
11K = Awesome Price
Delta347 is offline
post #8250 of 40899 Old 06-19-2008, 12:01 PM
Joe Dillard
11K = Awesome Price
Perhaps I'm missing your points. Here's mine.
Typically speaking, diesel trucks hold a good value.
Yeah, diesel is currently selling for more $ than regular unleaded.
However, when I had my 2500 2wd gas truck, I'd get ~6-7 MPG's while having my camper on and towing.
With my much larger, much heavier, 3500 4wd diesel truck, I now get closer to ~12.5 miles per gallon and have gotten as much as 17+ MPG's while towing and the camper. That's close to doubling my fuel mileage at the lower end.
Plus, the diesel engine & drivetrain is far superior, and has far more power (~610 ftlbs torque vs ~375) and should outlast the gas drivetrain 3 fold or more.
San Diego Meet and Greet, Jan 2nd 11AM Fiesta Island Jeebs SanDiego 243 12-28-2012 06:30 PM
Monster Jam San Diego (January 23rd) Delta347 SanDiego 7 01-09-2010 09:32 PM
