San Diego Area - Page 547 - JeepForum.com
 46Likes
post #8191 of 40686 Old 06-15-2008, 09:42 PM
CRAWLING 98
Wheeler
CRAWLING 98's Avatar
Oh yeah. I forgot and the K&N filter set-up.
The best part about this up-grade was the price...$0.00
Group W Bench
CRAWLING 98 is offline
post #8192 of 40686 Old 06-15-2008, 09:55 PM
CRAWLING 98
Wheeler
This is what Steve's frame to upper control arm bracket looks like.
Group W Bench
post #8193 of 40686 Old 06-16-2008, 12:07 AM
jbolty
jbolty's Avatar
Two nice upgrades
jbolty is offline
post #8194 of 40686 Old 06-16-2008, 12:41 AM
Jeebs
Jeebs's Avatar
Well, Jeff and I ended up pulling the entire drive train today. Wednesday the cleaning begins (tomorrow is the US Open playoff round! ) and I'll go from there. Right now the plan is to do the rebuild but I won't object to an engine swap if the right deal comes around.
Jeff- You left your shades. I'm booked up tomorrow until around 7 so let me know what works for you beyond that.
Jeebs is offline
post #8195 of 40686 Old 06-16-2008, 04:49 PM
jbolty
jbolty's Avatar
Is it driveable like that?!?!?
jbolty is offline
post #8196 of 40686 Old 06-16-2008, 09:48 PM
BrandonTJ
BrandonTJ's Avatar
Mmmmmmm... Super-dooper-self-adjusting upper control arms!!
Brandon
Ham - N6VAN
BrandonTJ is offline
post #8197 of 40686 Old 06-16-2008, 10:32 PM
Jeebs
Jeebs's Avatar
A little trivia:
It took 75lbs of what to undue what Jeff and I did wrong yesterday?
Jeebs is offline
post #8198 of 40686 Old 06-16-2008, 11:55 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Originally Posted by NewBlue90 View Post
A little trivia:
Cat litter.
Joe Dillard is offline
post #8199 of 40686 Old 06-17-2008, 12:00 AM
jbolty
jbolty's Avatar
Cat litter.
You are correct sir. We did not drain the transmission, until it was on the floor. Plus the remaining coolant from the engine. The floor was an OSHA nightmare.
Joe,
Do you recall the torque for the D30 bearing caps. I am seeing conflicting numbers from 60-75#
Second, the FSM says not to reuse ring gear bolts. Do I care about that?
jbolty is offline
post #8200 of 40686 Old 06-17-2008, 12:22 AM
Joe Dillard
Joe, Do you recall the torque for the D30 bearing caps. I am seeing conflicting numbers from 60-75#
D30 bearing caps should be 60 ft lbs.
Technically, yeah, new ring gear bolts *should* be used. You MUST use Loctite/thread locker & torque them to 55 ft lbs on the D30.
Master install kits do include new ring gear bolts, but I suppose you could buy them seperately.
post #8201 of 40686 Old 06-17-2008, 01:03 AM
CRAWLING 98
Wheeler
It is until it lets loose all the way.
Steve might be needing a good welder VERY SOON (Jeff....)
Group W Bench
post #8202 of 40686 Old 06-17-2008, 08:20 AM
jbolty
jbolty's Avatar
Any time, I still suck at upside down welding though.
jbolty is offline
post #8203 of 40686 Old 06-17-2008, 11:24 AM
jbolty
jbolty's Avatar
Anybody here today?
I just got a call from Ari. He is stalled on the freeway and waiting for AAA to tow him home.
He stopped by the house last night and we set his timing, it was off by about 10 degrees. We did nothing else and touched nothing else so I assume it is coincidental.
I am going to stop by there on the way home to see what's up.
Anyone else avail to take a look today? Point Loma area.
jbolty is offline
post #8204 of 40686 Old 06-17-2008, 12:54 PM
Delta347
Well back home now.
Jeep still not starting, and no clue what is wrong.
Just ate so I am gonna go outside and do 2 things first, check all the fuses and take a look at the distributor without the cap on.
Basically she was running smooth, as i got on the freeway I had a lose of forward momentum, I felt the engine skip a couple beats, and started pulling over and then lost power completely. Figured it was the fuel pump, turned it back on and went about 100 ft before it **** out again for good.
As i was checking again i heard 2 loud metallic spark/rapping noises while the car was off.
My only non-electrical guess is since it rotates but wont start and has the clicking to ignite is maybe the fuel line is clogged somewhere?
Otherwise my best guess is something went zap zap boom. =(
Originally Posted by Leans93 View Post
So ghost has a plug in his hole and opihi has a gaping hole, Do I need to worry about this hole at all? I just don't want to start her up and have something spewing out of it.
Side Effects may include dry mouth, nausea, vomitting, water retention, painful recolage, hallucination, dementia, psycosis, coma, death, and halitosus. YJs are not for everyone please consult your physician before use.
Delta347 is offline
post #8205 of 40686 Old 06-17-2008, 02:15 PM
MooJr
What you where trying to weld didn’t help either tho. BTW im off at 1 everyday and my wife is leaving for a week and a half, so i got alot of free time if any one needs any help or whats to do something.
Your local neighborhood Noob - Nate
MooJr is offline
San Diego Meet and Greet, Jan 2nd 11AM Fiesta Island Jeebs SanDiego 243 12-28-2012 07:30 PM
Monster Jam San Diego (January 23rd) Delta347 SanDiego 7 01-09-2010 10:32 PM
