San Diego Area - Page 507 - JeepForum.com
 46Likes
post #7591 of 40700 Old 05-05-2008, 07:03 PM
Delta347
I feel so lucky,
The speedometer gears for 1990 are marked as officially discontinued -_-
But the records show Dodge produces the same-ish ones still.
Originally Posted by Leans93 View Post
So ghost has a plug in his hole and opihi has a gaping hole, Do I need to worry about this hole at all? I just don't want to start her up and have something spewing out of it.
Side Effects may include dry mouth, nausea, vomitting, water retention, painful recolage, hallucination, dementia, psycosis, coma, death, and halitosus. YJs are not for everyone please consult your physician before use.
Delta347 is offline
post #7592 of 40700 Old 05-05-2008, 07:20 PM
jbolty
jbolty's Avatar
Originally Posted by Delta347 View Post
I feel so lucky,
check these links for info
http://www.jeepforum.com/forum/f12/speedometer-gears-pre-92-yj-534426/
search here too.
http://www.macromotive.com/
report your findings. Jason and I will need one too, eventually.
jbolty is offline
post #7593 of 40700 Old 05-05-2008, 07:53 PM
Jeebs
Jeebs's Avatar
I feel so lucky,
You're putting way to much effort into this. You aren't going to see that much of a difference. You might show 62 and actually be going 65. Let it go buddy.
Jeebs is offline
post #7594 of 40700 Old 05-05-2008, 08:24 PM
grandpapy
[QUOTE=NewBlue90;5179165]We didn't end up going through. Jeff and myself were low on fuel and we all ended up turning back. We had ventured down the trail after going up Palomar Mt, playing in the snow, driving through the Lake Henshaw area and then heading down to the desert. By then it was late and we had no go-juice. [QUOTE]
that brings up a great point are there gas stations close to where we are gong or we need to bring some reserve fuel out there seems like 2-3 days of wheeling and the drive out gonna have to use a little gas in reserve more then likely.
grandpapy is offline
post #7595 of 40700 Old 05-05-2008, 08:50 PM
jbolty
jbolty's Avatar
good point. I only changed my oil about 600 miles ago and its already black so that mileage reading does not matter and speeding is certainly not an issue.
see if you can find an alternator wiring diagram for a 91 deville. I think the one I found will work but it's not for that specific year.
jbolty is offline
post #7596 of 40700 Old 05-05-2008, 10:09 PM
jbolty
jbolty's Avatar
Does anyone else get the impression that we're the only ones reading that other SD thread besides the guy that started it?
no comments. well, we tried.
where is everyone? steve and jimmy have earned a day off but the rest of San Diego jeepers have fallen off the face of the earth.
jbolty is offline
post #7597 of 40700 Old 05-05-2008, 10:09 PM
slacker92104
slacker92104's Avatar
<--------- The Squeeze.
Also: http://home.earthlink.net/~randroo/b.../107_0702.html
'81 CJ5, efi 302, AX-15 5 spd, On Board Air, wrangler spring conversion, Astro van Hydro Brakes.
Soon: Custom cut Dana 44 front, wide trac solid axle amc 20 rear, SOA,
slacker92104 is offline
post #7598 of 40700 Old 05-05-2008, 10:15 PM
Delta347
http://www.jeepforum.com/forum/showthread.php?t=534426
search here too.
Well i know 4wd.com has up to size 32 for the 1990 and before.
That macromotive site says its gears fit but...it doesn't say how many teeth they are. Just that its "SPEEDOMETER GEARS" for 28$ -_- and I called and they no answer. But the picture is a short shaft gear so concerning.
I'm going to check Ebay and Craigslist.
And Jason is passionate about making me give up. By my estimation I'll be withing 1.5mph of my true speed. Which makes me happier than it saying Im +9mph (thats with a 32tooth, with the 30 is was +15mph).
Or I could just buy a new speedometer and tcase and make it easy and expensive and a hassle on myself.
Delta347 is offline
post #7599 of 40700 Old 05-05-2008, 10:34 PM
jbolty
jbolty's Avatar
We all want you to give up. If you succeed then you will be better than us. That must not be allowed to happen. We will drag you back to our level at any cost so we can feel better about ourselves.
or
try here for info
http://www.jeepsunlimited.com/zj/speedo/speedo.htm
here for gears
http://www.wyckoffchryslerparts.com/dodspeedgear.html
or here
http://www.transmissioncenter.org/sp...e_and_jeep.htm
Teeth Color Part Number
24 WHITE 3410024
25 BLUE 3410025
26 RED 2538926
27 WHITE 52068149
28 BLUE 52068150
29 BLACK 52068151
30 YELLOW 52068152
31 GREEN 52068153
32 BLACK 52068154
33 YELLOW 52068155
34 GREEN 52068156
35 ORANGE 52068157
36 RED 52068158
37 WHITE 52068159
38 BLUE 52068060
39 GREEN 52068061
40 ORANGE 52068062
41 RED 2538941
42 WHITE 2538942
43 BLUE 2538943
jbolty is offline
post #7600 of 40700 Old 05-05-2008, 10:46 PM
Delta347
Ah! I see how it is now!
Trying to hold me back xD
Was it Home Depot you got the Ubolts and Muffler mounts at? Cuz I wrote that down as the place. Otherwise I can drop by Napa and get them tmrw, since both are close by here.
or
try here for info
here for gears
or here
Delta347 is offline
post #7601 of 40700 Old 05-05-2008, 11:21 PM
Jeebs
Jeebs's Avatar
Thats a great picture of that XJ!!
Aren't ZJ's and WJ's fatter too?
Jeebs is offline
post #7602 of 40700 Old 05-05-2008, 11:24 PM
Jeebs
Jeebs's Avatar
I think the closest gas is Julian. Gas cans are a must unless you feel like making the trek back.
Jeebs is offline
post #7603 of 40700 Old 05-06-2008, 12:07 AM
StvDiego
Julian is close, next would be either the Blue Inn at Ocotillo Wells via Split Mountain/Fish Creek and the town of Ocotillo 30 mi south on the S-2 at I-8.
Coming out Pinyon Mt we'll be sorta close, relatively speaking, to Ocotillo Wells. Heading down to Diablo Dropoff and Valecito Creek we'll be closer to Ocotillo.
It's best to fill up in Julian if you're coming from that direction, or Ocotillo if coming from the south, and, if a gas run is necessary we could run down to Ocotillo, get gas and then make the run up Mortero Canyon from there and back to camp.
I'm bringing a fire pit and have extra tents, sleeping bags and coolers and everything else for any one in need.
My idea for Friday night is to settle in camp, do the campfire and and then do the morning run Saturday, a night run Saturday and then touristing on Sunday, maybe hit the mudcaves and Canyon Sin Nombre before heading home.
StvDiego is offline
post #7604 of 40700 Old 05-06-2008, 12:19 AM
StvDiego
This Saturday, May 10th, B.F. Goodrich is hosting an event with SD 4Wheelers at Superstition Mt. OHV Area naming Superstition Mt. OHV as one of the US National Outstanding Trails.
There will be a run up Black Cat (3++) and a run on a 3 or lower rated trail to be named at 8:30am and an award ceremony following.
I'd like to go out, but, at $4 a gal... I think I'll save the $$$ for the 16th...
And, since B.F. Goodrich is the sponsor of the event there will be special pricing on B.F. Goodrich tires this Saturday, look for buy 3 get one free deals at ORW, Saturday only...
StvDiego is offline
post #7605 of 40700 Old 05-06-2008, 12:29 AM
Jeebs
Jeebs's Avatar
OK, so we need to plan for 2 dinners, 2 breakfasts and 2 lunches. Do we wanna have everyone bring their own food or plan out all 6 and have people bring something for each?
I'll be bringing a tent and sleeping crap for myself. I also have a single burner propane grill I can bring. I have my large cooler and I have the foam cooler I can bring as well. Is there a fridge or larger cooler in the camper?
DOES ANYONE HAVE A VIDEO CAMERA WITH A NIGHT VISION FEATURE ON IT? We have to get some good night video. I can also just slap an aux light on my video camera. I just thought I would ask.
I have another, random, question. I'll be grabbing 1 set of Daylighters this week and am wondering if I should grab a second set too. Is 1 gonna cut it or is 2 overkill?
Jeebs is offline
San Diego Meet and Greet, Jan 2nd 11AM Fiesta Island Jeebs SanDiego 243 12-28-2012 07:30 PM
Monster Jam San Diego (January 23rd) Delta347 SanDiego 7 01-09-2010 10:32 PM
