San Diego Area - Page 496 - JeepForum.com
 61Likes
post #7426 of 40913 Old 04-28-2008, 07:45 PM
grandpapy
hey ari that trac lock that steve gave you or you bought off him whichever it maybe, i was wondering if you'll need it anymore? it's exactly what i need for my rear end D35 3.73 gears but mine isn't limited slip so maybe we can trade... what ya say? or i can buy it off you for what ever you paid steve for it. let me know send me a PM
grandpapy is offline
post #7427 of 40913 Old 04-28-2008, 08:01 PM
Delta347
Oh i passed it back to steve at the party. Unless he forgot it at jason's. I still have the Crosspin, bolt, and the driveshaft pinion for it though, forgot those were in the box, I knew something was missing.
If you want it check with him, though I am sure he will spot this, he seemed willing to part with it once, so Im sure you two can work out something.
Also grats on the lift, came out looking mighty fine!
Originally Posted by Leans93 View Post
So ghost has a plug in his hole and opihi has a gaping hole, Do I need to worry about this hole at all? I just don't want to start her up and have something spewing out of it.
Side Effects may include dry mouth, nausea, vomitting, water retention, painful recolage, hallucination, dementia, psycosis, coma, death, and halitosus. YJs are not for everyone please consult your physician before use.
Delta347 is offline
post #7428 of 40913 Old 04-28-2008, 09:49 PM
grandpapy
hey thanks yup after the hard work we all put to put it in i must say i'm mighty please with everything and those who doubted the nitro shocks for being to stiff. let me just say there perfect definitely a bit stiffer then the "cadillac" shocks i had but not overly stiff and there is no axle hop or anything like that associated with overly stiff springs. So i'm glade that worked out cause i was a little nervous they would be to stiff.
Hey steve, you think i can take that trac lock off your hands?
post #7429 of 40913 Old 04-28-2008, 10:02 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Originally Posted by NewBlue90 View Post
Apparently Joe forgot what the "P" was in PM....
Yeah, I normally would not post what was mentioned in a PM. I'm not a kiss & tell kinda guy. But.....since they were my words & I was being too lazy at the time to retype the same exact thing again, I decided to do a copy & paste.
Joe Dillard is offline
post #7430 of 40913 Old 04-28-2008, 10:03 PM
jbolty
jbolty's Avatar
Here is the link to all of the pictures along with some 'before and afters'
There are no pictures of my cup holder.
Nice body carnage though.
jbolty is offline
post #7431 of 40913 Old 04-28-2008, 10:09 PM
jbolty
jbolty's Avatar
Found this at Costco if anyone is interested.
Good Deal. I got the older model on closeout for $39.
jbolty is offline
post #7432 of 40913 Old 04-28-2008, 10:13 PM
Joe Dillard
That's good news about the Super axle Jeff. It should serve you well.
I may just have a trick or two left up my sleeve.
post #7433 of 40913 Old 04-28-2008, 10:14 PM
jbolty
jbolty's Avatar
Jeff, want to throw yet another thanks your way.
I called that Gear place off of Ronson. They said they have had a case like mine before and Do have YJ gears and that I can either buy new ones based off the locker diameter (assuming i bring it in with me). Or I can have the sides from the second axle downsized or ground down, it was hard to hear.
I figure I would be best to just buy new ones, and discover what this axle I bought is geared for and repair the brakes on it (what i was asking for, though I will probably buy the kit for my own axle as well).
If we want to move the Jeep at this point, I am willing to do that. I will make the detour onto the 805 tmrw to drop by the axle shop to get the right parts. Any votes on which of those I should do?
EDIT: Just got an email from the PO:
"I'm sorry to hear you're still having issues. I bought the rear 35 off
of a guy that had a 4cyl that came with stock 4:11 gears; he had
installed the locker. I don't know anything else besides that; I'd
never even taken off the rear diff cover. Good luck!"
good news. if you can get new parts for the existing setup, do it. I never heard of grinding gears to fit, but I guess they know what they are doing. If you can sneak past the guards and get the parts back in there will be no need to tow it. We can fix the brakes at the next repair party. What condition is your e-brake cable? Those are pretty cheap, if you order them online.
jbolty is offline
post #7434 of 40913 Old 04-28-2008, 10:17 PM
jbolty
jbolty's Avatar
I'm excited about it. I will still go to pick-a-part and look for an 8.8 with 4.11 though. If I can get one for $80 then I will not have to regear the front. But either way I am GOOD TO GO.
Now I need to decide whether to go over or under. I am inclined to stick to 33's and stay under. No steering issues, no driveline issues, no messing with the front.
Plety of time to decide on that.
jbolty is offline
post #7435 of 40913 Old 04-28-2008, 10:36 PM
Delta347
Well I am sure you remember the condition the brake springs and setup all was or atleast have a general memory on it from when we tore it all apart way back when in CC. If not, its pretty ugly and rusted and weak.
As for my cable, I will need to check that, though I would feel better with a second opinion as I have never checked one before. I do know i need a new spring for the Ebrake pedal, it sags and flops around on its own and triggers the light which is annoying.
Delta347 is offline
post #7436 of 40913 Old 04-28-2008, 10:47 PM
Joe Dillard
You might want to check to see if the dealership recall was ever done to your ebrake assembly which addresses this issue. It's a free deal to whoever owns the Jeep.
post #7437 of 40913 Old 04-28-2008, 10:50 PM
jbolty
jbolty's Avatar
the main thing with the brake cable is if it moves freely. usually they get rusted in place from age and disuse.
I had to add a spring to my e-brake
brakes are easy and a real positve feedback item because the differnce is readily apparent.
jbolty is offline
post #7438 of 40913 Old 04-28-2008, 10:56 PM
jbolty
jbolty's Avatar
search here for recalls
http://www-odi.nhtsa.dot.gov/cars/pr...callsearch.cfm
or here.
http://www.jeep.com/en/owners/
jbolty is offline
post #7439 of 40913 Old 04-28-2008, 11:12 PM
Delta347
Checked the sites, none of the recalls apply to me.
Cept the front brake line one, but I have new brake lines in a different position so they can't rub against the wheel.
and the recall on parking brakes is for manuals only.
Other stuff involves old aftermarket replacements.
I will stop by the gear shop tmrw after school. Then when i get home check the brake line.
By the way the flopping and sagging of the ebrake is only when it is disengaged. Its tight when i put it on. I think its just a warn spring on it. But i will check the rest for safety.
Delta347 is offline
post #7440 of 40913 Old 04-29-2008, 03:00 AM
Jeebs
2015 JK Wrangler
Nobody wants to play @ 2AM???
Jeebs is offline
San Diego Meet and Greet, Jan 2nd 11AM Fiesta Island Jeebs SanDiego 243 12-28-2012 06:30 PM
Monster Jam San Diego (January 23rd) Delta347 SanDiego 7 01-09-2010 09:32 PM
