San Diego Area - Page 504 - JeepForum.com
 60Likes
post #7546 of 40864 Old 05-04-2008, 01:03 PM
Jeebs
2015 JK Wrangler
I think Josh is bringing his pop-up trailer. He should be able to bring it as far as you park yours without issue.
I'm debating whether or not to order the lift and hope to have it installed by then or just wait until after.
Jeebs is offline
post #7547 of 40864 Old 05-04-2008, 02:39 PM
StvDiego
The trailer should be no prob, I'm towing my Jeep in there with the RV and I've seen 30'+ Class A RV's get back way back in there, as long as the road is in good condition...
Order the lift, we can put in before you go...
StvDiego is offline
post #7548 of 40864 Old 05-04-2008, 03:01 PM
Jeebs
2015 JK Wrangler
My RTV skills are lacking..... both axles have a slight leak now. What flavor RTV are you folks normally using?
Jeebs is offline
post #7549 of 40864 Old 05-04-2008, 03:15 PM
jbolty
jbolty's Avatar
Originally Posted by Delta347 View Post
Ok so I have had a problem with my power for a while obviously, hence the alternator. Now I haven't installed it yet, and assuming it wasn't God blessing my 7hr date with Jackie....
Would having found a quarter inch size ring shaped ground that wasn't tightened all the way and then tightened it so it actually touched the metal all the way...would that have fixed what looked like low-output from the voltage meter?
EDIT: Hey Jeff, any day this week (mon - fri) that we could put that bar in or fab the alternator together? (I get my new CB and Antenna Weds and forgot if there was anything you needed me to buy wire/resistor wise for the alternator.)
Home now.
Monday, wed or friday after work is free, so far. I bet fixing the ground fixes your charging problem.
BTW.
Flew right over corral canyon today. Those trails don't look tough at all, from 30,000 feet.
jbolty is offline
post #7550 of 40864 Old 05-04-2008, 04:24 PM
StvDiego
Permatex Ultra Black Hi-Temp
StvDiego is offline
post #7551 of 40864 Old 05-04-2008, 05:46 PM
grandpapy
well i think it's time for some guards for you diff, it must be leaking from getting hit all the time
grandpapy is offline
post #7552 of 40864 Old 05-04-2008, 05:58 PM
grandpapy
where exactly are we camping? the same spot that you already posted steve or we doing a little more rugged camping? also i have a generator and some flood lights for the campground area, should i bring those along or will there be hookups etc?
post #7553 of 40864 Old 05-04-2008, 06:00 PM
05moabTJ
05moabTJ's Avatar
Take the 1.99 on rtv and the 200 on front and rear riddlers, put that towards a 3.5" lift kit, most go for 500 or so, and sail right over those diff buster rocks. But then you'd have to get ya some 33's, bout 500 for some good ones, out the door. Then you'd have to extend your brake lines for 80 or 100 or so. Nah second thought spend the 1.99 on rtv, so when you sell it for a 6 cyl the guy won't see any leaks
Synergy 3" Phase 3,FOX,TOYOs 37",TrailReady 17HD Beads,RCV shafts,Yukon 5.13
05moabTJ is offline
post #7554 of 40864 Old 05-04-2008, 06:31 PM
Jeebs
2015 JK Wrangler
We're doing the dry camping in Blair Valley. Nothing there but dirt.
I'm hoping the weather cools a bit though. I'm not gonna be feeling to enthusiastic about going when its 95+ out there...
Jeebs is offline
post #7555 of 40864 Old 05-04-2008, 07:13 PM
Delta347
Originally Posted by jbolty View Post
Home now.
BTW.
How about we reserve weds? I can scoot on down home from school, change, check for the CB+Antenna (I got a tail light mount antenna), pack it all in the jeep. And head on over once you get off work. Maybe grab some soda and grub for us during the job along the way since I will be taking back roads becuase 8 will be dead stop heading east.
Originally Posted by Leans93 View Post
So ghost has a plug in his hole and opihi has a gaping hole, Do I need to worry about this hole at all? I just don't want to start her up and have something spewing out of it.
Side Effects may include dry mouth, nausea, vomitting, water retention, painful recolage, hallucination, dementia, psycosis, coma, death, and halitosus. YJs are not for everyone please consult your physician before use.
Delta347 is offline
post #7556 of 40864 Old 05-04-2008, 08:14 PM
Jeebs
2015 JK Wrangler
I have a D30 for a TJ in my pickup that is free to the first person who comes and grabs it!!!! Ready to bolt in!
Jeebs is offline
post #7557 of 40864 Old 05-04-2008, 08:24 PM
05moabTJ
05moabTJ's Avatar
FREE LOL thats about what it will take to get rid of that thing I'd sell mine if i could, so I could buy a new built d44,but no one will want it and its set up with 4:56, a riddler cover, and an aussie...
05moabTJ is offline
post #7558 of 40864 Old 05-04-2008, 08:25 PM
jbolty
jbolty's Avatar
Keep it and start a coil over on 'ol blue.
What is it from? gears? You should be able to get some $$$ for it.
jbolty is offline
post #7559 of 40864 Old 05-04-2008, 08:32 PM
jbolty
jbolty's Avatar
Hold the phone, maybe I can use yours. I bought a YJ D30 last week because it had 4.11 in it and I am planning to regear it to 4.56.
There is more to the story but short version is that a D30 with 4.56 is what I need.
jbolty is offline
post #7560 of 40864 Old 05-04-2008, 08:37 PM
slacker92104
slacker92104's Avatar
I use the permatex aviation stuff. I use it with a gasket, and have never had a leak. Compared to the RTV that I feel like I had to re-do at least one out of three times. It's much easier to apply too. Applies with a brush that is included. I call it space goop.
http://www.napaonline.com/MasterPage...ant+-+Aviation
'81 CJ5, efi 302, AX-15 5 spd, On Board Air, wrangler spring conversion, Astro van Hydro Brakes.
Soon: Custom cut Dana 44 front, wide trac solid axle amc 20 rear, SOA,
slacker92104 is offline
San Diego Meet and Greet, Jan 2nd 11AM Fiesta Island Jeebs SanDiego 243 12-28-2012 06:30 PM
Monster Jam San Diego (January 23rd) Delta347 SanDiego 7 01-09-2010 09:32 PM
